free alternative to MakeMKV?
Sunoo
Re: free alternative to MakeMKV?
#1 Post by Sunoo » Wed Aug 09, 2023 2:02 pm
I’m deeply confused why you’d come to a forum for MakeMKV to try to find an alternative to that product?
Also, the trial keeps getting renewed, you just need to enter the new key…
#2 Post by Woodstock » Wed Aug 09, 2023 2:05 pm
A lot of people avoid registering MakeMKV by using the beta key, which is issued every couple of months. There might be times when it's expired and a new one hasn't been issued yet, but isn't that worth saving that for the "twice" you're going to use it?
After all, you should have already used up your supposed "twice" you're going to use it, so there shouldn't be a need to replace it.
#3 Post by Billycar11 » Wed Aug 09, 2023 2:07 pm
Makemkv is the cheapest and most consumer friendly ripping software around that supports UHD discs.
Most others have gone to subscription based payments.
Makemkv is still a 1 time payment.
Not only that it's the first with many drive features and firmware and all that is released for free.
I would encourage you to buy makemkv when you can buy it .the developer does make this program free as long as you use the latest beta so it would be wrong for not to share this with you.
viewtopic.php?f=5&t=1053
flojo
#4 Post by flojo » Sat Aug 12, 2023 3:00 am
With a minimal trickery you can perpetually use DVDFab in Windows.
The only thing I wish makemkv had was a hook script that is called before every file ripped but, nothing has that and there's workarounds.
#5 Post by Woodstock » Sat Aug 12, 2023 4:53 pm
Turns out this was just a post to attach spam to. Original poster banned. Leaving the rest of the messages here.
