LG WH16NS40 No Disk Inserted
Cripples23
Successfully flashed my WH16NS40 to 1.02 to enable Libredrive. When I insert a disk however the blue activity light blinks for a couple seconds and Makemkv disk image spins for about 3 or 4 seconds then says no disk inserted. I need some help!
Re: LG WH16NS40 No Disk Inserted
What's the build date of your drive says on top labelCripples23 wrote: Mon Aug 21, 2023 5:19 pm Successfully flashed my WH16NS40 to 1.02 to enable Libredrive. When I insert a disk however the blue activity light blinks for a couple seconds and Makemkv disk image spins for about 3 or 4 seconds then says no disk inserted. I need some help!
Cripples23
Billycar11 wrote: Mon Aug 21, 2023 5:29 pmWhat's the build date of your drive says on top labelCripples23 wrote: Mon Aug 21, 2023 5:19 pm Successfully flashed my WH16NS40 to 1.02 to enable Libredrive. When I insert a disk however the blue activity light blinks for a couple seconds and Makemkv disk image spins for about 3 or 4 seconds then says no disk inserted. I need some help!
January 2020
Ok try this turn off the computer completely unplug psu for 5 mins
Then turn back on and put a disc in do not open makemkv untill your computer sees the disc in file explorer
Cripples23
Will do, will report back with what happens.Billycar11 wrote: Mon Aug 21, 2023 5:59 pmOk try this turn off the computer completely unplug psu for 5 mins
I should add off the drive is external unplug that power tooCripples23 wrote: Mon Aug 21, 2023 6:01 pmWill do, will report back with what happens.Billycar11 wrote: Mon Aug 21, 2023 5:59 pmOk try this turn off the computer completely unplug psu for 5 mins
Cripples23
Internal drive so no need there, drive shows up in file explorer but can't access movie from there either.Billycar11 wrote: Mon Aug 21, 2023 6:17 pmI should add off the drive is external unplug that power tooCripples23 wrote: Mon Aug 21, 2023 6:01 pmWill do, will report back with what happens.Billycar11 wrote: Mon Aug 21, 2023 5:59 pm
Well then I guess it's dead did you test it before flashing?Cripples23 wrote: Mon Aug 21, 2023 6:19 pmInternal drive so no need there, drive shows up in file explorer but can't access movie from there either.Billycar11 wrote: Mon Aug 21, 2023 6:17 pmI should add off the drive is external unplug that power too
Cripples23
That's what I was afraid of, and no I did not just got the drive in and was so excited to get going I didn't even think of it. Looks like it's time for an ebay return.Billycar11 wrote: Mon Aug 21, 2023 6:46 pmWell then I guess it's dead did you test it before flashing?Cripples23 wrote: Mon Aug 21, 2023 6:19 pmInternal drive so no need there, drive shows up in file explorer but can't access movie from there either.Billycar11 wrote: Mon Aug 21, 2023 6:17 pm
Never buy these LG/Asus drives used they are complete junkCripples23 wrote: Mon Aug 21, 2023 6:48 pm
The reason people sell them is because they are bad
Cripples23
The one I bought was supposedly new without original packaging. But I can assume that was never the case. In your experience what has been the best drive?Billycar11 wrote: Mon Aug 21, 2023 6:56 pmNever buy these LG/Asus drives used they are complete junkCripples23 wrote: Mon Aug 21, 2023 6:48 pm
The pioneers I sellCripples23 wrote: Mon Aug 21, 2023 6:58 pmThe one I bought was supposedly new without original packaging. But I can assume that was never the case. In your experience what has been the best drive?Billycar11 wrote: Mon Aug 21, 2023 6:56 pmNever buy these LG/Asus drives used they are complete junkCripples23 wrote: Mon Aug 21, 2023 6:48 pm
