fransalas
#8731 Post by fransalas » Thu Aug 17, 2023 11:29 am
Well, it gives me an error
#8732 Post by RESET_9999 » Thu Aug 17, 2023 12:07 pm
ha for XML inputs. You guys should give more info about your input files when you report a problem.
replace lines 8312 and 8313
     "%dovi_tool_path%" generate --xml "%filepath%%filename1%%fileext1%" --canvas-width 3840 --canvas-height 2160 --rpu-out "%output_path%%filename1%_RPU.bin"
	 set RPU="%output_path%%filename%_RPU.bin"
by this
     "%dovi_tool_path%" generate --xml "%filepath1%%filename1%%fileext1%" --canvas-width 3840 --canvas-height 2160 --rpu-out "%output_path%%filename1%_RPU.bin"
	 set RPU="%output_path%%filename1%_RPU.bin"
or wait for the next beta.
fransalas
#8733 Post by fransalas » Thu Aug 17, 2023 12:12 pm
ok, thanks, I'll wait for you, use previous versions..
thank you so much
Lapihin_A
#8734 Post by Lapihin_A » Thu Aug 17, 2023 12:18 pm
Hi @RESET_9999! I re-downloaded the original release of After Earth 2013 BCORE with Color range: Full, it plays the same as Limited (after changing the flag) i.e. the movie is dark, although when comparing screenshots (6-8-3) it looks normal. Is there any way to make the movie play with Color range: Limited?
Dune HD Real Vision 4K playback device.
#8735 Post by RESET_9999 » Fri Aug 18, 2023 1:35 am
yep, I've compared HDR10/DV to the MA version, and the BCORE definitely looks crushed/wrong. Not sure if there's anything we can do about it.
thirdmoon
#8736 Post by thirdmoon » Sat Aug 19, 2023 4:40 am
@RESET_9999
Using 3-1 in 1.9.1.5 beta
Input Martian.mov and for cutscenes hdr10plus.json generated in DaVinci
#8737 Post by RESET_9999 » Sat Aug 19, 2023 12:31 pm
@RESET_9999
It seems, for some reason, the dovi_tool can't generate a rpu from a Resolve hdr10plus json directly but if you just inject the resolve json to an hevc file and then extract it to a new json file, it works.
So either you do that or export a DV XML instead, or you can use my old RPU scene cuts: https://drive.google.com/file/d/15jug36 ... drive_link
quietvoid
#8738 Post by quietvoid » Sun Aug 20, 2023 4:40 pm
Does Resolve not do automatic scene cut detection?
Do you have an example file?
#8739 Post by RESET_9999 » Sun Aug 20, 2023 5:30 pm
Wait, I just tried with a sample (resolve 18.5) and it worked but I'm pretty sure I had a Resolve hdr10plus JSON that I couldn't convert directly to RPU in the past(had to inject/extract again).
He wants to generate HDR10plus in resolve and use the same scene cuts to generate DV with cm_analyze.exe .
@thirdmoon which Resolve version do you use?
#8740 Post by RESET_9999 » Sun Aug 20, 2023 6:47 pm
Ok, strangely I can only reproduce with a full movie.
Original resolve json throws an error but if I inject and then extract it, no more error. The hdr10plus_tool json filesize is also much smaller.
files: https://drive.google.com/drive/u/1/fold ... LhERrp1rL0
thirdmoon
#8741 Post by thirdmoon » Mon Aug 21, 2023 7:13 am
@RESET_9999 I used 18.5 for HDR10+
I tried generating DV by letting it run for a few min, but DaVinci wouldn't let me export it and gave some error. I ended up generating DV for the entire movie and then used it in 3-1 which worked fine.
But I don't think I can use 3-1 as it takes way too long. I couldn't even finish the full process as it kept getting slower and slower. It was already 4+ hours.
While it takes 30mins in DaVinci.
Comparison of 4K DV vs 1080p + cubic scaling - https://slow.pics/c/kjdYIsBI
I'm pretty happy with the 1080p + cubic scaling result and will stick to it for time being.
Draco1544
#8742 Post by Draco1544 » Mon Aug 21, 2023 5:35 pm
Hi, how I can bake the FEL into the BL. This is included in the @RESET_9999 script ?
chronomac
#8743 Post by chronomac » Mon Aug 21, 2023 6:32 pm
With option 6-2-7, to create heatmaps and gamut visualizations, is there anyway to have the script read a directory full of screenshots instead of dragging and dropping one at a time?
#8744 Post by RESET_9999 » Mon Aug 21, 2023 6:36 pm
Workflow 6-8-4. Input a mkv file and the script will automatically export heatmaps and gamut png for 50 frames. You can change the number of frames to export at line 76 in the latest beta.
set frame_number=50
6-9-2 in the latest beta
chronomac
#8745 Post by chronomac » Mon Aug 21, 2023 10:07 pm
set frame_number=50
What's the maximum number you can use?
