mkv version 1 6 10 problem with subtitles (to fast)
chimeguy
#1 Post by chimeguy » Sun Jun 12, 2011 6:37 pm
mkv version 1 6 10 problem with subtitles (subtitles are flashing to fast)
sometimes on screen for only 2-5 seconds,. this is bad as I watch a lot of foreign movies!!
I did not have this problem with previous versions. previous I had almost always
ripped the dvd to vob folders first then convert to mkv. 4 movies yesterday I converted
straight from DVD to MKV using version 1 6 10 of make mkv.
Axehandler
Re: mkv version 1 6 10 problem with subtitles (to fast)
#2 Post by Axehandler » Mon Jun 13, 2011 2:39 am
Known issue :)
(Mike : Thanks for this information - indeed, the new 1.6.10 doesn't put duration on subtitle frames. The next version will put duration back. A bug in 1.6.10 .)
chimeguy
#3 Post by chimeguy » Tue Jun 14, 2011 6:18 pm
when will the new version be out? that means I have to re order and re convert 20 DVDs
all foreign film (subtitles not working)
if this was known issues why was it not posted?
setarip_old
#4 Post by setarip_old » Tue Jun 14, 2011 9:53 pm
@chimeguy
Hi!
By "re order", do you mean it's a big deal to put 20 DVDs in a specific sequence - or do you mean something else?
crowfax
#5 Post by crowfax » Tue Jun 14, 2011 10:16 pm
setarip_old wrote:By "re order", do you mean it's a big deal to put 20 DVDs in a specific sequence - or do you mean something else?
Discussion of "something else" isn't appropriate on this forum. So you really shouldn't be asking.
setarip_old
#6 Post by setarip_old » Tue Jun 14, 2011 10:25 pm
@crowfax
Hi!
The OP is certainly entitled to the opportunity to clarify his/her posting, rather than have another member presume to know what he/she means by "re order".
(Perhaps when "mike admin" gets around to implementing formal basic rules for the forum similar and more obvious posts will be reported as rules violations, cumulatively subject to temporary suspension from forum posting)
crowfax
#7 Post by crowfax » Tue Jun 14, 2011 10:28 pm
setarip_old wrote:The OP is certainly entitled to the opportunity to clarify his/her posting, rather than have another member presume to know what he/she means by "re order".
Well colour me confused. Why is it that you need them to clarify their statement in order to help them?
Perhaps I missed something, but that part of their posting appears to have nothing to do with MakeMKV, nor can anyone help them with it. So, I'm confused as to why you, or anyone else, needs it clarifying.
setarip_old
#8 Post by setarip_old » Wed Jun 15, 2011 4:52 am
@crowfax
Precisely because the OP's statement doesn't clearly indicate WHY there is a need to "re order". In life, business, school, and forums, the best way to help a poster, for both present and future questions, is to get the poster to express his/her questions clearly and thoroughly.
That is presumption on your part - and although it may prove to be correct, this won't be KNOWN until/unless the OP clarifies what was meant by "re order"...
BrownRat
#9 Post by BrownRat » Wed Jun 15, 2011 12:27 pm
Are there known issues with Bluray rips made with 1.6.10? I ask for the same reason as the OP.
crowfax
#10 Post by crowfax » Wed Jun 15, 2011 2:42 pm
setarip_old wrote:Precisely because the OP's statement doesn't clearly indicate WHY there is a need to "re order".
Nor did they ask for any help with it.
setarip_old wrote:That is presumption on your part
No it isn't. The only thing they asked was why the bug wasn't posted. It has nothing to do with your line of questioning.
setarip_old
#11 Post by setarip_old » Wed Jun 15, 2011 4:34 pm
@BrownRat
Hi!
After reading through all posts specifically related to full disc Blu-ray backups ("Blu-ray rips" - either encrypted or decrypted) made using MakeMKV v.1.6.10, I've seen nothing to indicate any issues...
Axehandler
#12 Post by Axehandler » Thu Jun 16, 2011 4:38 am
This is setarip_old's way of saying that the OP is POSSIABLY admitting to ordering/renting and ripping movies.. which is not allowed. He honestly should have just stated that instead of beating around the bush like he is doing.
Axe
#13 Post by mike admin » Fri Jun 17, 2011 11:39 am
BrownRat wrote:Are there known issues with Bluray rips made with 1.6.10? I ask for the same reason as the OP.
For subtitles, the frame length is not encoded in MKV metadata ( but obviously is preserved in stream) so players that use MKV metadata flash subtitles too fast.
Seek metadata is written every 2 seconds and DTS-HD/TrueHD non-sync frames are marked as such. In practice that means that some players will take a very long time (~20 sec) to sync after seek.
Actual streams are always preserved correctly. If the file plays for you, then you don't need to worry. If the file doesn't play then remuxing with MMG ( or next version of MakeMKV from MKV file) should fix the file.
