LibreDrive for Pioneer drives
randomgeeza
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: CFDL000915WL
Firmware date: 2022-12-27
Highest AACS version: 66
Drive platform: Pioneer RS9331
Firmware version: ID05
Completely new to all of this and feeling my way around. Any insight would be gratefully received...
Revision: 1.02
Pioneer firmware update February 2023randomgeeza wrote: Fri Aug 18, 2023 6:45 pm Drive Information
Revision: 1.02
A solution still pending...
Just registered to reply your question.tommik128 wrote: Wed Aug 09, 2023 2:40 pm Hi guys, I have the Pioneer 209 EBK (209-M) and the current firmware is only 1.34/ID60. It is probably perfect for MakeMKV but I would like to upgrade the drive since it will be used as a burner as well. Is that 1.54 firmware still safe for MakeMKV? (I guess it might be since that firmware should be quite old - 2020?).
The BDR-209EBK is an awesome drive and absolutely makeMKV safe, incl FW1.54.
You can downgrade from v1.54 to previous versions (did it myself) and also crossflash to the BDR-211 v1.53 to read UHD discs (again, done by myself).
One important thing, don't crossflash to v1.54 of the BDR-211, you lose downgrade, crossflash, lose the ability to play UHD with a Leawo Blu-ray player (according to a different forum, other programs may be also affected) and lose the "safety" of makeMKV.
Tom
Hi Tom886,Tom886 wrote: Mon Aug 21, 2023 2:17 am The BDR-209EBK is an awesome drive and absolutely makeMKV safe, incl FW1.54.
which tool did you use to flash the BDR-209EBK to BDR-211, please?
can anyone recommend a tool to crossflash a BDR-209EBK to a BDR-211UBK?
anyone...? Bueller?
anyone...? Bueller?
Hi there,
I'd like to crossflash my Pioneer S12-XLT Firmware 1.02 to UHT Version, but I cant find the necessary tool. Where can I get it please?
Greetings
Greetings
Aflutter8838
Do you have instructions for flashing Pioneer Electronics BDR-XS07UHD. Right now my libre status shows possible, but not enabled. It looks like at one point this drive worked without flashing that is the reason I bought it. It looks like firmware has been updated. Please help
Email me for thatmiba78 wrote: Wed Sep 06, 2023 7:31 pm Hi,
anyone...? Bueller?![]()
Email below i maybe able to helpuhxc378 wrote: Wed Sep 06, 2023 8:22 pm Hi there,
Greetings
Sorry there is currently no way to flash those on the new fwAflutter8838 wrote: Wed Sep 06, 2023 9:00 pm Hello,
nohairbear
Got an older Pioneer drive, posting the particulars for inclusion in the .bin file. Thanks.
Product: BD-RW BDR-209M
Revision: 8.11
Serial number: PADL077796WL
Firmware date: 2014-01-16
Highest AACS version: 63
Drive platform: RS8600
Firmware version: 8.11/ID52
Revision: 8.11
You guys asking questions on this forum are sloooooow. You should read PMs more frequently. Its a nuisance if you want to get help. Just my 2 cents.
Meh. I discovered that my internal drive on my old PC works perfectly, so I'm in no rush for Pioneer support now.Coopervid wrote: Fri Sep 08, 2023 9:21 pm You guys asking questions on this forum are sloooooow. You should read PMs more frequently. Its a nuisance if you want to get help. Just my 2 cents.
Read your PM.MrEJ42 wrote: Fri Sep 08, 2023 10:10 pmMeh. I discovered that my internal drive on my old PC works perfectly, so I'm in no rush for Pioneer support now.Coopervid wrote: Fri Sep 08, 2023 9:21 pm You guys asking questions on this forum are sloooooow. You should read PMs more frequently. Its a nuisance if you want to get help. Just my 2 cents.
You're confusing me with someone else. I have a BDR-XD08U, for which no solution currently exists.Coopervid wrote: Sat Sep 09, 2023 10:07 amRead your PM.MrEJ42 wrote: Fri Sep 08, 2023 10:10 pmMeh. I discovered that my internal drive on my old PC works perfectly, so I'm in no rush for Pioneer support now.Coopervid wrote: Fri Sep 08, 2023 9:21 pm You guys asking questions on this forum are sloooooow. You should read PMs more frequently. Its a nuisance if you want to get help. Just my 2 cents.
