I didn't realize it may had todo with an issue with ffmpeg itself, anyways, I have been using a newer ffmpeg version
The first is the one you linked to, the second is the one I've been using.
C:\Users\Andreas\Downloads>ffmpeg -v
ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 11.2.0 (Rev7, Built by MSYS2 project)
C:\Users\Andreas\Downloads>D:\Video\tools\ffmpeg-5.1\ffmpeg.exe -v
ffmpeg version 5.1-essentials_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 12.1.0 (Rev2, Built by MSYS2 project)
and i had to add this option to get the 5.1 output instead of 5.0.
Ill try with 5.0.1 and see what happens. If there was an issue fixed, maybe they broke it again with a more recent change.
Hi @RESET_9999! Was taken After Earth 2013 BCORE movie with Color range: Full and after changing to Limited using ffmpeg has no effect, screenshots are created with Color range: Full (dark), when playing the movie is also dark. Is there any way to fix it?
really excited about this tool,
registered to get some help.
i got an error on the:
4) MODE.P= DoVi Profile 7 Input (MKV/BDMV) -
-2) MODE.2= MKV/TS/M2TS/MP4 Profile 7 rip to Profile 8
Rewriting file with interleaved EL NALUs..
error: a value is required for '--input <input>' but none was supplied
TSMUXER still opened and a HEVC p8 file was created.
the created file is 6GB smaller than the original with the exact same tracks.
what input am i missing?
how critical is this error? can I ignore it?
@RESET_9999
code output:
@RESET_9999
code output:
WARNING!
OS drive output path(C:\) detected, some function are now restricted and some workflow might not work properly...
Put the script folder on a non-OS drive...
_____ __ ___ _____ _ _
| __ \ \ \ / (_) / ____| (_) | |
| | | | __\ \ / / _ | (___ ___ _ __ _ _ __ | |_ ___
| | | |/ _ \ \/ / | | \___ \ / __| '__| | '_ \| __/ __|
| |__| | (_) \ / | | ____) | (__| | | | |_) | |_\__ \
|_____/ \___/ \/ |_| |_____/ \___|_| |_| .__/ \__|___/
-@RESET_9999---------------------------------|__|-----------
Choose a mode...
1) MODE.I= DoVi Convert/Edit/Sync/Inject two inputs (P8 Hybrid maker)
2) MODE.F= DoVi Fix/Extract/Info/Edit/Verify one input (doesn't convert the profile)
3) MODE.H= DoVi Maker (from HDR10 madVR or HDR10plus)
5) MODE.B= Dovi Batch Muxer
6) MODE.M= MIXED: Remove/Measure/Plot/Audio/Player and more...
7) MODE.M4= MP4 Workflows
8) Exit
Choice? [1,2,3,4,5,6,7,8]?4
* CHOOSE A MODE *
1) MODE.1= Bluray Disc to Profile 8 or ST Profile 7
3) MODE.3= MKV/TS/M2TS/MP4 Profile 7 ST-DL rip to DT-DL
4) MODE.4= Back to main menu
Choice? [1,2,3,4]?2
--This workflow will convert P7 MKV to profile 8 and can convert THD to THDac3 and to DD+
--If input is dual track dual layer, the script expect track 3 to be coreless THD
--Will mux to TS unless you disable it
Drag and drop a P7 MKV file and press enter...
C:\Users\Administrator\Desktop\New\testname.mkv
* INPUT INFO *
--> L5 Left offset: 0
--> L5 Right offset: 0
--> L5 Top offset: 42
--> L5 Bottom offset: 42
--> DoVi Profile: FEL
--> L2 trims: YES (100nits) (600nits) (1000nits)
--> DoVi source min_pq: 1 nits
--> DoVi source max_pq: 1000 nits
--> HDR10 BL input MDL: "min: 0.0001 cd/m2, max: 1000 cd/m2"
Do you want to edit L5... y or n ? and/or press enter...
N
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'C:\Users\Administrator\Desktop\dovitools_install\TEMP_folder\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
converting and injecting RPU...
For more information, try '--help'.
error: the following required arguments were not provided:
--input <input>
<input_pos>
Usage: dovi_tool.exe info --summary --input <input> <input_pos>
Strangely for this movie, the color must be kept to full range... BCORE WEB-DLs are very strangely made.
see limited vs full BCORE vs Movies Anywhere limited: https://slow.pics/c/AYffaiUm
EDIT: added P5 comparison: https://slow.pics/c/SYrdfpeN
The new hevc is ok and can be muxed.
The error at the end is the script trying to read an RPU that is not present. It's my fault and I'll fix it in the next version but right now you can ignore it or put the script folder on a non-windows drive.
The file is 6gb smaller which is normal because this workflow converts dual layer FEL to single layer profile 8. FEL alone can be 15gb+.
hello:
Your scripts very easy to use with Windows OS.
your free time and discretion, have a Deb version ?.
My Windows PC messed up.
I would love to install on Ubuntu, Wine does not work well.
Thanks for the 600 rpu(s) you gave me access to a few months ago..
My files are all in mkv container.
Thanks.
George
Thanks.
George
No sorry this won't happen, I have no desire in making the script works on OS that I'll never use.ekpen wrote: ↑Thu Aug 10, 2023 3:06 pmhello:
Thanks.
George
George
George
Hi Reset_9999
I wanted to thank you for your great work and expertise.
and I wanted to ask if you could PM me. To see your video how to convert SDR to HDR.
My workflow is very long and cumbersome. and I think you have a better way. So I thought I'd just ask.
(3-1)
@RESET_9999
When using the updated script (3-1), do I need to generate a shot list file before running the script? At the moment if I just press enter, when prompted for the shot list, the script crashes after L5 input.
@RESET_9999
More reasons to collect physical media. 2019 Shield TV Pro.
oops, I forgot to test the frame-by-frame options after I added external shot list support. Will fix in the next version.
Does (3-1) typically take hours to complete?
2700X - RTX 3070
2700X - RTX 3070
if you dont provide a shot list file, yes the scene cuts detection takes forever.
You can use scene cuts from resolve and do the DV in CM_analyze.
CM_analyze took just over 15 hours. Perhaps it's just my setup?
How do I export the Resolve Scenecut data?
CUDA 9.0.2
CUDA 9.0.2
