I am new to makemkv and ripping in general for Plex. Slowly discovering the amazing world of subtitles haha.
So far, I have run into two types:
1) There is a separate English subtitle track that contains the forced subtitles (either it is labelled as "forced" or just an additional English subtitle track in MKV); or
2) It is burned into the video.
I was searching these forums and came across a possible third type:
"Forced subtitles in a subtitle track and NOT marked as forced".
So I interpret this as there being for example a single English subtitle track, and inside there are English subtitles identified as "forced".
Is this an actual thing? I can't seem to find much information on this. What software can be used to identify if forced subtitles are smooshed into a English subtitle track?
Are there any other ways in which forced subtitles can appear or is that it?
Forced Subtitles within a English Subtitle Track
technoob
Chetwood
Re: Forced Subtitles within a English Subtitle Track
Did you use the search function which should turn up this?
technoob
So your point #3 in that link you sent answers my question - it is possible to have a subtitle track that has the forced subtitles within the subtitle track (meaning they are not a separate track or burned into the video file itself).
How does one extract those out?
technoob
Sorry, I should be more precise in my last reply - Can there be situations of a general track that has forced subtitles but are not flagged? (seems to be what I am asking).
In my experience, I have not run into a situation where 1) forced subtitles are not marked as forced and 2) forced subtitles are commingled with non-forced subtitles and 3) the forced subtitles are not available in a subtitle track by themselves.
I suppose if this were to be the case you could convert the whole thing to a .srt (a text based subtitle format) and delete the non-forced subtitles to get a forced only track.
I have run into situations where forced subtitles are not marked as forced. In these cases there has always been a subtitle track where these subtitles were isolated. This is why I rip all the subtitle tracks in my language.
Chetwood
Same here.
