two different blu ray movies unable to rip
ironsniper1
#1 Post by ironsniper1 » Wed Dec 07, 2022 8:04 pm
hey all i have two copies of the movie stir of echoes that refuses to rip and one copy of the movie blade that will get to about 90% or so and fail,
all three discs are clean and undamaged and i have no issues with other discs, i could understand if it was one copy but two copies of the same movie seems a little odd
here is part of the error log and drive info
DEBUG: Code 117506188 at qfmN#a{sFwgf"zj2mo:121263429
DEBUG: Code 117506188 at qfmN#a{sFwgf"zj2mo:121262302
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '749568'
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '755712'
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '761856'
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '768000'
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '774144'
Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '780288'
DEBUG: Code 0 at y)Ry^8yAV]1;).Da:29396092
DEBUG: Code 0 at y)Ry^8yAV]1;).Da:29395172
Product: BDDVDRW CH30N
Revision: AS00
Serial number: K9BDCDI2040
Firmware date: 2113-06-14 14:59
Bus encryption flags: 1E
Highest AACS version: 68
Drive platform: MT1939
Firmware version: 0.AS00S
BD raw metadata read: Partial
Disc Information
Label: LOGICAL_VOLUME_ID
Timestamp: 2007-05-23 13:41:59
Protection: AACS v3
Data capacity: 21.72 Gb
Disc type: BD-ROM
Number of layers: 1
Re: two different blu ray movies unable to rip
#2 Post by Woodstock » Tue Dec 13, 2022 5:32 pm
If ironsniper1 is having the same error at the same place on two disks, I would suspect a mastering error. But that has not been said yet. Different places imply different errors.
ironsniper1
#3 Post by ironsniper1 » Fri Aug 18, 2023 5:22 am
hey all, just thought i would update, still getting the same errors from different discs but most rip just fine, any advice or anything i should try let me know
