Suggestions on a drive?
Simplywolf
Post by Simplywolf »
Trying my best to rip a few of my Blu rays so that I can take them on a road trip with me. Non of them are UHD and I'm not looking for a fancy drive or anything. Is there any suggestions for a cheep USB Blu ray drive that just works?
Re: Suggestions on a drive?
i recommend a pioneer but if you want cheap the BP50/wp50 can be gotten for $80-$90 and they are ok
Simplywolf
Billycar11 wrote: Tue Aug 15, 2023 5:45 pm i recommend a pioneer but if you want cheap the BP50/wp50 can be gotten for $80-$90 and they are ok
I keep seeing the ones on Amazon for 50/60 bucks, will those work just to rip regular Blu rays or will there be problem with using them?
Simplywolf
Do the cheep ones on Amazon work?
Simplywolf wrote: Tue Aug 15, 2023 7:47 pm Do the cheep ones on Amazon work?
yeah they work but for future UHD capability it might be worth the extra $20 now than spending 60 now and then 80 more in a few years if you want UHD but thats up to you
almost any drive works with makemkv for regular bluray and dvd only a special drive is needed for UHD
