Problems with Spider-Man: Into the Spiderverse UHD, no problems with BD version
RangerEnn
Post by RangerEnn » Tue Aug 08, 2023 6:52 pm
Hi everyone. I have recently bought a TechPulse120 drive (HL-DT-ST BD-RE BU40N) to rip some UHD BluRays. It reads normal BluRays perfectly but I'm struggling to remux Spider-Man: Into the Spiderverse (UHD). The edition I bought comes with a UHD and BD versions in the same box (also comes with extras in a third disc). I have successfully remuxed the BD version but the UHD version is giving me hard time.
There's a post in this forum from a member having trouble with the same film, and although it seems like a similar problem. the error present in the log seems very different from mine. I have already submitted a copy of the dump.tgz to MakeMKV support email, but wanted to ask if someone stumbled with the same problem and knows its cause.
Here's a summary of the log (ommited some repeated lines because of character limit):
MakeMKV v1.17.4 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Downloading latest HK to C:\Users\EnricRyzen-PC/.MakeMKV ...
Saved AACS dump file as C:\Users\EnricRyzen-PC/.MakeMKV/MKB20_v68_Spider-Man-_Into_the_Spider-Verse_42EF.tgz
Here's my drive information:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.00
Firmware date: 2116-12-20 15:28
Highest AACS version: 68
Firmware version: 1.00
Disc Information
Label: SPIDER-MAN_INTO_SPIDER-VERSE
Timestamp: 2019-01-28 10:20:25
Protection: AACS2.0/C v68
Data capacity: 56.37 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Thank you very much.
Re: Problems with Spider-Man: Into the Spiderverse UHD, no problems with BD version
Post by Billycar11 » Tue Aug 08, 2023 7:13 pm
Hmm that's strange it should work try after a reboot of the drive and PC unplug the drive for at least a min.
And do a full shutdown of the pc
RangerEnn
Post by RangerEnn » Tue Aug 08, 2023 9:31 pm
Hi Billycar11. Thanks for your reply.
Already tried:
- Downgrade to 1.16.5, 1.16.7, 1.17.3.
- Full restart between installations.
- Plugging and unplugging drive between failures.
- Changing java runtime from 17 to 8.
- Installing ccexctractor and configuring MakeMKV to point to it.
Same result every time. My pc is a Ryzen 5800X on an X470 mobo with all its drivers installed. Also tried on my laptop (Dell with i3-1035g1). I'm starting to think that there's something weird with this disc's DRM or a bad interaction with MakeMKV, but I don't know about any free software that could allow me to reach a conclusion about the cause.
The things that both PCs have in common that come to my mind:
- MakeMKV 1.17.4
- Windows 11 latest release.
- Currently Java 8 (not the exact same version but very close).
Is there any way I can test playback a UHD BluRay on Windows 11 without all this DRM circus (HDCP and so)? Thanks.
RangerEnn
Post by RangerEnn » Tue Aug 15, 2023 6:47 am
Ok, found the issue: the enclosure the drive comes with. Getting the drive out and connecting it via miniSATA-USB allows MakeMKV to access with LibreDrive mode, thus allowing decryption of the drive. What in the actual heck TechPulse120, why you do this?
I'll try flashing the drive to 1.03MK, but I suspect it will have no effect since the problem resides between the drive and the PC.
Thanks a lot for your help, specially you Billycar11, you helped me on multiple posts.
I'll share more info if I get the default enclosure to work.
RangerEnn
Post by RangerEnn » Sun Dec 17, 2023 9:03 pm
I said that I would post an update if I managed to make the stock enclosure to work. I didn't.
I bought an offbrand USB mini-SATA enclosure and a LG HL-DT-ST BD-RE BU40N. The full set costed almost half as much as the TechPulse120 product and works like a charm.
