Gatorman
#8701 Post by Gatorman » Sun Aug 13, 2023 7:21 pm
(3-1)
@RESET_9999
When using the updated script (3-1), do I need to generate a shot list file before running the script? At the moment if I just press enter, when prompted for the shot list, the script crashes after L5 input.
#8702 Post by RESET_9999 » Sun Aug 13, 2023 7:48 pm
oops, I forgot to test the frame-by-frame options after I added external shot list support. Will fix in the next version.
Gatorman
#8703 Post by Gatorman » Tue Aug 15, 2023 2:19 am
Does (3-1) typically take hours to complete?
2700X - RTX 3070
#8704 Post by RESET_9999 » Tue Aug 15, 2023 3:29 am
if you dont provide a shot list file, yes the scene cuts detection takes forever.
You can use scene cuts from resolve and do the DV in CM_analyze.
Gatorman
#8705 Post by Gatorman » Tue Aug 15, 2023 12:02 pm
CM_analyze took just over 15 hours. Perhaps it's just my setup?
How do I export the Resolve Scenecut data?
CUDA 9.0.2
#8706 Post by RESET_9999 » Tue Aug 15, 2023 2:04 pm
Gatorman wrote: Tue Aug 15, 2023 12:02 pm CM_analyze took just over 15 hours. Perhaps it's just my setup?
CUDA 9.0.2
I dont know, it takes about the same time as resolve on my end. rtx3070 + i9 13900ks
I noticed that if you touch your PC while analyzing, it gradually gets slower and can take hours.
In resolve, you import the prores file, do the DV analysis for just 1 frame, do the scene cut detection and export the XML.
The XML will have static metadata but it doesn't matter because we only want the scene cut file.
valington
#8707 Post by valington » Tue Aug 15, 2023 4:05 pm
RESET_9999 wrote: Tue Aug 15, 2023 2:04 pm
CUDA 9.0.2
Reset may be you just could do one programm without drag and drop which don t work in any cases in windows 11 , here in makemkv we had one programm from grincola which work without darg and drop but this programm dont work with mkv 7 profile dolby vision and don t do subtitles
#8708 Post by RESET_9999 » Tue Aug 15, 2023 4:22 pm
valington wrote: Tue Aug 15, 2023 4:05 pm Reset may be you just could do one programm without drag and drop which don t work in any cases in windows 11 , here in makemkv we had one programm from grincola which work without darg and drop but this programm dont work with mkv 7 profile dolby vision and don t do subtitles
drag and drop works just fine on Windows 11 and I already told you how to fix your problem here: viewtopic.php?p=138327#p138327
valington
#8709 Post by valington » Tue Aug 15, 2023 6:19 pm
RESET_9999 wrote: Tue Aug 15, 2023 4:22 pm
But this don t work
#8710 Post by RESET_9999 » Tue Aug 15, 2023 6:24 pm
valington wrote: Tue Aug 15, 2023 6:19 pm But this don t work
yes, it works. My own PC is on Windows 11.
Change back your Windows security settings to default and reboot.
Gatorman
#8711 Post by Gatorman » Wed Aug 16, 2023 12:03 am
@RESET_9999
Will (3-1) work with variable L5 videos?
#8712 Post by RESET_9999 » Wed Aug 16, 2023 1:09 am
Gatorman wrote: Wed Aug 16, 2023 12:03 am @RESET_9999
I'm not sure but I don't think so.
FYI, in the next version, there will be an option to force the CPU for CM_analyze. It is slightly slower than with the cuda GPU but it seems more stable on speed.
Gatorman
#8713 Post by Gatorman » Wed Aug 16, 2023 2:08 am
Nice! That will be useful. Perhaps better for those without Nvidia GPUs. I haven't done enough testing, but I've run 2 videos thru (3-1) where I created the prores file with StaxRip and the time to generate the RPU is far more reasonable. The time to complete only goes down, it doesn't climb.
djanvi2020
#8714 Post by djanvi2020 » Wed Aug 16, 2023 9:00 am
can someone remind me,
is there a way you can up the quality of the DD+ when you use MP4 Workflow cause 128kbps doesn't seem sufficient enough?
#8715 Post by RESET_9999 » Wed Aug 16, 2023 10:43 am
djanvi2020 wrote: Wed Aug 16, 2023 9:00 am can someone remind me,
it's 128 per channel so 1024kbps total which is the maximum allowed by DEE and EAE for a coreless EC3
