your HDR10 pic is wrong somehow.
it's working just fine and it's the same as MPV on my end so I don't know.
6-8-3: https://slow.pics/c/jVXtSv5Z
MPV:https://slow.pics/c/hmJiiuVO
Yes, I was wrong that the problem is not DV-P5 but HDR, I saw it by taking a screenshot in MPC. After that I tried 6-8-4 option for magic.mike.2012.hdr.2160p.web.h265-slot.mkv and got normal HDR screenshots.RESET_9999 wrote: ↑Sun Aug 06, 2023 6:20 pmyour HDR10 pic is wrong somehow.
My goal is, create a file that works well on old LG and Apple TV.RESET_9999 wrote: ↑Sun Aug 06, 2023 11:42 ambut why use the mp4muxer at all for ATV or new TV (2019+) when mp4box can mux directly lossless audio + subs + chapter?NiCE77 wrote: ↑Sun Aug 06, 2023 8:44 am
Thanks! But I noticed, the --dvh1flag option is not working. This would be necessary for playback on Apple TV (with tvOS 17). Can you fix it?
This solution works until: https://github.com/rixtox/mp4dovi
I had this issue with some newer versions of ffmpeg and I thought it was fixed in the version I use (02-27-2023) right now.
WARNING!
OS drive output path(C:\) detected, some function are now restricted and some workflow might not work properly...
Put the script folder on a non-OS drive...
_____ __ ___ _____ _ _
| __ \ \ \ / (_) / ____| (_) | |
| | | | __\ \ / / _ | (___ ___ _ __ _ _ __ | |_ ___
| | | |/ _ \ \/ / | | \___ \ / __| '__| | '_ \| __/ __|
| |__| | (_) \ / | | ____) | (__| | | | |_) | |_\__ \
|_____/ \___/ \/ |_| |_____/ \___|_| |_| .__/ \__|___/
-@RESET_9999---------------------------------|__|-----------
Choose a mode...
1) MODE.I= DoVi Convert/Edit/Sync/Inject two inputs (P8 Hybrid maker)
2) MODE.F= DoVi Fix/Extract/Info/Edit/Verify one input (doesn't convert the profile)
3) MODE.H= DoVi Maker (from HDR10 madVR or HDR10plus)
4) MODE.P= DoVi Profile 7 Input (MKV/BDMV)
5) MODE.B= Dovi Batch Muxer
6) MODE.M= MIXED: Remove/Measure/Plot/Audio/Player and more...
7) MODE.M4= MP4 Workflows
8) Exit
Choice? [1,2,3,4,5,6,7,8]?4
* CHOOSE A MODE *
1) MODE.1= Bluray Disc to Profile 8 or ST Profile 7
2) MODE.2= MKV/TS/M2TS/MP4 Profile 7 rip to Profile 8
3) MODE.3= MKV/TS/M2TS/MP4 Profile 7 ST-DL rip to DT-DL
4) MODE.4= Back to main menu
Choice? [1,2,3,4]?2
--This workflow will convert P7 MKV to profile 8 and can convert THD to THDac3 and to DD+
--If input is dual track dual layer, the script expect track 3 to be coreless THD
--Will mux to TS unless you disable it
Drag and drop a P7 MKV file and press enter...
C:\Users\Administrator\Desktop\New\testname.mkv
* INPUT INFO *
--> L5 Left offset: 0
--> L5 Right offset: 0
--> L5 Top offset: 42
--> L5 Bottom offset: 42
--> DoVi Profile: FEL
--> L2 trims: YES (100nits) (600nits) (1000nits)
--> DoVi source min_pq: 1 nits
--> DoVi source max_pq: 1000 nits
--> HDR10 BL input MDL: "min: 0.0001 cd/m2, max: 1000 cd/m2"
Do you want to edit L5... y or n ? and/or press enter...
N
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'C:\Users\Administrator\Desktop\dovitools_install\TEMP_folder\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
converting and injecting RPU...
Rewriting file with interleaved EL NALUs..
error: a value is required for '--input <input>' but none was supplied
For more information, try '--help'.
error: the following required arguments were not provided:
--input <input>
<input_pos>
Usage: dovi_tool.exe info --summary --input <input> <input_pos>
Strangely for this movie, the color must be kept to full range... BCORE WEB-DLs are very strangely made.
The new hevc is ok and can be muxed.
