Settings Make MKV Quality
lmarcus
Post by lmarcus »
When I rip a DVD I find that I lose quality.
There is noise that is added.
The textures drool much more.
How should I adjust the software to avoid all this?
Thank you
Re: Settings Make MKV Quality
MakeMKV copies the contents of the DVD, Bluray, or UHD to your drive as a 1:1 copy. If the result is "not adequate", there is nothing you can do about it, unless you find a better quality disk.
and to avoid the obvious reply of it looked good when i played it direct on my dvd player to tv
no it didn't your tv or player was upscaling and "enhancing" it and that stuff is junk you always want native files how they were intended to look
