Super Mario Brothers
irish2010
Post by irish2010 »
I've been trying to rip the retail Super Mario Brothers 4k disc and have been having issues. Below is the error message I'm receiving. This may be some sort of a read issue, but I don't think so as I've tried it with two different discs and both have given me this issue. I've also ripped a half dozen or so 4k discs since first getting a failure on this disc, so I don't think it's my setup either. Any help or suggestions? Thanks!
Saving 1 titles into directory W:/*****/Media/Films/4k UHD
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '23922733056'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '23922733056'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '23922733056'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '23922733056'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '23922733056'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '23922733056'
Failed to save title 0 to file W:/greshamcooney/Media/Films/4k UHD/The Super Mario Bros. Movie (2023)_t00.mkv
Encountered 24 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Re: Super Mario Brothers
Is your drive for reading USB-powered, by chance? If so, make sure it is "fully powered", because the errors you're seeing are consistent with the drive stopping when it tries to go faster than the port can power.
irish2010
Post by irish2010 »
Woodstock wrote:
Sat Aug 12, 2023 4:48 pm
Thanks but no, it's powered separately by an AC adapter. To be sure that wasn't the problem, I also switched the drive to a different outlet to be sure it wasn't something with that outlet being faulty, but no luck. Any other thoughts? Thanks again!
irish2010 wrote:
Mon Aug 14, 2023 12:32 am
then this is only caused by a bad disc or bad drive.
clean the drive laser see if it helps
ploppy5892
Post by ploppy5892 »
I'm having the same issue as OP. I'm using a brand new drive (literally got it in the mail today) and a brand new disc that I just took out of the packaging. Did you ever get this working? The package (Mario Bros. Movie "Power Up Edition") comes with both a 1080p Blu-Ray disc and a UHD disc. I was able to successfully rip the 1080p disc but for the UHD disc I keep getting the following errors:
Hash check failed for file 00294.m2ts at offset 32775530496, file is corrupt.
Hash check failed for file 00294.m2ts at offset 32775923712, file is corrupt.
Too many hash check errors in file 00294.m2ts.
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 32774879232, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 32774879232-32774885376, attempting to work around
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 32774885376, attempting to work around
Here's my drive information:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KL8N8495352
Highest AACS version: 77
Firmware version: 1.02
Disc Information
Label: THE_SUPER_MARIO_BROS_MOVIE
Timestamp: 2023-06-27 18:34:48
Protection: AACS2.0/C v77
Data capacity: 85.30 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
tursiops
Post by tursiops »
Hi all,
I'm actually having the same issue, and the disk can be read fine by my ps5 so i don't think it's the disk fault. I've bought a brand new drive just in case, but getting the same read error.
Anyone else managed to solve this ?
Thank you.
tursiops wrote:
Sat Oct 07, 2023 11:46 am
Hi all,
Thank you.
What drive did you buy?
I recommend pioneers for hard to read discs
tursiops
Post by tursiops »
I bought the ASUS BW-16D1HT/G flashed it good, and indeed managed to read a disc i wasn't able to with my other drive, but this one still is resisting me.
ploppy5892
I bought a WH16NS60. I actually did get this working after a reboot and cleaning the disk. It was BRAND NEW out of the package but somehow had a smudge on it that wasn't from me. Maybe I got a returned copy or something? In any case, I was able to rip the UHD version of Mario!
