Didier (1965)
Sheep18
Didier (1965)
Post by Sheep18 »
Hi all,
can't open this disc. Is it a bad disc or some other issue? See attached.
Re: Didier (1965)
Well, without any attachment, it is REALLY impossible to say what the issue is. Your question is appropriate - it could be a bad disk, or some other issue.
Why not provide some information to work with?
Sheep18
Re: Didier (1965)
Post by Sheep18 »
Was just testing your magic skills :)
Just kidding, I am pretty sure I did attach something. Another try...
EDIT:
Nope still not working. Error message behind the attachment is "Sorry, the board attachment quota has been reached." It is certainly not too big, since it is only 116 KB.
Re: Didier (1965)
Ah, well... There is a limit to storage capabilities, and it seems the forum reached them. Since Mike is in control of that, it's hard to say what I can do...
Sheep18
Re: Didier (1965)
Post by Sheep18 »
Sooo... do I have to contact him? The problem with the attachment remains.
Re: Didier (1965)
Are you trying to post the text of a MakeMKV log? Just paste it in.
If you're fancy, put it in 'code' tags.
Sheep18
Re: Didier (1965)
Post by Sheep18 »
Debug log started at Fri Aug 18 08:33:31 2023 , written by MakeMKV v1.17.4 win(x64-release)
001005:0000 MakeMKV v1.17.4 win(x64-release) gestartet
No  SDF v098: Slimtype_DVD_A__DA8AESH_XA1M_KO0080F01380403D44F101
DEBUG: Code 3 at w.G,[.W,J~s[OWwzq<.Q$D1P:29395310
SDF id v098: Slimtype_DVD_A__DA8AESH_XA1M_KO0080F01380403D44F101
SDF  v098: TSSTcorp_BDDVDW_SE-506BB_TS00_R90K6YWD700GCR
No  SDF v098: ASUS_SDRW-08D2S-U_BA01_3733508A97_436016518329
SDF id v098: ASUS_SDRW-08D2S-U_BA01_3733508A97_436016518329
No  SDF v098: ASUS_SDRW-08D2S-U_BA01_3733508A97_436016518327
SDF id v098: ASUS_SDRW-08D2S-U_BA01_3733508A97_436016518327
No  SDF v098: ASUS_SDRW-08D2S-U_BA01_3733508A97_436016518219
SDF id v098: ASUS_SDRW-08D2S-U_BA01_3733508A97_436016518219
No auto SDF v098: Slimtype_DVD_A__DA8AESH_XA1M_KO0080F01380403D44F101
DEBUG: Code 0 at /$I_D_s_U8V}=/y'0:29396253
DEBUG: Code 0 at Hu0Y6$"G%/26#v|y:213136746
DEBUG: Code 2317353435 at /$I_D_s_U8V}=/y'0:121265246
DEBUG: Code 0 at /$I_D_s_U8V}=/y'0:213133388
DEBUG: Code 1 at /$I_D_s_U8V}=/y'0:213133388
DEBUG: Code 2 at /$I_D_s_U8V}=/y'0:213133388
DEBUG: Code 3 at /$I_D_s_U8V}=/y'0:213133388
DEBUG: Code 4 at /$I_D_s_U8V}=/y'0:213133388
DEBUG: Code 5 at /$I_D_s_U8V}=/y'0:213133388
DEBUG: Code 2317353435 at /$I_D_s_U8V}=/y'0:29396943
DEBUG: Code 0 at Hu0Y6$"G%/26#v|y:29401750
003007:0000 Direkter Zugriffsmodus wird verwendet
005085:0000 Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
DEBUG: Code 2147483648 at Nx*e^{R_\6h/]Oy7:121265499
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=abXdU0D3jzEv0H6h0cdueKKWYvqe9DY13UkPMivaXOqt+HqQmvtuRfhVMskgH5datROsJ+oZoG5anXwz2VD3Bcs1jfhcoBP9iTKZs3KdrG4mx7RSg2IO32+INd27bmO6+zizhprPw5CPXNhFrvKTtmaiByCBmkDSww==
002004:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:UNRECOVERED READ ERROR' trat auf während der Übertragung des SCSI-Befehls AD010..080002400 zu Laufwerk 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at YMq3jgB7A;@Jc9Lkn:213130306
DEBUG: Code 0 at s}-}>EOo+VG9bh]Lv3:121264395
DEBUG: Code 0 at s}-}>EOo+VG9bh]Lv3:213130789
DCE=RVg8NB01jx4mdTW1J1u/pNrQSBMyY23nNdBB9UXUgzqox6tYwegbokGrzMTpTfL78p4CT5BSM7zqzHuJ9h8PunVH/pNOzH5FxDQQMcJd9ci9gd2ZcEd3+7n+vk4PieX9SHzpcIavEjsjvX3DYvcgK1uA3Qfb4MSGlw==
DEBUG: Code 1 at s}-}>EOo+VG9bh]Lv3:213130789
DCE=Ttu3tnbhG9LbyTZUWL6YLSCSYvq72G2yXkqgZVSW9gBcJG/C3uzRezcQVBm/vMBqErqnuFJJ3W4usSVz1SBEhKGaO/RUbgoM3ckgxW41hLq2eRjUeFbesYTVODltNQG89991A0cLSM7BN9jPT6CU9Owv9oAHA2o8ug==
DEBUG: Code 2 at s}-}>EOo+VG9bh]Lv3:213130789
DCE=+xCInyHyeshAS+eRrOPxy7P+EkwasgkVEj+uhh7wKk42k0NbWhSMFhceT+fSwfqZkrKdA+NxIvHU5Z53tH74ZCzsTUXoPD5172cEGm4JxM6cGkT7Rqy9IwM+2h3o0hj+LPt3S4g/GS/7a3wdXayhdC8SBf+/UWPyfg==
DEBUG: Code 3 at s}-}>EOo+VG9bh]Lv3:213130789
DCE=Gy0naaxhWpnLVDtTf970rjTqcof8DQw3OkAZeCONB8/gfZzJstT7QGUQVhhJBJomnSHvRs5CKYTQGe0czCg4XRQMGhYORIkqlrLoWLcjHDP+ofxW2V5E3oP9pc0rXQyZRHMpOWR7FRnM1FMCWogS0NdFojnVejqe9w==
DEBUG: Code 4 at s}-}>EOo+VG9bh]Lv3:213130789
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..09E7ED962DD50A514DFDD1B44C1BA585202 zu Laufwerk 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at YMq3jgB7A;@Jc9Lkn:213130766
DEBUG: Code 0 at s}-}>EOo+VG9bh]Lv3:121263429
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0398BEBD00934C9C0F659BE3383616A1EEC zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..091139D552D4EA5C78F2F9F47070BF77519 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0EFFB89060B8C36B6584DA60E58B90F176F zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..079AF107AC14806599342916DA395B725C6 zu Laufwerk 'SPTI:\Device\CdRom1'
DCE=oIdG3Xg0jRHbDZXFPDbz8X3YsApEC0M6QDJvTWsmc6eVVc0I5B1A2LIFwsehuRaQy9e9EX2O1iE+0OcTEr9H7dnY/lyfnNPTms0fBGErpRLYcWULyAG1/6oHLTqCgPJorP0uItrKWenebA+HtfTDEOZQZaY89hC/ww==
DCE=oPaQBspFwicrOv/47DtrT7RBzxxXPpC0rFEmalzs/wsFnhz9PI7dBMAYmVlo4o3ObJGx0cu2KXfvraZa1TyesZZZnXtCBODR8zasmRyFY8EDd81L0VCcXUYahviwRcW7lmXf7sGPZoEx/VQ9gQeknFox1/zj4PK0sQ==
DCE=GuDusZDiR+wgGb/OepJyAhlKOpYTq6Ldo1fh5VDKjax929PhorG0jfRYgKRJngXIGd6XecWlkBvTvI6T8/nCqAV3QlYtthl0t1WJ5NnrwDiPZhXJYJSioO33Lykhm1jxKU60UIIE/eFEIFE2e1J9FmcxLpCtUj2S+Q==
DCE=SwN8bqhsdFbaWdYA5mQPhqScV9f4vQ/reZF6x/Q9DnUJHzQ5byRhxISB6Zyr8d4RXxlIoKZO8q1FT6euakkWn8MlsiIZVXHvEYHPRu4FbGj+kMmycEjz2Jqgk9SnxfJ0VSH6kXtz3OXIDOvt1/qop8ZlSdQVSJK+jw==
DCE=tq8Awz51dIZeXxTNqYXeaLG4SGQCwkwSA++ep8dx90/l68jo85QtC5tX9mStsLFHOr7UmoCKJsEHGBQHwb2h4E68iOmQ8erSZXkQlMIKjv/7ggCPJpECJlwuS8gZAayIACKyMzXTXqgqIs2tQYNZVHTbXDJu8SPdYw==
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..02B826377B6BF8A79F5D43D42B890042148 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..06785635E9AA0C56D71140D15971C02549B zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0048107119DA7B6643C84C7FD847CB5C5AD zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0CA98BB9E894B03B2AF86C6A4EE202400D4 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..083C9D078394401A390211C6520055754F7 zu Laufwerk 'SPTI:\Device\CdRom1'
DCE=i8tG6J2EQp0q+ESZa0czIvSQCyCCr8P4OLokmjrAUlx+SayOm43s00ZB4G2Va79Du5MVUwekkDsAnj7hL2ODeebUWGmN2zIwB6o472zyRDk7TAUe80eyN9tmsI4MCvZAZoKms8BKmzQBh2dt2yJTlCIga3hlxbOguw==
DCE=pMnx/iM9ofiy0WrIP3qtBF0Q2/f6ClFESu2L6jWtLUsGvgw/tK212XL9l28JK+cP7nQ61+m0U032XcqWGChhAZY5HKZLZgxjZSNK7Ki9VIx9Ec5n+W5F+sJnzuf52IwHz894GrpiI/8zEioO0yJBVrYid3aSRpiwGQ==
DCE=VMahiBNIyVv2o6pIrNnjukqW0YP9XdqdFInFTYvBTsufc0HNbqpcz1MpJdG27ZA2UhYTCxHHpDUT22k/atiHmN3YYAgc/msRcSK1VEpnnCArxeJYWVg4uCN19EY39hxzgReS6hcipEHMvc3jjsbVIW+9ClOyrx5C6g==
DCE=X4AbcvopIYSfYl501eaDi1cNSl8Ztae++GY+7pLwaPckTHnt84P2HNoEGpH4cM8FA94mZ+PyHLpZ/iwd2f4x3vNGcgg9zklk2+oqH5pqG7F1Vo9qaHjf7bsW39BXu5TaiOigPpBo2A6hseJtEunYpwlIX98AyVYKTw==
DCE=eWOymurvrYcLCy6SQJwFRHzLydolWbrE5ZoL/mtcPX2gA1zy96+Bz7aSE1amMZHutcOUJALSYiG1Y4MzovCyeoHFGpwGqK+Unamnsy20sTrRa7hCzgWvST62/IBfeBDYDpq1cQ7dd7JMUjsYhe5u9o6I7UKbjr5ELw==
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..005A0AC10375F34408F5F0748B9F5D75FE1 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' trat auf während der Übertragung des SCSI-Befehls AD010..080002400 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..032660202B1F6761484D96B5A7247B5F359 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0C7515267D2FC4D410FAF276A7CF1496DDE zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..04C7ABADA305906E2F4ED8F656C2FE666E7 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..085217BFF7877073362430715789C46C9F9 zu Laufwerk 'SPTI:\Device\CdRom1'
DCE=JqTNkQ6+/q7NlBWQqMlyw5NSkeIGgDbKgFTr01qsJwUEaTLcx9KdUbVLmXzFo08ytiwXGslJQXr8ZNSaSO0Y49LgxGdRruQ5GACuy1IPY5GnVFNO4b3+QiejlELBuVKjWsc6iBw5ql1KYWlgQbudiktk0pi/cCkB2A==
DCE=83q66dh0mOrTE0tqA/F4F8Zu0qYkDkcW6EiE/2r0DjA6Rg/XInuDOFr5DdX4jQFp01cyH2Usz4AbY7LGgcwamvCFFaS9GYs1CRwog88RwTlK4AahnA8qiE5sXoG4kWMdJQc4vt/Bg8aVUHHzXMMl7gSf5Dp8CuhaVA==
DCE=zGz1TehHpIDuVOAhSlu/iITyI2RUPV+MtCynhHUlTQaVmK0LP+9e/RMk/N3miTxYiuYOoLlFrXI0/fEmuYTWmFrm2LmoFVj4uvPmMaULex/lKV/q6IlsWzUhx9h3I+5NWef5pTwBEoxk9kOxzDYuzaLsxurXs2c5aA==
DCE=b5Pk1EhGNVPnvs0TtLN32dpTRlGiU2/h35QyB8yjYqyJwTU7IHfhT3W34DUowMIviYpAN4KBnkbIbmXpmrOLFd/7FJhl62VqU3JRk3Zty2s9OAbS7w5m0q9N+8XjxWCpSLYJmLJWMWN7wj+FLV0RaBy947tdJmLnsQ==
DCE=j+vEK5Bum76PWmpYen9twj60aKIdan3H67dTt+8E9rryt+xmJXi6W0DaSHusRfJ2PG+tumP9ri6oBAw7+u3DnXnxJp4sEcDFsXnGCLsZhmboib2t8pa+LGmgTURFkQ6SrtznvjkVFMmPZtrPzaGx1TW2d6F2KZVZ+g==
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0CBEE4A026D11D5E9EAC56639B3341BF6E2 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..054C91223417C6C061C3227044D3BF801A8 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..06C52FB138BF4FA5E0056A16BC293909C33 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0D99B670DEA870A20337850359CBDD9BA60 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0E1C3A998DEC95994FD19EE68BE513F81BE zu Laufwerk 'SPTI:\Device\CdRom1'
003306:0000 AACS-VID kann nicht gelesen werden - höchstwahrscheinlich wird das AACS-Hostzertifikat durch Ihr Laufwerk aufgehoben
003338:0000 Lade aktuelle HK in C:\Users\PiusK/.MakeMKV ...
003332:0000 AACS Ausgabedatei als file://C:\Users\PiusK/.MakeMKV/MKB_v78_BLU-RAY_3A08.tgz gesichert
003303:0000 Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
DEBUG: Code 0 at 6o}7w.Puikol{)H3:213132721
DEBUG: Code 0 at 6o}7w.Puikol{)H3:213131341
005010:0000 Das Öffnen der Disk schlug fehl
DAFD=PAAAADAAAAEEBDQgEHwECAQ==
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0179FCF489ABE933DE8A8634894317EAA0B zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0BB72A1B99001B8298494684B4C4456A909 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0E3EF001C34EC35EA3ABC45EB57C2DC36B2 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0CE88985F5A3A40D074C054F557BE0C8CED zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..08136EE4B03271456095B3E9921969DBFB6 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0072EFC4E59C745820E47FA581CA454EBAC zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0B2141350C4DDC9264123F7AB049176F568 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0659E6212687FF4259876F982A02AA9469F zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0E070CB00D7B846BD1D110D388FFB6D840F zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..081661E55BCF124E09AE809610CCC999F83 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..03DC96D3415597ABDAD2AF5FC9214288192 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..05713AE1DABC8E0B0753BC10859493CBF85 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..01BB41352760978834E9ECACED41A8A95CC zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0FFEDBA9ACDB8533017218DC1593FD13C6B zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..09EF8AADA72D54B7223E04E767F66C1E06D zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..01FEF8A41894BC6BF1A0F8C9646400FF5C8 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..01150F929F73CC87EC754764B8426860D66 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0F7F4D3C8132C79FAD177DEAFBFC0913CAF zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0889DCD5D4807D5B506A36025E64C526236 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..03BBE43FA63CE5513A211BBF8056374458F zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..02DFB1752C91728AF80E471B90C1B8424DB zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:INVALID FIELD IN CDB' trat auf während der Übertragung des SCSI-Befehls AD010..080002400 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0BE6901C5608BF0CBC97723000C8C11632A zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0C9E72B30C80A30CD19EA766E80953B2C05 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0EF20D5D9CC72225206946384A64E90439A zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0BCB1B85E1E7A618DEA8DD14E22B8F21458 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0083D92F5AB9C2FD2030B095C0CD704F06C zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..090C860809203846BC35A1185E6E8F9AC33 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..092730819264B02CB4EDB067FE35346EF01 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0FA96ACB1B33F13BF848189835DDE8A259E zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0ABDF9C43357B6557BD3659810E88BB6F3D zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..025B00223F82B9EEFD45C96A6EB0EE0D78A zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0F7406055AB81CBF1A0AB4BA544A2549810 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0B696695CCE58C06B127221E4E6BCE0AE53 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..01253DBACF5215797F9D4488CC2D13CFC8D zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..040FF0D1A636D181BD2E665D8EDCA4A1F59 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0DC767B96A03EA5DFCF1657712DA0E9D5AE zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..01A5F2AD9EA4CCA956D7DD87B8D64162523 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0EEE2152B4178949B36DB80C358AD95D942 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..077E8D0662FEF2EC7189ECCCB88007F0252 zu Laufwerk 'SPTI:\Device\CdRom1'
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' trat auf während der Übertragung des SCSI-Befehls A30..00200740100720..0CDA8B73CDC73325EB6384928E546377137 zu Laufwerk 'SPTI:\Device\CdRom1'
DCE=2T3TP3UMN/eQGTDXwtVGCsCRYQ5sc/ZDc6Gq4lgj7/DbNRn4Zpq1KmSzdqVBpYrH6Eex/IHe+wfsAgtghP5iQXU99KgjpUtPOne+GzpiF7LOGBh2x/INlcF55178+Fx7alGemHpBjrvDXiTsybAdV6+v4r4P0DoxHQ==
DCE=vwKF047g7PjVRXPZUFwKVMI1FuFsMtZo632W3UvyRbhNPg9fVxSinw8yHcptadNLQ9P4CboDR7YAc1mEVAwPqqnO6pndyvuFh/t0oSKSG4ZwdokayGINZ/fH8xdCwPJiJKda8MAa7NC2v8YgE4X1jlOJsp1O50QoCg==
DEBUG: Code 117506188 at XLZy#@p!6m/^{4B`f):121263429
DEBUG: Code 117506188 at XLZy#@p!6m/^{4B`f):121262302
002003:0000 Fehler 'Interner Fehler - Vorgang wurde abgebrochen (140)' trat auf während des Auslesens von 'BD-RE TSSTcorp BDDVDW SE-506BB TS00 R90K6YWD700GCR' bei Offset '2490368'
002003:0000 Fehler 'Interner Fehler - Vorgang wurde abgebrochen (140)' trat auf während des Auslesens von 'BD-RE TSSTcorp BDDVDW SE-506BB TS00 R90K6YWD700GCR' bei Offset '2535424'
002003:0000 Fehler 'Interner Fehler - Vorgang wurde abgebrochen (140)' trat auf während des Auslesens von 'BD-RE TSSTcorp BDDVDW SE-506BB TS00 R90K6YWD700GCR' bei Offset '7340032'
002003:0000 Fehler 'Interner Fehler - Vorgang wurde abgebrochen (140)' trat auf während des Auslesens von 'BD-RE TSSTcorp BDDVDW SE-506BB TS00 R90K6YWD700GCR' bei Offset '3538944'
002003:0000 Fehler 'Interner Fehler - Vorgang wurde abgebrochen (140)' trat auf während des Auslesens von 'BD-RE TSSTcorp BDDVDW SE-506BB TS00 R90K6YWD700GCR' bei Offset '3584000'
002003:0000 Fehler 'Interner Fehler - Vorgang wurde abgebrochen (140)' trat auf während des Auslesens von 'BD-RE TSSTcorp BDDVDW SE-506BB TS00 R90K6YWD700GCR' bei Offset '8388608'
DEBUG: Code 2264989754 at {B4,;}lC\XBZ1{jC$:213133848
Re: Didier (1965)
Those errors typically mean the drive was unable to correctly read the optical disc. The standard advice is to gently clean the disc and try again.
If you're experiencing rip errors, please read here first
Sheep18
Re: Didier (1965)
Post by Sheep18 »
Did that but with no luck.
