All the sudden the font in the app is like 4 pitch and unreadable.
I have tried re-installing - no help.
I noticed in the registry there are a few keys referring to the screen (a geometry key and state key).
I have also reset the Windows screen resolution, no help there as well.
See attached image.
Any help would be appreciated - Thanks!
MakwMKV Font Issue
Re: MakwMKV Font Issue
This usually happens when the screen resolution and or scaling changes or monitor turns off. restart your PC and don't change any of that stuff and the scaling should be correct
Yeah, tried all that before I posted - no help.
May have to just uninstall, clean out the registry keys for the app and reinstall.
Last reinstall was just basic through Control Panel.
Guess I need to get a bit more aggressive.
Thanks...
Thanks...
