Gatorman
#8716 Post by Gatorman » Wed Aug 16, 2023 2:08 am
Nice! That will be useful. Perhaps better for those without Nvidia GPUs. I haven't done enough testing, but I've run 2 videos thru (3-1) where I created the prores file with StaxRip and the time to generate the RPU is far more reasonable. The time to complete only goes down, it doesn't climb.
djanvi2020
#8717 Post by djanvi2020 » Wed Aug 16, 2023 9:00 am
can someone remind me,
is there a way you can up the quality of the DD+ when you use MP4 Workflow cause 128kbps doesn't seem sufficient enough?
#8718 Post by RESET_9999 » Wed Aug 16, 2023 10:43 am
djanvi2020 wrote: Wed Aug 16, 2023 9:00 am can someone remind me,
it's 128 per channel so 1024kbps total which is the maximum allowed by DEE and EAE for a coreless EC3
#8719 Post by RESET_9999 » Wed Aug 16, 2023 12:05 pm
Gatorman wrote: Wed Aug 16, 2023 2:08 am Nice! That will be useful. Perhaps better for those without Nvidia GPUs.
it was already falling back to the CPU when no GPU was detected.
In the next version, I'll use madvr for the scene cuts so Resolve wont be needed anymore (except for dynamic L5)
dividingelves
#8720 Post by dividingelves » Wed Aug 16, 2023 9:39 pm
Hi guys,
First of all thanks RESET_9999 for the script.
With the option 7-1-1 I get the following error and I don't know why.
Error parsing command line!
[Importer] Cannot load filter for input file "M:\DoVi_Scripts_TOOLS\TEMP_folder\1.mp4"
Failure while importing import: Requested URL is not valid or cannot be found
Error importing M:\DoVi_Scripts_TOOLS\TEMP_folder\1.mp4#1: Requested URL is not valid or cannot be found
2023/08/16 23:16:42 failed processing file M:\DoVi_Scripts_TOOLS\Avatar2022.mkv: cannot open file "M:\DoVi_Scripts_TOOLS\Avatar2022.mkv": open M:\DoVi_Scripts_TOOLS\Avatar2022.mkv: The system cannot find the file specified.
the script has completed...
                        _____    __      ___       _____           _       _
                       |  __ \   \ \    / (_)     / ____|         (_)     | |
                       | |  | | __\ \  / / _     | (___   ___ _ __ _ _ __ | |_ ___
                       | |  | |/ _ \ \/ / | |     \___ \ / __| '__| | '_ \| __/ __|
                       | |__| | (_) \  /  | |     ____) | (__| |  | | |_) | |_\__ \
                       |_____/ \___/ \/   |_|    |_____/ \___|_|  |_| .__/ \__|___/
                       -@RESET_9999---------------------------------|__|-----------
 Choose a mode...
1) MODE.I=  DoVi Inject/Convert/Edit/Re-sync TWO INPUTS (P8 Hybrid maker/Injector)
2) MODE.F=  DoVi Fix/Edit/Extract/Verify/Info ONE INPUT
3) MODE.H=  DoVi Maker from HDR10 (Dolby Algo or madVR or HDR10plus)
4) MODE.P=  DoVi Profile 7 Input (MKV/BDMV)
5) MODE.B=  Dovi Batch Muxer
6) MODE.M=  MIXED: Plot/Audio/Screenshots/Remove/Player/Encoder and more...
7) MODE.M4= MP4 Workflows
8) Exit
Choice? [1,2,3,4,5,6,7,8]?7
                                           * CHOOSE A MODE *
1) MODE.1= Single-Track output (FAST mp4box/iOS/Sony & newer LG TVs)
2) MODE.2= Single-Track output (SLOW Old mp4muxer for older LG TVs)
3) MODE.3= Dual-Track output (p7)
4) MODE.4= Demuxer (p5, p8, p7)
5) MODE.5= Davinci Resolve ready files maker
6) MODE.6= back to main menu
Choice? [1,2,3,4,5,6]?1
                                         * CHOOSE A WORKFLOW *
-- Dont use these workflows for older LG TVs (EG. C9 or older). Use (7-2) instead
1) Workflow.1= MKV/HEVC/TS/M2TS input + AC3/EC3
2) Workflow.2= MKV/HEVC/TS/M2TS input + PCM
3) Workflow.3= Bluray Disc to Profile 8 + AC3/EC3
4) Workflow.4= Bluray Disc to Profile 8 + PCM
5) Workflow.5= Batch muxer (up to 13 videos/audio/srt.subs)
6) Workflow.6= back to main menu
-- Input can be P5-P7-P8-HDR10plus-HDR10 HEVC/H265/MKV/TS/M2TS - SRT/AC3/EC3/AAC/DTS/DTSHD/THD
-- If input doesnt have Dynamic Metadata(DV or HDR10+), it will use madVR to generate it.
-- If input has lossless audio, DDP 1536kbps will be encoded.
  Drag and drop your DoVi video file and press enter...
"\\nas\movies\Avatar\Avatar2022.mkv"
Do you want to create a fake P5 mp4? y or n default=n
n
Sorting the input tracks format/id/language...
done.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Extracting track 1 with the CodecID 'A_TRUEHD' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A1.thd'. Container format: TrueHD
Extracting track 2 with the CodecID 'A_AC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A2.ac3'. Container format: Dolby Digital (AC-3)
Extracting track 3 with the CodecID 'A_EAC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A3.ac3'. Container format: Dolby Digital Plus (E-AC-3)
Extracting track 4 with the CodecID 'A_TRUEHD' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A4.thd'. Container format: TrueHD
Extracting track 5 with the CodecID 'A_AC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A5.ac3'. Container format: Dolby Digital (AC-3)
Extracting track 8 with the CodecID 'S_TEXT/UTF8' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\S8.srt'. Container format: SRT text subtitles
Extracting track 15 with the CodecID 'S_TEXT/UTF8' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\S15.srt'. Container format: SRT text subtitles
Progress: 100%
ffmpeg version 6.0-full_build-www.gyan.dev Copyright (c) 2000-2023 the FFmpeg developers
  built with gcc 12.2.0 (Rev10, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      58.  2.100 / 58.  2.100
  libavcodec     60.  3.100 / 60.  3.100
  libavformat    60.  3.100 / 60.  3.100
  libavdevice    60.  1.100 / 60.  1.100
  libavfilter     9.  3.100 /  9.  3.100
  libswscale      7.  1.100 /  7.  1.100
  libswresample   4. 10.100 /  4. 10.100
  libpostproc    57.  1.100 / 57.  1.100
Input #0, truehd, from 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A1.thd':
  Duration: N/A, start: 0.000000, bitrate: N/A
  Stream #0:0: Audio: truehd, 48000 Hz, 7.1, s32 (24 bit)
Stream mapping:
  Stream #0:0 -> #0:0 (truehd (native) -> eac3 (native))
Press [q] to stop, [?] for help
Output #0, matroska, to 'M:\DoVi_Scripts_TOOLS\TEMP_folder\EC3.1.mkv':
  Metadata:
    encoder         : Lavf60.3.100
  Stream #0:0: Audio: eac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.0(side), fltp, 1536 kb/s
    Metadata:
      encoder         : Lavc60.3.100 eac3
size= 2174999kB time=03:12:53.13 bitrate=1539.6kbits/s speed=74.8x
video:0kB audio:2169966kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.231956%
Extracting track 0 with the CodecID 'A_EAC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A1.ec3'. Container format: Dolby Digital Plus (E-AC-3)
Progress: 100%
Output #0, mp4, to 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A1.mp4':
  Metadata:
  Stream #0:0: Audio: truehd (mlpa / 0x61706C6D), 48000 Hz, 7.1, s32 (24 bit)
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
size= 7441180kB time=03:12:53.14 bitrate=5267.2kbits/s speed=13.4x
video:0kB audio:7386366kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.742098%
Input #0, truehd, from 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A4.thd':
Stream mapping:
  Metadata:
    Metadata:
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 6a.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated d8.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 2b.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated f7.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 74.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated ac.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 52.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 0e.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated ab.
[truehd @ 000001f3e7ab5d80] quant_step_size larger than huff_lsbsx
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 6b.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 0a.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated ea.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 9a.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated e5.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated f3.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 79.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 46.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 5f.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 60.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 34.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated f2.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 59.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated d3.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated fa.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 55.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated c1.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 8a.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 13.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated b6.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated ba.
size= 2171433kB time=03:12:34.15 bitrate=1539.6kbits/s speed=75.9x
video:0kB audio:2166408kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.231956%
Extracting track 0 with the CodecID 'A_EAC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A4.ec3'. Container format: Dolby Digital Plus (E-AC-3)
Progress: 100%
Output #0, mp4, to 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A4.mp4':
  Metadata:
Stream mapping:
size= 6853036kB time=03:12:34.17 bitrate=4858.9kbits/s speed=12.5x
video:0kB audio:6798322kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.804821%
muxing into a MP4 DoVi file. Be patient, it can take a while. 40min+ on slow HDD!
thirdmoon
#8721 Post by thirdmoon » Thu Aug 17, 2023 6:52 am
@RESET_9999
In the next version can we have 3-1 take prores input. For now it starts converting to prores even if the input is prores.
#8722 Post by RESET_9999 » Thu Aug 17, 2023 11:00 am
thirdmoon wrote: Thu Aug 17, 2023 6:52 am @RESET_9999
seems fine in the latest beta?
fransalas
#8723 Post by fransalas » Thu Aug 17, 2023 11:18 am
in the latest beta of dovi_scrit the command 6-2-3- does not extract the plot.png or the rpu, thank you very much for everything in advance
#8724 Post by RESET_9999 » Thu Aug 17, 2023 11:21 am
fransalas wrote: Thu Aug 17, 2023 11:18 am in the latest beta of dovi_scrit the command 6-2-3- does not extract the plot.png or the rpu, thank you very much for everything in advance
mm yes it does, I just tried the mkv and ts version.
fransalas
#8725 Post by fransalas » Thu Aug 17, 2023 11:29 am
Well, it gives me an error
#8726 Post by RESET_9999 » Thu Aug 17, 2023 12:07 pm
ha for XML inputs. You guys should give more info about your input files when you report a problem.
replace lines 8312 and 8313
     "%dovi_tool_path%" generate --xml "%filepath%%filename1%%fileext1%" --canvas-width 3840 --canvas-height 2160 --rpu-out "%output_path%%filename1%_RPU.bin"
	 set RPU="%output_path%%filename%_RPU.bin"
by this
     "%dovi_tool_path%" generate --xml "%filepath1%%filename1%%fileext1%" --canvas-width 3840 --canvas-height 2160 --rpu-out "%output_path%%filename1%_RPU.bin"
	 set RPU="%output_path%%filename1%_RPU.bin"
or wait for the next beta.
fransalas
#8727 Post by fransalas » Thu Aug 17, 2023 12:12 pm
ok, thanks, I'll wait for you, use previous versions..
thank you so much
Lapihin_A
#8728 Post by Lapihin_A » Thu Aug 17, 2023 12:18 pm
Hi @RESET_9999! I re-downloaded the original release of After Earth 2013 BCORE with Color range: Full, it plays the same as Limited (after changing the flag) i.e. the movie is dark, although when comparing screenshots (6-8-3) it looks normal. Is there any way to make the movie play with Color range: Limited?
Dune HD Real Vision 4K playback device.
#8729 Post by RESET_9999 » Fri Aug 18, 2023 1:35 am
Lapihin_A wrote: Thu Aug 17, 2023 12:18 pm Hi @RESET_9999! I re-downloaded the original release of After Earth 2013 BCORE with Color range: Full, it plays the same as Limited (after changing the flag) i.e. the movie is dark, although when comparing screenshots (6-8-3) it looks normal. Is there any way to make the movie play with Color range: Limited?
yep, I've compared HDR10/DV to the MA version, and the BCORE definitely looks crushed/wrong. Not sure if there's anything we can do about it.
thirdmoon
#8730 Post by thirdmoon » Sat Aug 19, 2023 4:40 am
@RESET_9999
Using 3-1 in 1.9.1.5 beta
Input Martian.mov and for cutscenes hdr10plus.json generated in DaVinci
