valington
Post by valington »
RESET_9999 wrote:
Tue Aug 15, 2023 2:04 pm
Gatorman wrote:
Tue Aug 15, 2023 12:02 pm
CM_analyze took just over 15 hours. Perhaps it's just my setup?
How do I export the Resolve Scenecut data?
CUDA 9.0.2
I dont know, it takes about the same time as resolve on my end. rtx3070 + i9 13900ks
I noticed that if you touch your PC while analyzing, it gradually gets slower and can take hours.
In resolve, you import the prores file, do the DV analysis for just 1 frame, do the scene cut detection and export the XML.
The XML will have static metadata but it doesn't matter because we only want the scene cut file.
Reset may be you just could do one programm without drag and drop which don t work in any cases in windows 11 , here in makemkv we had one programm from grincola which work without darg and drop but this programm dont work with mkv 7 profile dolby vision and don t do subtitles
valington wrote:
Tue Aug 15, 2023 4:05 pm
drag and drop works just fine on Windows 11 and I already told you how to fix your problem here: viewtopic.php?p=138327#p138327
valington
Post by valington »
RESET_9999 wrote:
Tue Aug 15, 2023 4:22 pm
But this don t work
valington wrote:
Tue Aug 15, 2023 6:19 pm
But this don t work
yes, it works. My own PC is on Windows 11.
Change back your Windows security settings to default and reboot.
Gatorman
Post by Gatorman »
@RESET_9999
Will (3-1) work with variable L5 videos?
More reasons to collect physical media. 2019 Shield TV Pro.
Gatorman wrote:
Wed Aug 16, 2023 12:03 am
@RESET_9999
I'm not sure but I don't think so.
FYI, in the next version, there will be an option to force the CPU for CM_analyze. It is slightly slower than with the cuda GPU but it seems more stable on speed.
Gatorman
Post by Gatorman »
Nice! That will be useful. Perhaps better for those without Nvidia GPUs. I haven't done enough testing, but I've run 2 videos thru (3-1) where I created the prores file with StaxRip and the time to generate the RPU is far more reasonable. The time to complete only goes down, it doesn't climb.
djanvi2020
Post by djanvi2020 »
can someone remind me,
is there a way you can up the quality of the DD+ when you use MP4 Workflow cause 128kbps doesn't seem sufficient enough?
djanvi2020 wrote:
Wed Aug 16, 2023 9:00 am
it's 128 per channel so 1024kbps total which is the maximum allowed by DEE and EAE for a coreless EC3
Gatorman wrote:
Wed Aug 16, 2023 2:08 am
it was already falling back to the CPU when no GPU was detected.
In the next version, I'll use madvr for the scene cuts so Resolve wont be needed anymore (except for dynamic L5)
dividingelves
Post by dividingelves »
Hi guys,
First of all thanks RESET_9999 for the script.
With the option 7-1-1 I get the following error and I don't know why.
Error parsing command line!
[Importer] Cannot load filter for input file "M:\DoVi_Scripts_TOOLS\TEMP_folder\1.mp4"
Failure while importing import: Requested URL is not valid or cannot be found
Error importing M:\DoVi_Scripts_TOOLS\TEMP_folder\1.mp4#1: Requested URL is not valid or cannot be found
2023/08/16 23:16:42 failed processing file M:\DoVi_Scripts_TOOLS\Avatar2022.mkv: cannot open file "M:\DoVi_Scripts_TOOLS\Avatar2022.mkv": open M:\DoVi_Scripts_TOOLS\Avatar2022.mkv: The system cannot find the file specified.
the script has completed...
                        _____    __      ___       _____           _       _
                       |  __ \   \ \    / (_)     / ____|         (_)     | |
                       | |  | | __\ \  / / _     | (___   ___ _ __ _ _ __ | |_ ___
                       | |  | |/ _ \ \/ / | |     \___ \ / __| '__| | '_ \| __/ __|
                       | |__| | (_) \  /  | |     ____) | (__| |  | | |_) | |_\__ \
                       |_____/ \___/ \/   |_|    |_____/ \___|_|  |_| .__/ \__|___/
                       -@RESET_9999---------------------------------|__|-----------
 Choose a mode...
1) MODE.I=  DoVi Inject/Convert/Edit/Re-sync TWO INPUTS (P8 Hybrid maker/Injector)
2) MODE.F=  DoVi Fix/Edit/Extract/Verify/Info ONE INPUT
3) MODE.H=  DoVi Maker from HDR10 (Dolby Algo or madVR or HDR10plus)
4) MODE.P=  DoVi Profile 7 Input (MKV/BDMV)
5) MODE.B=  Dovi Batch Muxer
6) MODE.M=  MIXED: Plot/Audio/Screenshots/Remove/Player/Encoder and more...
7) MODE.M4= MP4 Workflows
8) Exit
Choice? [1,2,3,4,5,6,7,8]?7
                                           * CHOOSE A MODE *
1) MODE.1= Single-Track output (FAST mp4box/iOS/Sony & newer LG TVs)
2) MODE.2= Single-Track output (SLOW Old mp4muxer for older LG TVs)
3) MODE.3= Dual-Track output (p7)
4) MODE.4= Demuxer (p5, p8, p7)
5) MODE.5= Davinci Resolve ready files maker
6) MODE.6= back to main menu
Choice? [1,2,3,4,5,6]?1
                                         * CHOOSE A WORKFLOW *
-- Dont use these workflows for older LG TVs (EG. C9 or older). Use (7-2) instead
1) Workflow.1= MKV/HEVC/TS/M2TS input + AC3/EC3
2) Workflow.2= MKV/HEVC/TS/M2TS input + PCM
3) Workflow.3= Bluray Disc to Profile 8 + AC3/EC3
4) Workflow.4= Bluray Disc to Profile 8 + PCM
5) Workflow.5= Batch muxer (up to 13 videos/audio/srt.subs)
6) Workflow.6= back to main menu
-- Input can be P5-P7-P8-HDR10plus-HDR10 HEVC/H265/MKV/TS/M2TS - SRT/AC3/EC3/AAC/DTS/DTSHD/THD
-- If input doesnt have Dynamic Metadata(DV or HDR10+), it will use madVR to generate it.
-- If input has lossless audio, DDP 1536kbps will be encoded.
  Drag and drop your DoVi video file and press enter...
"\\nas\movies\Avatar\Avatar2022.mkv"
Do you want to create a fake P5 mp4? y or n default=n
n
Sorting the input tracks format/id/language...
done.
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Extracting track 1 with the CodecID 'A_TRUEHD' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A1.thd'. Container format: TrueHD
Extracting track 2 with the CodecID 'A_AC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A2.ac3'. Container format: Dolby Digital (AC-3)
Extracting track 3 with the CodecID 'A_EAC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A3.ac3'. Container format: Dolby Digital Plus (E-AC-3)
Extracting track 4 with the CodecID 'A_TRUEHD' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A4.thd'. Container format: TrueHD
Extracting track 5 with the CodecID 'A_AC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A5.ac3'. Container format: Dolby Digital (AC-3)
Extracting track 8 with the CodecID 'S_TEXT/UTF8' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\S8.srt'. Container format: SRT text subtitles
Extracting track 15 with the CodecID 'S_TEXT/UTF8' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\S15.srt'. Container format: SRT text subtitles
Progress: 100%
ffmpeg version 6.0-full_build-www.gyan.dev Copyright (c) 2000-2023 the FFmpeg developers
  built with gcc 12.2.0 (Rev10, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      58.  2.100 / 58.  2.100
  libavcodec     60.  3.100 / 60.  3.100
  libavformat    60.  3.100 / 60.  3.100
  libavdevice    60.  1.100 / 60.  1.100
  libavfilter     9.  3.100 /  9.  3.100
  libswscale      7.  1.100 /  7.  1.100
  libswresample   4. 10.100 /  4. 10.100
  libpostproc    57.  1.100 / 57.  1.100
Input #0, truehd, from 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A1.thd':
  Duration: N/A, start: 0.000000, bitrate: N/A
  Stream #0:0: Audio: truehd, 48000 Hz, 7.1, s32 (24 bit)
Stream mapping:
  Stream #0:0 -> #0:0 (truehd (native) -> eac3 (native))
Press [q] to stop, [?] for help
Output #0, matroska, to 'M:\DoVi_Scripts_TOOLS\TEMP_folder\EC3.1.mkv':
  Metadata:
    encoder         : Lavf60.3.100
  Stream #0:0: Audio: eac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.0(side), fltp, 1536 kb/s
    Metadata:
      encoder         : Lavc60.3.100 eac3
size= 2174999kB time=03:12:53.13 bitrate=1539.6kbits/s speed=74.8x
video:0kB audio:2169966kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.231956%
Extracting track 0 with the CodecID 'A_EAC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A1.ec3'. Container format: Dolby Digital Plus (E-AC-3)
Progress: 100%
Output #0, mp4, to 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A1.mp4':
  Metadata:
  Stream #0:0: Audio: truehd (mlpa / 0x61706C6D), 48000 Hz, 7.1, s32 (24 bit)
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
size= 7441180kB time=03:12:53.14 bitrate=5267.2kbits/s speed=13.4x
video:0kB audio:7386366kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.742098%
Input #0, truehd, from 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A4.thd':
Stream mapping:
  Metadata:
    Metadata:
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 6a.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated d8.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 2b.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated f7.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 74.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated ac.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 52.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 0e.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated ab.
[truehd @ 000001f3e7ab5d80] quant_step_size larger than huff_lsbsx
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 6b.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 0a.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated ea.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 9a.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated e5.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated f3.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 79.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 46.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 5f.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 60.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 34.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated f2.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 59.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated d3.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated fa.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 55.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated c1.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 8a.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated 13.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated b6.
[truehd @ 000001f3e7ab5d80] Lossless check failed - expected 00, calculated ba.
size= 2171433kB time=03:12:34.15 bitrate=1539.6kbits/s speed=75.9x
video:0kB audio:2166408kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.231956%
Extracting track 0 with the CodecID 'A_EAC3' to the file 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A4.ec3'. Container format: Dolby Digital Plus (E-AC-3)
Progress: 100%
Output #0, mp4, to 'M:\DoVi_Scripts_TOOLS\TEMP_folder\A4.mp4':
  Metadata:
Stream mapping:
size= 6853036kB time=03:12:34.17 bitrate=4858.9kbits/s speed=12.5x
video:0kB audio:6798322kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.804821%
muxing into a MP4 DoVi file. Be patient, it can take a while. 40min+ on slow HDD!
thirdmoon
Post by thirdmoon »
@RESET_9999
In the next version can we have 3-1 take prores input. For now it starts converting to prores even if the input is prores.
thirdmoon wrote:
Thu Aug 17, 2023 6:52 am
@RESET_9999
seems fine in the latest beta?
fransalas
Post by fransalas »
in the latest beta of dovi_scrit the command 6-2-3- does not extract the plot.png or the rpu, thank you very much for everything in advance
fransalas wrote:
Thu Aug 17, 2023 11:18 am
mm yes it does, I just tried the mkv and ts version.
