LG WH16NS40 No Disk Inserted
Cripples23
Post by Cripples23 »
Successfully flashed my WH16NS40 to 1.02 to enable Libredrive. When I insert a disk however the blue activity light blinks for a couple seconds and Makemkv disk image spins for about 3 or 4 seconds then says no disk inserted. I need some help!
Re: LG WH16NS40 No Disk Inserted
Cripples23 wrote:
Mon Aug 21, 2023 5:19 pm
What's the build date of your drive says on top label
Cripples23
Billycar11 wrote:
Mon Aug 21, 2023 5:29 pm
January 2020
Cripples23 wrote:
Mon Aug 21, 2023 5:52 pm
January 2020
Ok try this turn off the computer completely unplug psu for 5 mins
Then turn back on and put a disc in do not open makemkv untill your computer sees the disc in file explorer
Cripples23
Billycar11 wrote:
Mon Aug 21, 2023 5:59 pm
January 2020
Will do, will report back with what happens.
Cripples23 wrote:
Mon Aug 21, 2023 6:01 pm
January 2020
I should add off the drive is external unplug that power too
Cripples23
Billycar11 wrote:
Mon Aug 21, 2023 6:17 pm
Internal drive so no need there, drive shows up in file explorer but can't access movie from there either.
Cripples23 wrote:
Mon Aug 21, 2023 6:19 pm
Well then I guess it's dead did you test it before flashing?
Cripples23
Billycar11 wrote:
Mon Aug 21, 2023 6:46 pm
That's what I was afraid of, and no I did not just got the drive in and was so excited to get going I didn't even think of it. Looks like it's time for an ebay return.
Cripples23 wrote:
Mon Aug 21, 2023 6:48 pm
Never buy these LG/Asus drives used they are complete junk
The reason people sell them is because they are bad
Cripples23
Billycar11 wrote:
Mon Aug 21, 2023 6:56 pm
The one I bought was supposedly new without original packaging. But I can assume that was never the case. In your experience what has been the best drive?
Cripples23 wrote:
Mon Aug 21, 2023 6:58 pm
The pioneers I sell
