Avatar The Way of the Water dump submitted
peter-a
Re: Avatar The Way of the Water dump submitted
Post by peter-a » Fri Aug 11, 2023 8:30 am
polskasubie wrote: Wed Aug 09, 2023 12:13 pm
peter-a wrote: Wed Aug 09, 2023 7:54 am Would anyone happen to have any information on the issue I'm encountering? It's been a month and I still can't rip this video.
Thank you.
you can try these steps as others have had the issue...
viewtopic.php?f=12&t=24711
That link would be more useful if it mentioned the replacement for "hkdata.fairuse.org". Without that information, it's useless for the issue encountered.
Coopervid wrote: Thu Aug 10, 2023 10:23 am There is your problem. Makemkv needs to have Internet access enabled. View - Preferences General. Check the box.
Internet access IS enabled.
Post by Coopervid » Fri Aug 11, 2023 2:10 pm
Then your DNS is blocking Russia. Change your DNS in your Router. Google for options.
peter-a
Post by peter-a » Fri Aug 11, 2023 9:38 pm
Coopervid wrote: Fri Aug 11, 2023 2:10 pm Then your DNS is blocking Russia. Change your DNS in your Router. Google for options.
Nope. I don't have any GeoBlocking turned on.
Does anyone know the DNS name of the current HK server? That would make this process much easier.
Post by Coopervid » Fri Aug 11, 2023 9:46 pm
Your DNS server has geoblocking. Change it, stubborn.
Post by SamuriHL » Fri Aug 11, 2023 10:39 pm
Nobody knows how to do basic networking stuff anymore. You want to see where it's being blocked?
tracert hkdata.fairuse.org
And you will find your answer.
Post by Coopervid » Fri Aug 11, 2023 10:40 pm
You ask for too much Sam.
EDIT: Open a command window. Copy and paste what Sam has posted into the command window. See the trace.
iFrog
Post by iFrog » Fri Aug 11, 2023 10:52 pm
I'm still trying to determine which version of the movie people are having ieeus with here. I posted here when I first got the movie because I was unsure of the correct title, but then I figured it out and gave people the info. However, My copy of Way of Water ripped out of the box with the latest MakeMKV. I did the standard Blu-ray, as I have no reason to rip UHD discs, and just play UHD from disc.
Post by Coopervid » Fri Aug 11, 2023 10:56 pm
Don't hijack if the movie is working for you.
iFrog
Post by iFrog » Fri Aug 11, 2023 11:00 pm
Coopervid wrote: Fri Aug 11, 2023 10:56 pm Don't hijack if the movie is working for you.
That's why I was asking, because it worked for me without issues, wanted to see if I could do anything to help others. However, I wasn't sure which version we're talking about here.
UHD, or Standard BD, or both.
Post by Coopervid » Fri Aug 11, 2023 11:05 pm
Again for peter-a. Open a command line and paste Sam's tracert line. Then you will see where it's stuck.
peter-a
Post by peter-a » Sat Aug 12, 2023 9:57 pm
Coopervid wrote: Fri Aug 11, 2023 9:46 pm Your DNS server has geoblocking. Change it, stubborn.
Despite your claims to the contrary, I have no GeoBlocking enabled in my router. Please don't treat others as though they're clueless just because you can't see past the end of your nose.
SamuriHL wrote: Fri Aug 11, 2023 10:39 pm Nobody knows how to do basic networking stuff anymore. You want to see where it's being blocked?
The documentation linked previously (viewtopic.php?f=12&t=24711) clearly states that HKDATA.FAIRUSE.ORG is no longer used as the Hash Key repository.
However, it can't hurt, so:
PS C:\Users\Peter> tracert hkdata.fairuse.org
Tracing route to hkdata.fairuse.org [185.84.108.20]
over a maximum of 30 hops:
  1     2 ms     2 ms     2 ms  192.168.2.1
  2    38 ms    13 ms    15 ms  142-254-184-093.inf.spectrum.com [142.254.184.93]
  3    30 ms    29 ms    31 ms  lag-63.sndaca8102h.netops.charter.com [76.167.26.213]
  4    19 ms    21 ms    20 ms  lag-25.sndhcaax02r.netops.charter.com [72.129.1.248]
  5    23 ms    19 ms    19 ms  lag-22.tustcaft01r.netops.charter.com [72.129.1.2]
  6    22 ms    20 ms    24 ms  lag-26.tustca4200w-bcr00.netops.charter.com [66.109.3.232]
  7    20 ms    20 ms    22 ms  ae-11.edge1.Tustin1.Level3.net [4.68.111.101]
  8     *        *        *     Request timed out.
  9   197 ms   199 ms   204 ms  EDN-SOVINTE.ear4.Amsterdam1.Level3.net [213.19.197.34]
 10     *        *        *     Request timed out.
 11   206 ms   205 ms   205 ms  195.218.178.138
 12   217 ms   217 ms   215 ms  176.99.137.73.inetcom.ru [176.99.137.73]
 13   213 ms   212 ms   213 ms  majordomo-hosting.weba.ru [37.153.0.97]
 14   211 ms   215 ms   212 ms  web33.majordomo.ru [185.84.108.20]
Trace complete.
PS C:\Users\Peter>
Can we accept that as proof that there's no GeoBlocking in use to the "no longer used" Hash Key repository of HKDATA.FAIRUSE.ORG?
I can also bring the site up as HTTP, but HTTPS returns an error of "ERR_SSL_PROTOCOL_ERROR". If HTTPS is used to retrieve the HKDB, I probably need to enable an older SSL/TLS protocol. Does anyone know the SSL/TLS version actually used for the HKDB download?
Now, back to my previous question. Since this host is "no longer used", does anyone know what the DNS name is for the current Hash Key repository?
Post by Billycar11 » Sat Aug 12, 2023 10:59 pm
peter-a wrote: Sat Aug 12, 2023 9:57 pm Despite your claims to the contrary, I have no GeoBlocking enabled in my router. Please don't treat others as though they're clueless just because you can't see past the end of your nose.
Trace complete.
PS C:\Users\Peter>
none of this matters just because your router does not have geo blocking on does not mean your isp dns does not and thats out of your control.
the domain name is hidden and can be changed for obvious reasons these keys are not meant to be out there that's why they are hidden.
you will just have to bite the bullet and do the troubleshooting steps everyone else is doing changing your dns trying a vpn ect... if you want to use makemkv for UHD ripping there is no special help for this and no exceptions.
viewtopic.php?f=1&t=30460&p=133280#p133280
Post by Coopervid » Sun Aug 13, 2023 12:04 am
Thank you, Billy! I suspect you will not get a thank you from him.
