bbeny123
Post by bbeny123 » Sun Aug 06, 2023 11:20 am
NiCE77 wrote: Sun Aug 06, 2023 8:44 am Thanks! But I noticed, the --dvh1flag option is not working. This would be necessary for playback on Apple TV (with tvOS 17). Can you fix it?
This solution works until: https://github.com/rixtox/mp4dovi
Since its introduction, the '--dvh1flag {trackId}' flag has only worked with DV profiles: 1, 3 or 5. I have lifted this restriction.
Version 1.3.3: https://github.com/bbeny123/mp4muxer/releases/tag/1.3.3
Post by RESET_9999 » Sun Aug 06, 2023 11:42 am
but why use the mp4muxer at all for ATV or new TV (2019+) when mp4box can mux directly lossless audio + subs + chapter?
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 3:22 pm
Please share the file "SDR_heatmap.cube".
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 4:42 pm
Hi @RESET_9999! When using the 6-8-3 option with video 1 (HDR10) and video 2 (DV-P5) we get these screenshots, you can see that tonemapping is applied to video 2 (DV-P5).
Post by RESET_9999 » Sun Aug 06, 2023 5:00 pm
Lapihin_A wrote: Sun Aug 06, 2023 4:42 pm Hi @RESET_9999! When using the 6-8-3 option with video 1 (HDR10) and video 2 (DV-P5) we get these screenshots, you can see that tonemapping is applied to video 2 (DV-P5).
unless you're using an older version of the script, the latest ones no longer tonemap to SDR for 6-8-3.
if you're using the latest beta, are you sure it's not just your two sources that are different?
I know some BCORE webdl are incorrectly flagged as a ''full range'' which messes up the black levels.
Lapihin_A wrote: Sun Aug 06, 2023 3:22 pm Please share the file "SDR_heatmap.cube".
https://drive.google.com/file/d/1Ix3JT6 ... drive_link
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 5:10 pm
RESET_9999 wrote: Sun Aug 06, 2023 5:00 pm
I used your script of the latest version of "DoVi_Scripts_1.9.0.2.beta_MKV" at the moment.
SiC's BCORE video was used, which has no contrast problem unlike ROCCaT's BCORE.
General
Unique ID                                : 83590475605974953443278668065443810502 (0x3EE2F0A411F5477A6A2AAA890CB20CC6)
Complete name                            : Escape.Room.2019.2160p.BCORE.WEB-DL.DTS-HD.MA.5.1.HDR.HEVC-SiC.mkv
File size                                : 57.2 GiB
Duration                                 : 1 h 39 min
Overall bit rate                         : 82.2 Mb/s
Frame rate                               : 23.976 FPS
Writing application                      : mkvmerge v13.0.0 ('Sharing is Caring') 64-bit
Writing library                          : libebml v1.0.0 + libmatroska v1.1.1
Video
Format profile                           : Main 10@L5.2@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Maximum Content Light Level              : 3876 cd/m2
Maximum Frame-Average Light Level        : 852 cd/m2
Audio
Format                                   : DTS XLL
Commercial name                          : DTS-HD Master Audio
Channel layout                           : C L R Ls Rs LFE
Bit depth                                : 16 bits
Delay relative to video                  : 2 ms
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Text #2
Format                                   : UTF-8
Title                                    : SDH
Text #3
Format                                   : UTF-8
Language                                 : Arabic
Text #4
Format                                   : UTF-8
Language                                 : Cantonese
Text #5
Format                                   : UTF-8
Title                                    : Simplified
Language                                 : Chinese-cmn-simple
Text #6
Format                                   : UTF-8
Title                                    : Traditional
Language                                 : Mandarin
Text #7
Format                                   : UTF-8
Language                                 : Croatian
Text #8
Format                                   : UTF-8
Language                                 : Czech
Text #9
Format                                   : UTF-8
Language                                 : Danish
Text #10
Format                                   : UTF-8
Language                                 : Dutch
Text #11
Format                                   : UTF-8
Language                                 : Finnish
Text #12
Format                                   : UTF-8
Language                                 : French
Text #13
Format                                   : UTF-8
Language                                 : German
Text #14
Format                                   : UTF-8
Language                                 : Greek
Text #15
Format                                   : UTF-8
Language                                 : Hebrew
Text #16
Format                                   : UTF-8
Language                                 : Hungarian
Text #17
Format                                   : UTF-8
Language                                 : Icelandic
Text #18
Format                                   : UTF-8
Language                                 : Indonesian
Text #19
Format                                   : UTF-8
Language                                 : Italian
Text #20
Format                                   : UTF-8
Language                                 : Korean
Text #21
Format                                   : UTF-8
Language                                 : Norwegian
Text #22
Format                                   : UTF-8
Language                                 : Polish
Text #23
Format                                   : UTF-8
Title                                    : Brazilian
Language                                 : Portuguese (BR)
Text #24
Format                                   : UTF-8
Title                                    : Iberian
Language                                 : Portuguese (PT)
Text #25
Format                                   : UTF-8
Language                                 : Romanian
Text #26
Format                                   : UTF-8
Language                                 : Russian
Text #27
Format                                   : UTF-8
Title                                    : Castilian
Language                                 : Spanish (ES)
Text #28
Format                                   : UTF-8
Language                                 : Swedish
Text #29
Format                                   : UTF-8
Language                                 : Thai
Text #30
Format                                   : UTF-8
Language                                 : Ukrainian
Text #31
Format                                   : UTF-8
Language                                 : Vietnamese
Menu
00:00:00.000                             : en:Chapter 1
00:04:35.025                             : en:Chapter 2
00:09:24.647                             : en:Chapter 3
00:14:07.764                             : en:Chapter 4
00:19:45.101                             : en:Chapter 5
00:25:54.219                             : en:Chapter 6
00:33:07.944                             : en:Chapter 7
00:37:26.161                             : en:Chapter 8
00:43:04.081                             : en:Chapter 9
00:50:05.169                             : en:Chapter 10
00:53:57.568                             : en:Chapter 11
01:03:14.290                             : en:Chapter 12
01:09:06.893                             : en:Chapter 13
01:16:13.694                             : en:Chapter 14
01:22:47.754                             : en:Chapter 15
01:30:26.880                             : en:Chapter 16
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 5:12 pm
Also, when using the 6-6-2 option, an error appears.
D:\Movies_Soft\DoVi_Scripts>TITLE DoVi_Scripts_1.9.0.2.beta
D:\Movies_Soft\DoVi_Scripts>set output_path=D:\Movies_Soft\DoVi_Scripts\
D:\Movies_Soft\DoVi_Scripts>for %i in (D:\Movies_Soft\DoVi_Scripts\) do set letterpath=%~di
D:\Movies_Soft\DoVi_Scripts>set letterpath=D:
D:\Movies_Soft\DoVi_Scripts>cd /d "D:\Movies_Soft\DoVi_Scripts\"
D:\Movies_Soft\DoVi_Scripts>set temp_folder=D:\Movies_Soft\DoVi_Scripts\TEMP_folder
D:\Movies_Soft\DoVi_Scripts>set container=MKV
D:\Movies_Soft\DoVi_Scripts>set MUX=YES
D:\Movies_Soft\DoVi_Scripts>set mp4_version=NEW
D:\Movies_Soft\DoVi_Scripts>set mux_all_audio=YES
D:\Movies_Soft\DoVi_Scripts>set mux_all_sub=YES
D:\Movies_Soft\DoVi_Scripts>set encode_DDP=YES
D:\Movies_Soft\DoVi_Scripts>set encode_7.1=YES
D:\Movies_Soft\DoVi_Scripts>set encode_LPCM=NO
D:\Movies_Soft\DoVi_Scripts>set keep_lossless=YES
D:\Movies_Soft\DoVi_Scripts>set keep_rpu=NO
D:\Movies_Soft\DoVi_Scripts>set keep_EL=NO
D:\Movies_Soft\DoVi_Scripts>set export.subs=NO
D:\Movies_Soft\DoVi_Scripts>set drop.HDR10plus=NO
D:\Movies_Soft\DoVi_Scripts>set auto.crop=YES
D:\Movies_Soft\DoVi_Scripts>set overwrite.L2=YES
D:\Movies_Soft\DoVi_Scripts>set remove_100=NO
D:\Movies_Soft\DoVi_Scripts>set remove_600=NO
D:\Movies_Soft\DoVi_Scripts>set remove_1000=NO
D:\Movies_Soft\DoVi_Scripts>set validate_metadata=NO
D:\Movies_Soft\DoVi_Scripts>set rem_cmv4=NO
D:\Movies_Soft\DoVi_Scripts>set scene_detect_type=detect-adaptive
D:\Movies_Soft\DoVi_Scripts>set L1_Tuning=1
D:\Movies_Soft\DoVi_Scripts>set upscale=YES
D:\Movies_Soft\DoVi_Scripts>set input.delay=NO
D:\Movies_Soft\DoVi_Scripts>set plot_100=NO
D:\Movies_Soft\DoVi_Scripts>set auto_scale_plot=NO
D:\Movies_Soft\DoVi_Scripts>set timestamp=00:00:00-00:05:00
D:\Movies_Soft\DoVi_Scripts>set frame_number=50
D:\Movies_Soft\DoVi_Scripts>set qscale=6
D:\Movies_Soft\DoVi_Scripts>set keep_prores=NO
D:\Movies_Soft\DoVi_Scripts>set english=YES
D:\Movies_Soft\DoVi_Scripts>set french=NO
D:\Movies_Soft\DoVi_Scripts>set spanish=NO
D:\Movies_Soft\DoVi_Scripts>set german=NO
D:\Movies_Soft\DoVi_Scripts>set italian=NO
D:\Movies_Soft\DoVi_Scripts>set chinese=NO
D:\Movies_Soft\DoVi_Scripts>set dutch=NO
D:\Movies_Soft\DoVi_Scripts>set finish=NO
D:\Movies_Soft\DoVi_Scripts>set russian=NO
D:\Movies_Soft\DoVi_Scripts>set polish=NO
D:\Movies_Soft\DoVi_Scripts>set japenese=NO
D:\Movies_Soft\DoVi_Scripts>set portuguese=NO
D:\Movies_Soft\DoVi_Scripts>if "YES" == "YES" set lang=English  & set langDG=eng  & set lmp4=en-EN  & set lmkv=en
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=French  & set langDG=fra  & set lmp4=fr-FR  & set lmkv=fr
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Spanish  & set langDG=spa  & set lmp4=es-ES  & set lmkv=es
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=German  & set langDG=deu  & set lmp4=de  & set lmkv=de
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Italian  & set langDG=ita  & set lmp4=it  & set lmkv=it
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Chinese  & set langDG=zho  & set lmp4=zh  & set lmkv=zh
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Dutch  & set langDG=nld  & set lmp4=nl  & set lmkv=nl
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Finish  & set langDG=fin  & set lmp4=fi  & set lmkv=fi
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Russian  & set langDG=rus  & set lmp4=ru  & set lmkv=ru
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Polish  & set langDG=pol  & set lmp4=po  & set lmkv=po
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Japenese  & set langDG=jpn  & set lmp4=jp  & set lmkv=jp
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Portuguese  & set langDG=por  & set lmp4=po  & set lmkv=po
D:\Movies_Soft\DoVi_Scripts>if "en" == "" set lmkv=und
D:\Movies_Soft\DoVi_Scripts>if "en-EN" == "" set lmp4=und
D:\Movies_Soft\DoVi_Scripts>if "eng" == "" set langDG=und
D:\Movies_Soft\DoVi_Scripts>if "English" == "" set lang=undetermined
D:\Movies_Soft\DoVi_Scripts>set dovi_tool_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\dovi_tool\dovi_tool.exe
D:\Movies_Soft\DoVi_Scripts>set dovi_tool_FIX_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\dovi_tool\dovi_tool.fix.exe
D:\Movies_Soft\DoVi_Scripts>set hdr10plus_parser_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\hdr10plus_tool\hdr10plus_tool.exe
D:\Movies_Soft\DoVi_Scripts>set tsmuxer_path=D:\Movies_Soft\Program_Files\tsMuxeR\tsMuxeR.exe
D:\Movies_Soft\DoVi_Scripts>set tsmuxer.GUI_path=D:\Movies_Soft\Program_Files\tsMuxeR\tsMuxeRGUI.exe
D:\Movies_Soft\DoVi_Scripts>set ffmpeg_path=D:\Movies_Soft\Program_Files\ffmpeg\bin\ffmpeg.exe
D:\Movies_Soft\DoVi_Scripts>set ffprobe_path=D:\Movies_Soft\Program_Files\ffmpeg\bin\ffprobe.exe
D:\Movies_Soft\DoVi_Scripts>set mkvmerge_path=D:\Movies_Soft\Program_Files\MKVToolNix\mkvmerge.exe
D:\Movies_Soft\DoVi_Scripts>set mkvtoolnix_path=D:\Movies_Soft\Program_Files\MKVToolNix\mkvtoolnix-gui.exe
D:\Movies_Soft\DoVi_Scripts>set mkvextract_path=D:\Movies_Soft\Program_Files\MKVToolNix\mkvextract.exe
D:\Movies_Soft\DoVi_Scripts>set madvr_path=D:\Movies_Soft\Program_Files\madVR\madMeasureHDR.exe
D:\Movies_Soft\DoVi_Scripts>set AC3.64kbps_path=D:\Movies_Soft\DoVi_Scripts\tools\64kbps.Silent.AC3.Track.ac3
D:\Movies_Soft\DoVi_Scripts>set thdmerge_path=D:\Movies_Soft\DoVi_Scripts\tools\thdmerge.exe
D:\Movies_Soft\DoVi_Scripts>set mp4muxer_path=D:\Movies_Soft\DoVi_Scripts\tools\mp4muxer.exe
D:\Movies_Soft\DoVi_Scripts>set mp4muxerNEW_path=D:\Movies_Soft\DoVi_Scripts\tools\mp4muxerNEW.exe
D:\Movies_Soft\DoVi_Scripts>set mp4demuxer_path=D:\Movies_Soft\DoVi_Scripts\tools\mp4demuxer.exe
D:\Movies_Soft\DoVi_Scripts>set mp4box_path=D:\Movies_Soft\DoVi_Scripts\tools\GPAC\mp4box.exe
D:\Movies_Soft\DoVi_Scripts>set mp4box2_path=D:\Movies_Soft\DoVi_Scripts\tools\GPAC2.0\mp4box.exe
D:\Movies_Soft\DoVi_Scripts>set DVH1=D:\Movies_Soft\DoVi_Scripts\tools\DoVi_mp4_DVH1.exe
D:\Movies_Soft\DoVi_Scripts>set detectborders_path=D:\Movies_Soft\DoVi_Scripts\tools\DetectBorders.exe
D:\Movies_Soft\DoVi_Scripts>set mediainfo_path=D:\Movies_Soft\Program_Files\MediaInfo_CLI_23.07_Windows_x64\mediainfo.exe
D:\Movies_Soft\DoVi_Scripts>set delaycut=D:\Movies_Soft\DoVi_Scripts\tools\delaycut.exe
D:\Movies_Soft\DoVi_Scripts>set DGDemux_path=D:\Movies_Soft\Program_Files\DGDemux\DGDemux.exe
D:\Movies_Soft\DoVi_Scripts>set eac3to_path=D:\Movies_Soft\Program_Files\UsEac3to\eac3to.exe
D:\Movies_Soft\DoVi_Scripts>set JQ_path=D:\Movies_Soft\Program_Files\JQ\jq-win64.exe
D:\Movies_Soft\DoVi_Scripts>set MPV_path=D:\Movies_Soft\Program_Files\mpv\mpv.com
D:\Movies_Soft\DoVi_Scripts>set plotbitrate_path=D:\Movies_Soft\Program_Files\plotbitrate-main\plotbitrate.py
D:\Movies_Soft\DoVi_Scripts>set EAE_path=D:\Movies_Soft\DoVi_Scripts\tools\EAE
D:\Movies_Soft\DoVi_Scripts>set EAE=D:\Movies_Soft\DoVi_Scripts\tools\EAE\EasyAudioEncoder.exe
D:\Movies_Soft\DoVi_Scripts>set wave=D:\Movies_Soft\DoVi_Scripts\tools\audiowaveform.exe
D:\Movies_Soft\DoVi_Scripts>set PLEX=D:\Movies_Soft\DoVi_Scripts\tools\EAE\PlexTranscoder.exe
D:\Movies_Soft\DoVi_Scripts>set supfoe=D:\Movies_Soft\DoVi_Scripts\tools\SUPfoe.exe
D:\Movies_Soft\DoVi_Scripts>set languages=D:\Movies_Soft\DoVi_Scripts\tools\languages.bat
D:\Movies_Soft\DoVi_Scripts>set imagemagick=D:\Movies_Soft\Program_Files\ImageMagick-7.1.1-Q16-HDRI\magick.exe
D:\Movies_Soft\DoVi_Scripts>set RPU.to.XML=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\RPU.to.XML\dovi_meta.exe
D:\Movies_Soft\DoVi_Scripts>set scenedetect_path=D:\Movies_Soft\Program_Files\PySceneDetect-0.6.1\scenedetect.exe
D:\Movies_Soft\DoVi_Scripts>set gnuplot=D:\Movies_Soft\Program_Files\gnuplot\bin\gnuplot.exe
D:\Movies_Soft\DoVi_Scripts>set AvsPmod_path=D:\Movies_Soft\Program_Files\AvsPmod\AvsPmod.exe
D:\Movies_Soft\DoVi_Scripts>set DGIndexNV_path=D:\Movies_Soft\Program_Files\DGDecNV\DGIndexNV.exe
D:\Movies_Soft\DoVi_Scripts>set DGDecodeNV.dll=D:\Movies_Soft\Program_Files\DGDecNV\DGDecodeNV.dll
D:\Movies_Soft\DoVi_Scripts>set DoViBaker=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\DoViBaker\DoViBaker_x64.dll
D:\Movies_Soft\DoVi_Scripts>set ffms2=D:\Movies_Soft\Program_Files\ffms2\x64\ffms2.dll
D:\Movies_Soft\DoVi_Scripts>set ffmsindex=D:\Movies_Soft\Program_Files\ffms2\x64\ffmsindex.exe
D:\Movies_Soft\DoVi_Scripts>set heat_map=D:\Movies_Soft\Program_Files\heatmap\
D:\Movies_Soft\DoVi_Scripts>set metafier_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\Dolby_Vision_Professional_Tools_v5.4.0\metafier.exe
D:\Movies_Soft\DoVi_Scripts>set cm_analyzer_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\Dolby_Vision_Professional_Tools_v5.4.0\cm_analyze.exe
D:\Movies_Soft\DoVi_Scripts>set DEE_path=D:\other\DEE\dee.exe
D:\Movies_Soft\DoVi_Scripts>set frame.to.read_path=100
D:\Movies_Soft\DoVi_Scripts>if "D:" == "C:" (
echo WARNING!
 echo OS drive output path(C:\) detected, some function are now restricted and some workflow might not work properly...
 echo Put the script folder on a non-OS drive...   & set MUX=NO  & set encode_DDP=NO
D:\Movies_Soft\DoVi_Scripts>echo.
D:\Movies_Soft\DoVi_Scripts>echo                         _____    __      ___       _____           _       _
D:\Movies_Soft\DoVi_Scripts>echo                        |  __ \   \ \    / (_)     / ____|         (_)     | |
D:\Movies_Soft\DoVi_Scripts>echo                        | |  | | __\ \  / / _     | (___   ___ _ __ _ _ __ | |_ ___
D:\Movies_Soft\DoVi_Scripts>echo                        | |  | |/ _ \ \/ / | |     \___ \ / __| '__| | '_ \| __/ __|
D:\Movies_Soft\DoVi_Scripts>echo                        | |__| | (_) \  /  | |     ____) | (__| |  | | |_) | |_\__ \
D:\Movies_Soft\DoVi_Scripts>echo                        |_____/ \___/ \/   |_|    |_____/ \___|_|  |_| .__/ \__|___/
D:\Movies_Soft\DoVi_Scripts>echo                        -@RESET_9999---------------------------------|__|-----------
D:\Movies_Soft\DoVi_Scripts>echo  Choose a mode...
 Choose a mode...
D:\Movies_Soft\DoVi_Scripts>echo 1) MODE.I=  DoVi Inject/Convert/Edit/Re-sync TWO INPUTS (P8 Hybrid maker/Injector)
D:\Movies_Soft\DoVi_Scripts>echo 2) MODE.F=  DoVi Fix/Edit/Extract/Verify/Info ONE INPUT
D:\Movies_Soft\DoVi_Scripts>echo 3) MODE.H=  DoVi Maker from HDR10 (Dolby Algo or madVR or HDR10plus)
D:\Movies_Soft\DoVi_Scripts>echo 4) MODE.P=  DoVi Profile 7 Input (MKV/BDMV)
D:\Movies_Soft\DoVi_Scripts>echo 5) MODE.B=  Dovi Batch Muxer
D:\Movies_Soft\DoVi_Scripts>echo 6) MODE.M=  MIXED: Plot/Audio/Screenshots/Remove/Player/Encoder and more...
D:\Movies_Soft\DoVi_Scripts>echo 7) MODE.M4= MP4 Workflows
D:\Movies_Soft\DoVi_Scripts>echo 8) Exit
8) Exit
D:\Movies_Soft\DoVi_Scripts>choice /C:12345678 /M Choice?
Choice? [1,2,3,4,5,6,7,8]?6
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 8 (Exit)
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 7 (goto :MODE.M4 )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 6 (goto :MODE.M )
D:\Movies_Soft\DoVi_Scripts>echo                                            *****************
D:\Movies_Soft\DoVi_Scripts>echo                                            * CHOOSE A MODE *
                                           * CHOOSE A MODE *
D:\Movies_Soft\DoVi_Scripts>echo 1) MODE.1= DV/HDR10+ REMOVER
D:\Movies_Soft\DoVi_Scripts>echo 2) MODE.2= Measurer
2) MODE.2= Measurer
D:\Movies_Soft\DoVi_Scripts>echo 3) MODE.3= AUDIO encoding
D:\Movies_Soft\DoVi_Scripts>echo 4) MODE.4= Find main movie playlist (BD MPLS)
D:\Movies_Soft\DoVi_Scripts>echo 5) MODE.5= HDR10plus INJECTOR/EXTRACTOR
D:\Movies_Soft\DoVi_Scripts>echo 6) MODE.6= MPV DV-P5/HDR10 player
D:\Movies_Soft\DoVi_Scripts>echo 7) MODE.7= Sample maker (creates 5min chunk)
D:\Movies_Soft\DoVi_Scripts>echo 8) MODE.8= Screenshot comparisons maker (DoVi_baker, Libplacebo, Heat/gamut map)
D:\Movies_Soft\DoVi_Scripts>echo 9) MODE.9= Encode P5/p7 FEL DV to HDR10 or SDR
D:\Movies_Soft\DoVi_Scripts>choice /C:123456789 /M Choice?
Choice? [1,2,3,4,5,6,7,8,9]?6
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 9 (goto :MODE.9 )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 8 (goto :MODE.8 )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 7 (goto :MODE.7 )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 6 (goto :MODE.6 )
                                           * CHOOSE A MODE *
D:\Movies_Soft\DoVi_Scripts>echo -----------------------------------------------------------------------------------------
D:\Movies_Soft\DoVi_Scripts>echo -- These modes can play P5-DV / HDR10 / HLG  in PQ or SDR
D:\Movies_Soft\DoVi_Scripts>echo -- Press "s" to export lossless screenshots. PNG will be in Dolby-Vision-Tools\tools\MPV
D:\Movies_Soft\DoVi_Scripts>echo -- I'm not sure if this will work if your pc doesnt have a GPU
D:\Movies_Soft\DoVi_Scripts>echo 1) MODE.PQ= MPV Play HDR10/DV/HLG in PQ (HDR10)
D:\Movies_Soft\DoVi_Scripts>echo 2) MODE.AUTO= MPV Play HDR10/DV/HLG in SDR
D:\Movies_Soft\DoVi_Scripts>echo 3) MODE.3= Back to main menu
D:\Movies_Soft\DoVi_Scripts>choice /C:123 /M Choice?
Choice? [1,2,3]?2
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 3 (goto :Main.Menu )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 2 (goto :MODE.AUTO )
D:\Movies_Soft\DoVi_Scripts>echo   Drag and drop a video file and press enter...  & set /p input=
W:\_Work\Escape.Room.2019\Escape.Room.2019.2160p.DolbyVision.WEB-DL.DTS-HD.MA.5.1.H.265-BLUTONiUM\Escape.Room.2019.DolbyVision.mkv
D:\Movies_Soft\DoVi_Scripts>Setlocal EnableDelayedExpansion
D:\Movies_Soft\DoVi_Scripts>for %i in (!input!) do set filename=%~ni
D:\Movies_Soft\DoVi_Scripts>set filename=Escape.Room.2019.DolbyVision
D:\Movies_Soft\DoVi_Scripts>Setlocal DisableDelayedExpansion
D:\Movies_Soft\DoVi_Scripts>D:\Movies_Soft\Program_Files\mpv\mpv.com --target-trc=auto --target-prim=auto --vo=gpu-next --gpu-context=d3d11 --screenshot-format=png --screenshot-png-compression=1 --screenshot-directory=D:\Movies_Soft\DoVi_Scripts\ --screenshot-template="Escape.Room.2019.DolbyVision" "Escape.Room.2019.DolbyVision"
[file] Cannot open file 'Escape.Room.2019.DolbyVision': No such file or directory
Failed to open Escape.Room.2019.DolbyVision.
Exiting... (Errors when loading file)
D:\Movies_Soft\DoVi_Scripts>goto :againqqq
Post by RESET_9999 » Sun Aug 06, 2023 5:21 pm
Lapihin_A wrote: Sun Aug 06, 2023 5:10 pm I used your script of the latest version of "DoVi_Scripts_1.9.0.2.beta_MKV" at the moment.
My guess is that SiC changed the full range flag for the container only(with mkvtoolnix) and not at the bitstream level and ffmpeg still thinks the color range is FULL when it export the screenshot.
Post by RESET_9999 » Sun Aug 06, 2023 5:27 pm
Lapihin_A wrote: Sun Aug 06, 2023 5:12 pm Also, when using the 6-6-2 option, an error appears.
oops..
try DoVi_Scripts_1.9.0.3.beta
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 5:34 pm
RESET_9999 wrote: Sun Aug 06, 2023 5:21 pm My guess is that SiC changed the full range flag for the container only(with mkvtoolnix) and not at the bitstream level and ffmpeg still thinks the color range is FULL when it export the screenshot.
I don't think so.
General
Complete name                            : Escape.Room.2019.hevc
File size                                : 51.2 GiB
Video
I tried some of the other videos
magic.mike.2012.hdr.2160p.web.h265-slot.mkv
magic.mike.2012.dv.2160p.web.h265-slot.mkv
And there is exactly the same problem, if you need to provide screenshots.
Post by RESET_9999 » Sun Aug 06, 2023 5:42 pm
Lapihin_A wrote: Sun Aug 06, 2023 5:34 pm I tried some of the other videos
Well I use 6-8-3 every day, it doesn't tone map to SDR... Your Bcore comparison sure looks like full vs limited range.
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 6:16 pm
Post by RESET_9999 » Sun Aug 06, 2023 6:20 pm
Lapihin_A wrote: Sun Aug 06, 2023 6:16 pm Magic.Mike.2012.PQ
your HDR10 pic is wrong somehow.
it's working just fine and it's the same as MPV on my end so I don't know.
6-8-3: https://slow.pics/c/jVXtSv5Z
MPV:https://slow.pics/c/hmJiiuVO
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 6:31 pm
RESET_9999 wrote: Sun Aug 06, 2023 6:20 pm
Yes, I was wrong that the problem is not DV-P5 but HDR, I saw it by taking a screenshot in MPC. After that I tried 6-8-4 option for magic.mike.2012.hdr.2160p.web.h265-slot.mkv and got normal HDR screenshots.
NiCE77
Post by NiCE77 » Mon Aug 07, 2023 7:22 am
RESET_9999 wrote: Sun Aug 06, 2023 11:42 am
My goal is, create a file that works well on old LG and Apple TV.
