Worked! Perfect.
Since the 1.3.2-alpha3 version seems to be fully stable, I released it as 1.3.2
https://github.com/bbeny123/mp4muxer/releases/tag/1.3.2
Version 1.3.2 differs from 1.3.1 in that for DV profiles > 7 the codec configuration box is set to dvcC instead of dvvC (mp4box_64bits 1.0.0 also set dvcC).
This is non-compliant with Dolby's documentation, but as we can see Oppo and older LG TVs are also non-compliant (as only this setting works on them).
No, LG dropped P7 support since the CX. I was talking about P8 and P5.
Is there a way to tell what resolution video an RPU came from/what resolution an RPU is intended for? Like if I have a p5 RPU but not the source p5 video, and a HDR10 Blu-ray BL to inject the RPU into - how do I know if black bars should be cropped or not (on some p5 videos the video is 16:9 with black bars in the stream, some p5 will have just the video in whatever resolution/aspect ratio with no black bars)? Like a specific line/variable to look for in the json/RPU?
Everything about the rpu aspect ratio(active area) is in Level 5staknhalo wrote: ↑Sun Aug 06, 2023 1:30 amIs there a way to tell what resolution video an RPU came from/what resolution an RPU is intended for? Like if I have a p5 RPU but not the source p5 video, and a HDR10 Blu-ray BL to inject the RPU into - how do I know if black bars should be cropped or not (on some p5 videos the video is 16:9 with black bars in the stream, some p5 will have just the video in whatever resolution/aspect ratio with no black bars)? Like a specific line/variable to look for in the json/RPU?
If the BL is 16:9 with no black bars or if it is cropped, L5 should always be 0 regardless of the base layer resolution.
if the new BL has black bars, you measure them and edit L5 accordingly.
Got it thanksRESET_9999 wrote: ↑Sun Aug 06, 2023 2:08 amEverything about the rpu aspect ratio(active area) is in Level 5staknhalo wrote: ↑Sun Aug 06, 2023 1:30 amIs there a way to tell what resolution video an RPU came from/what resolution an RPU is intended for? Like if I have a p5 RPU but not the source p5 video, and a HDR10 Blu-ray BL to inject the RPU into - how do I know if black bars should be cropped or not (on some p5 videos the video is 16:9 with black bars in the stream, some p5 will have just the video in whatever resolution/aspect ratio with no black bars)? Like a specific line/variable to look for in the json/RPU?
So I never really figured out what was wrong with my setup that was keeping me from converting TrueHD Atmos to DD+, but I think I figured out a way to get around it.
My setup can only handle lossy 5.1 Atmos over ARC anyway, so for movies where audio like that (or even just 5.1 surround or lesser) is available, I want to make a Frankenstein .MP4 file of a profile 7 DT-DL DV stream and whatever lossy audio I find. That should play in DV on my LG E8. I know I'll need to use MP4Muxer at the end but uh, how would I do that? Specifically, should I demux the P7 DT-DL DV stream from the original file (which in this case contains a TrueHD audio stream that would break DV on my LG E8), the lossy audio from whatever other file, and mux them together with MP4Muxer? I guess my real obstacle is properly demuxing everything, and finding out what command exactly I should enter in MP4Muxer. Any guidance would be much appreciated.
In short, the file I'm imagining would be a .MP4 file containing BL+EL+RPU profile 7 DT-DL Dolby Vision, and lossy audio topping out at 5.1 DD+ Atmos.
Amateur enthusiast
LG E8 55” ——-> Vizio M512A-H6
Thanks! But I noticed, the --dvh1flag option is not working. This would be necessary for playback on Apple TV (with tvOS 17). Can you fix it?bbeny123 wrote: ↑Sat Aug 05, 2023 1:54 pmSince the 1.3.2-alpha3 version seems to be fully stable, I released it as 1.3.2
This solution works until: https://github.com/rixtox/mp4dovi
Since its introduction, the '--dvh1flag {trackId}' flag has only worked with DV profiles: 1, 3 or 5. I have lifted this restriction.NiCE77 wrote: ↑Sun Aug 06, 2023 8:44 amThanks! But I noticed, the --dvh1flag option is not working. This would be necessary for playback on Apple TV (with tvOS 17). Can you fix it?
Version 1.3.3: https://github.com/bbeny123/mp4muxer/releases/tag/1.3.3
but why use the mp4muxer at all for ATV or new TV (2019+) when mp4box can mux directly lossless audio + subs + chapter?NiCE77 wrote: ↑Sun Aug 06, 2023 8:44 am
Please share the file "SDR_heatmap.cube".
Hi @RESET_9999! When using the 6-8-3 option with video 1 (HDR10) and video 2 (DV-P5) we get these screenshots, you can see that tonemapping is applied to video 2 (DV-P5).
unless you're using an older version of the script, the latest ones no longer tonemap to SDR for 6-8-3.Lapihin_A wrote: ↑Sun Aug 06, 2023 4:42 pmHi @RESET_9999! When using the 6-8-3 option with video 1 (HDR10) and video 2 (DV-P5) we get these screenshots, you can see that tonemapping is applied to video 2 (DV-P5).
if you're using the latest beta, are you sure it's not just your two sources that are different?
I know some BCORE webdl are incorrectly flagged as a ''full range'' which messes up the black levels.
https://drive.google.com/file/d/1Ix3JT6 ... drive_link
I used your script of the latest version of "DoVi_Scripts_1.9.0.2.beta_MKV" at the moment.RESET_9999 wrote: ↑Sun Aug 06, 2023 5:00 pmunless you're using an older version of the script, the latest ones no longer tonemap to SDR for 6-8-3.Lapihin_A wrote: ↑Sun Aug 06, 2023 4:42 pmHi @RESET_9999! When using the 6-8-3 option with video 1 (HDR10) and video 2 (DV-P5) we get these screenshots, you can see that tonemapping is applied to video 2 (DV-P5).
SiC's BCORE video was used, which has no contrast problem unlike ROCCaT's BCORE.
General
Unique ID : 83590475605974953443278668065443810502 (0x3EE2F0A411F5477A6A2AAA890CB20CC6)
Complete name : Escape.Room.2019.2160p.BCORE.WEB-DL.DTS-HD.MA.5.1.HDR.HEVC-SiC.mkv
Format : Matroska
Format version : Version 4
File size : 57.2 GiB
Duration : 1 h 39 min
Overall bit rate mode : Variable
Overall bit rate : 82.2 Mb/s
Frame rate : 23.976 FPS
Writing application : mkvmerge v13.0.0 ('Sharing is Caring') 64-bit
Writing library : libebml v1.0.0 + libmatroska v1.1.1
Video
Format : HEVC
Format profile : Main 10@L5.2@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 3876 cd/m2
Maximum Frame-Average Light Level : 852 cd/m2
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Delay relative to video : 2 ms
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Title : SDH
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Language : Arabic
Default : No
Forced : No
Text #4
Format : UTF-8
Language : Cantonese
Default : No
Forced : No
Text #5
Format : UTF-8
Title : Simplified
Language : Chinese-cmn-simple
Default : No
Forced : No
Text #6
Format : UTF-8
Title : Traditional
Language : Mandarin
Default : No
Forced : No
Text #7
Format : UTF-8
Language : Croatian
Default : No
Forced : No
Text #8
Format : UTF-8
Language : Czech
Default : No
Forced : No
Text #9
Format : UTF-8
Language : Danish
Default : No
Forced : No
Text #10
Format : UTF-8
Language : Dutch
Default : No
Forced : No
Text #11
Format : UTF-8
Language : Finnish
Default : No
Forced : No
Text #12
Format : UTF-8
Language : French
Default : No
Forced : No
Text #13
Format : UTF-8
Language : German
Default : No
Forced : No
Text #14
Format : UTF-8
Language : Greek
Default : No
Forced : No
Text #15
Format : UTF-8
Language : Hebrew
Default : No
Forced : No
Text #16
Format : UTF-8
Language : Hungarian
Default : No
Forced : No
Text #17
Format : UTF-8
Language : Icelandic
Default : No
Forced : No
Text #18
Format : UTF-8
Language : Indonesian
Default : No
Forced : No
Text #19
Format : UTF-8
Language : Italian
Default : No
Forced : No
Text #20
Format : UTF-8
Language : Korean
Default : No
Forced : No
Text #21
Format : UTF-8
Language : Norwegian
Default : No
Forced : No
Text #22
Format : UTF-8
Language : Polish
Default : No
Forced : No
Text #23
Format : UTF-8
Title : Brazilian
Language : Portuguese (BR)
Default : No
Forced : No
Text #24
Format : UTF-8
Title : Iberian
Language : Portuguese (PT)
Default : No
Forced : No
Text #25
Format : UTF-8
Language : Romanian
Default : No
Forced : No
Text #26
Format : UTF-8
Language : Russian
Default : No
Forced : No
Text #27
Format : UTF-8
Title : Castilian
Language : Spanish (ES)
Default : No
Forced : No
Text #28
Format : UTF-8
Language : Swedish
Default : No
Forced : No
Text #29
Format : UTF-8
Language : Thai
Default : No
Forced : No
Text #30
Format : UTF-8
Language : Ukrainian
Default : No
Forced : No
Text #31
Format : UTF-8
Language : Vietnamese
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:04:35.025 : en:Chapter 2
00:09:24.647 : en:Chapter 3
00:14:07.764 : en:Chapter 4
00:19:45.101 : en:Chapter 5
00:25:54.219 : en:Chapter 6
00:33:07.944 : en:Chapter 7
00:37:26.161 : en:Chapter 8
00:43:04.081 : en:Chapter 9
00:50:05.169 : en:Chapter 10
00:53:57.568 : en:Chapter 11
01:03:14.290 : en:Chapter 12
01:09:06.893 : en:Chapter 13
01:16:13.694 : en:Chapter 14
01:22:47.754 : en:Chapter 15
01:30:26.880 : en:Chapter 16
Also, when using the 6-6-2 option, an error appears.
D:\Movies_Soft\DoVi_Scripts>TITLE DoVi_Scripts_1.9.0.2.beta
D:\Movies_Soft\DoVi_Scripts>set output_path=D:\Movies_Soft\DoVi_Scripts\
D:\Movies_Soft\DoVi_Scripts>for %i in (D:\Movies_Soft\DoVi_Scripts\) do set letterpath=%~di
D:\Movies_Soft\DoVi_Scripts>set letterpath=D:
D:\Movies_Soft\DoVi_Scripts>cd /d "D:\Movies_Soft\DoVi_Scripts\"
D:\Movies_Soft\DoVi_Scripts>set temp_folder=D:\Movies_Soft\DoVi_Scripts\TEMP_folder
D:\Movies_Soft\DoVi_Scripts>set container=MKV
D:\Movies_Soft\DoVi_Scripts>set MUX=YES
D:\Movies_Soft\DoVi_Scripts>set mp4_version=NEW
D:\Movies_Soft\DoVi_Scripts>set mux_all_audio=YES
D:\Movies_Soft\DoVi_Scripts>set mux_all_sub=YES
D:\Movies_Soft\DoVi_Scripts>set encode_DDP=YES
D:\Movies_Soft\DoVi_Scripts>set encode_7.1=YES
D:\Movies_Soft\DoVi_Scripts>set encode_LPCM=NO
D:\Movies_Soft\DoVi_Scripts>set keep_lossless=YES
D:\Movies_Soft\DoVi_Scripts>set keep_rpu=NO
D:\Movies_Soft\DoVi_Scripts>set keep_EL=NO
D:\Movies_Soft\DoVi_Scripts>set export.subs=NO
D:\Movies_Soft\DoVi_Scripts>set drop.HDR10plus=NO
D:\Movies_Soft\DoVi_Scripts>set auto.crop=YES
D:\Movies_Soft\DoVi_Scripts>set overwrite.L2=YES
D:\Movies_Soft\DoVi_Scripts>set remove_100=NO
D:\Movies_Soft\DoVi_Scripts>set remove_600=NO
D:\Movies_Soft\DoVi_Scripts>set remove_1000=NO
D:\Movies_Soft\DoVi_Scripts>set validate_metadata=NO
D:\Movies_Soft\DoVi_Scripts>set rem_cmv4=NO
D:\Movies_Soft\DoVi_Scripts>set scene_detect_type=detect-adaptive
D:\Movies_Soft\DoVi_Scripts>set L1_Tuning=1
D:\Movies_Soft\DoVi_Scripts>set upscale=YES
D:\Movies_Soft\DoVi_Scripts>set input.delay=NO
D:\Movies_Soft\DoVi_Scripts>set plot_100=NO
D:\Movies_Soft\DoVi_Scripts>set auto_scale_plot=NO
D:\Movies_Soft\DoVi_Scripts>set timestamp=00:00:00-00:05:00
D:\Movies_Soft\DoVi_Scripts>set frame_number=50
D:\Movies_Soft\DoVi_Scripts>set qscale=6
D:\Movies_Soft\DoVi_Scripts>set keep_prores=NO
D:\Movies_Soft\DoVi_Scripts>set english=YES
D:\Movies_Soft\DoVi_Scripts>set french=NO
D:\Movies_Soft\DoVi_Scripts>set spanish=NO
D:\Movies_Soft\DoVi_Scripts>set german=NO
D:\Movies_Soft\DoVi_Scripts>set italian=NO
D:\Movies_Soft\DoVi_Scripts>set chinese=NO
D:\Movies_Soft\DoVi_Scripts>set dutch=NO
D:\Movies_Soft\DoVi_Scripts>set finish=NO
D:\Movies_Soft\DoVi_Scripts>set russian=NO
D:\Movies_Soft\DoVi_Scripts>set polish=NO
D:\Movies_Soft\DoVi_Scripts>set japenese=NO
D:\Movies_Soft\DoVi_Scripts>set portuguese=NO
D:\Movies_Soft\DoVi_Scripts>if "YES" == "YES" set lang=English & set langDG=eng & set lmp4=en-EN & set lmkv=en
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=French & set langDG=fra & set lmp4=fr-FR & set lmkv=fr
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Spanish & set langDG=spa & set lmp4=es-ES & set lmkv=es
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=German & set langDG=deu & set lmp4=de & set lmkv=de
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Italian & set langDG=ita & set lmp4=it & set lmkv=it
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Chinese & set langDG=zho & set lmp4=zh & set lmkv=zh
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Dutch & set langDG=nld & set lmp4=nl & set lmkv=nl
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Finish & set langDG=fin & set lmp4=fi & set lmkv=fi
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Russian & set langDG=rus & set lmp4=ru & set lmkv=ru
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Polish & set langDG=pol & set lmp4=po & set lmkv=po
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Japenese & set langDG=jpn & set lmp4=jp & set lmkv=jp
D:\Movies_Soft\DoVi_Scripts>if "NO" == "YES" set lang=Portuguese & set langDG=por & set lmp4=po & set lmkv=po
D:\Movies_Soft\DoVi_Scripts>if "en" == "" set lmkv=und
D:\Movies_Soft\DoVi_Scripts>if "en-EN" == "" set lmp4=und
D:\Movies_Soft\DoVi_Scripts>if "eng" == "" set langDG=und
D:\Movies_Soft\DoVi_Scripts>if "English" == "" set lang=undetermined
D:\Movies_Soft\DoVi_Scripts>set dovi_tool_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\dovi_tool\dovi_tool.exe
D:\Movies_Soft\DoVi_Scripts>set dovi_tool_FIX_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\dovi_tool\dovi_tool.fix.exe
D:\Movies_Soft\DoVi_Scripts>set hdr10plus_parser_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\hdr10plus_tool\hdr10plus_tool.exe
D:\Movies_Soft\DoVi_Scripts>set tsmuxer_path=D:\Movies_Soft\Program_Files\tsMuxeR\tsMuxeR.exe
D:\Movies_Soft\DoVi_Scripts>set tsmuxer.GUI_path=D:\Movies_Soft\Program_Files\tsMuxeR\tsMuxeRGUI.exe
D:\Movies_Soft\DoVi_Scripts>set ffmpeg_path=D:\Movies_Soft\Program_Files\ffmpeg\bin\ffmpeg.exe
D:\Movies_Soft\DoVi_Scripts>set ffprobe_path=D:\Movies_Soft\Program_Files\ffmpeg\bin\ffprobe.exe
D:\Movies_Soft\DoVi_Scripts>set mkvmerge_path=D:\Movies_Soft\Program_Files\MKVToolNix\mkvmerge.exe
D:\Movies_Soft\DoVi_Scripts>set mkvtoolnix_path=D:\Movies_Soft\Program_Files\MKVToolNix\mkvtoolnix-gui.exe
D:\Movies_Soft\DoVi_Scripts>set mkvextract_path=D:\Movies_Soft\Program_Files\MKVToolNix\mkvextract.exe
D:\Movies_Soft\DoVi_Scripts>set madvr_path=D:\Movies_Soft\Program_Files\madVR\madMeasureHDR.exe
D:\Movies_Soft\DoVi_Scripts>set AC3.64kbps_path=D:\Movies_Soft\DoVi_Scripts\tools\64kbps.Silent.AC3.Track.ac3
D:\Movies_Soft\DoVi_Scripts>set thdmerge_path=D:\Movies_Soft\DoVi_Scripts\tools\thdmerge.exe
D:\Movies_Soft\DoVi_Scripts>set mp4muxer_path=D:\Movies_Soft\DoVi_Scripts\tools\mp4muxer.exe
D:\Movies_Soft\DoVi_Scripts>set mp4muxerNEW_path=D:\Movies_Soft\DoVi_Scripts\tools\mp4muxerNEW.exe
D:\Movies_Soft\DoVi_Scripts>set mp4demuxer_path=D:\Movies_Soft\DoVi_Scripts\tools\mp4demuxer.exe
D:\Movies_Soft\DoVi_Scripts>set mp4box_path=D:\Movies_Soft\DoVi_Scripts\tools\GPAC\mp4box.exe
D:\Movies_Soft\DoVi_Scripts>set mp4box2_path=D:\Movies_Soft\DoVi_Scripts\tools\GPAC2.0\mp4box.exe
D:\Movies_Soft\DoVi_Scripts>set DVH1=D:\Movies_Soft\DoVi_Scripts\tools\DoVi_mp4_DVH1.exe
D:\Movies_Soft\DoVi_Scripts>set detectborders_path=D:\Movies_Soft\DoVi_Scripts\tools\DetectBorders.exe
D:\Movies_Soft\DoVi_Scripts>set mediainfo_path=D:\Movies_Soft\Program_Files\MediaInfo_CLI_23.07_Windows_x64\mediainfo.exe
D:\Movies_Soft\DoVi_Scripts>set delaycut=D:\Movies_Soft\DoVi_Scripts\tools\delaycut.exe
D:\Movies_Soft\DoVi_Scripts>set DGDemux_path=D:\Movies_Soft\Program_Files\DGDemux\DGDemux.exe
D:\Movies_Soft\DoVi_Scripts>set eac3to_path=D:\Movies_Soft\Program_Files\UsEac3to\eac3to.exe
D:\Movies_Soft\DoVi_Scripts>set JQ_path=D:\Movies_Soft\Program_Files\JQ\jq-win64.exe
D:\Movies_Soft\DoVi_Scripts>set MPV_path=D:\Movies_Soft\Program_Files\mpv\mpv.com
D:\Movies_Soft\DoVi_Scripts>set plotbitrate_path=D:\Movies_Soft\Program_Files\plotbitrate-main\plotbitrate.py
D:\Movies_Soft\DoVi_Scripts>set EAE_path=D:\Movies_Soft\DoVi_Scripts\tools\EAE
D:\Movies_Soft\DoVi_Scripts>set EAE=D:\Movies_Soft\DoVi_Scripts\tools\EAE\EasyAudioEncoder.exe
D:\Movies_Soft\DoVi_Scripts>set wave=D:\Movies_Soft\DoVi_Scripts\tools\audiowaveform.exe
D:\Movies_Soft\DoVi_Scripts>set PLEX=D:\Movies_Soft\DoVi_Scripts\tools\EAE\PlexTranscoder.exe
D:\Movies_Soft\DoVi_Scripts>set supfoe=D:\Movies_Soft\DoVi_Scripts\tools\SUPfoe.exe
D:\Movies_Soft\DoVi_Scripts>set languages=D:\Movies_Soft\DoVi_Scripts\tools\languages.bat
D:\Movies_Soft\DoVi_Scripts>set imagemagick=D:\Movies_Soft\Program_Files\ImageMagick-7.1.1-Q16-HDRI\magick.exe
D:\Movies_Soft\DoVi_Scripts>set RPU.to.XML=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\RPU.to.XML\dovi_meta.exe
D:\Movies_Soft\DoVi_Scripts>set scenedetect_path=D:\Movies_Soft\Program_Files\PySceneDetect-0.6.1\scenedetect.exe
D:\Movies_Soft\DoVi_Scripts>set gnuplot=D:\Movies_Soft\Program_Files\gnuplot\bin\gnuplot.exe
D:\Movies_Soft\DoVi_Scripts>set AvsPmod_path=D:\Movies_Soft\Program_Files\AvsPmod\AvsPmod.exe
D:\Movies_Soft\DoVi_Scripts>set DGIndexNV_path=D:\Movies_Soft\Program_Files\DGDecNV\DGIndexNV.exe
D:\Movies_Soft\DoVi_Scripts>set DGDecodeNV.dll=D:\Movies_Soft\Program_Files\DGDecNV\DGDecodeNV.dll
D:\Movies_Soft\DoVi_Scripts>set DoViBaker=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\DoViBaker\DoViBaker_x64.dll
D:\Movies_Soft\DoVi_Scripts>set ffms2=D:\Movies_Soft\Program_Files\ffms2\x64\ffms2.dll
D:\Movies_Soft\DoVi_Scripts>set ffmsindex=D:\Movies_Soft\Program_Files\ffms2\x64\ffmsindex.exe
D:\Movies_Soft\DoVi_Scripts>set heat_map=D:\Movies_Soft\Program_Files\heatmap\
D:\Movies_Soft\DoVi_Scripts>set metafier_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\Dolby_Vision_Professional_Tools_v5.4.0\metafier.exe
D:\Movies_Soft\DoVi_Scripts>set cm_analyzer_path=D:\Movies_Soft\Program_Files\HDR10plus_DV_Metadata\Dolby_Vision_Professional_Tools_v5.4.0\cm_analyze.exe
D:\Movies_Soft\DoVi_Scripts>set DEE_path=D:\other\DEE\dee.exe
D:\Movies_Soft\DoVi_Scripts>set frame.to.read_path=100
D:\Movies_Soft\DoVi_Scripts>if "D:" == "C:" (
echo WARNING!
echo OS drive output path(C:\) detected, some function are now restricted and some workflow might not work properly...
echo Put the script folder on a non-OS drive... & set MUX=NO & set encode_DDP=NO
D:\Movies_Soft\DoVi_Scripts>echo.
D:\Movies_Soft\DoVi_Scripts>echo _____ __ ___ _____ _ _
D:\Movies_Soft\DoVi_Scripts>echo | __ \ \ \ / (_) / ____| (_) | |
D:\Movies_Soft\DoVi_Scripts>echo | | | | __\ \ / / _ | (___ ___ _ __ _ _ __ | |_ ___
D:\Movies_Soft\DoVi_Scripts>echo | | | |/ _ \ \/ / | | \___ \ / __| '__| | '_ \| __/ __|
D:\Movies_Soft\DoVi_Scripts>echo | |__| | (_) \ / | | ____) | (__| | | | |_) | |_\__ \
D:\Movies_Soft\DoVi_Scripts>echo |_____/ \___/ \/ |_| |_____/ \___|_| |_| .__/ \__|___/
D:\Movies_Soft\DoVi_Scripts>echo -@RESET_9999---------------------------------|__|-----------
D:\Movies_Soft\DoVi_Scripts>echo Choose a mode...
Choose a mode...
D:\Movies_Soft\DoVi_Scripts>echo 1) MODE.I= DoVi Inject/Convert/Edit/Re-sync TWO INPUTS (P8 Hybrid maker/Injector)
D:\Movies_Soft\DoVi_Scripts>echo 2) MODE.F= DoVi Fix/Edit/Extract/Verify/Info ONE INPUT
D:\Movies_Soft\DoVi_Scripts>echo 3) MODE.H= DoVi Maker from HDR10 (Dolby Algo or madVR or HDR10plus)
D:\Movies_Soft\DoVi_Scripts>echo 4) MODE.P= DoVi Profile 7 Input (MKV/BDMV)
D:\Movies_Soft\DoVi_Scripts>echo 5) MODE.B= Dovi Batch Muxer
D:\Movies_Soft\DoVi_Scripts>echo 6) MODE.M= MIXED: Plot/Audio/Screenshots/Remove/Player/Encoder and more...
D:\Movies_Soft\DoVi_Scripts>echo 7) MODE.M4= MP4 Workflows
D:\Movies_Soft\DoVi_Scripts>echo 8) Exit
8) Exit
D:\Movies_Soft\DoVi_Scripts>choice /C:12345678 /M Choice?
Choice? [1,2,3,4,5,6,7,8]?6
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 8 (Exit)
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 7 (goto :MODE.M4 )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 6 (goto :MODE.M )
D:\Movies_Soft\DoVi_Scripts>echo *****************
D:\Movies_Soft\DoVi_Scripts>echo * CHOOSE A MODE *
* CHOOSE A MODE *
D:\Movies_Soft\DoVi_Scripts>echo 1) MODE.1= DV/HDR10+ REMOVER
D:\Movies_Soft\DoVi_Scripts>echo 2) MODE.2= Measurer
2) MODE.2= Measurer
D:\Movies_Soft\DoVi_Scripts>echo 3) MODE.3= AUDIO encoding
D:\Movies_Soft\DoVi_Scripts>echo 4) MODE.4= Find main movie playlist (BD MPLS)
D:\Movies_Soft\DoVi_Scripts>echo 5) MODE.5= HDR10plus INJECTOR/EXTRACTOR
D:\Movies_Soft\DoVi_Scripts>echo 6) MODE.6= MPV DV-P5/HDR10 player
D:\Movies_Soft\DoVi_Scripts>echo 7) MODE.7= Sample maker (creates 5min chunk)
D:\Movies_Soft\DoVi_Scripts>echo 8) MODE.8= Screenshot comparisons maker (DoVi_baker, Libplacebo, Heat/gamut map)
D:\Movies_Soft\DoVi_Scripts>echo 9) MODE.9= Encode P5/p7 FEL DV to HDR10 or SDR
D:\Movies_Soft\DoVi_Scripts>choice /C:123456789 /M Choice?
Choice? [1,2,3,4,5,6,7,8,9]?6
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 9 (goto :MODE.9 )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 8 (goto :MODE.8 )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 7 (goto :MODE.7 )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 6 (goto :MODE.6 )
* CHOOSE A MODE *
D:\Movies_Soft\DoVi_Scripts>echo -----------------------------------------------------------------------------------------
D:\Movies_Soft\DoVi_Scripts>echo -- These modes can play P5-DV / HDR10 / HLG in PQ or SDR
D:\Movies_Soft\DoVi_Scripts>echo -- Press "s" to export lossless screenshots. PNG will be in Dolby-Vision-Tools\tools\MPV
D:\Movies_Soft\DoVi_Scripts>echo -- I'm not sure if this will work if your pc doesnt have a GPU
D:\Movies_Soft\DoVi_Scripts>echo 1) MODE.PQ= MPV Play HDR10/DV/HLG in PQ (HDR10)
D:\Movies_Soft\DoVi_Scripts>echo 2) MODE.AUTO= MPV Play HDR10/DV/HLG in SDR
D:\Movies_Soft\DoVi_Scripts>echo 3) MODE.3= Back to main menu
D:\Movies_Soft\DoVi_Scripts>choice /C:123 /M Choice?
Choice? [1,2,3]?2
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 3 (goto :Main.Menu )
D:\Movies_Soft\DoVi_Scripts>if ERRORLEVEL 2 (goto :MODE.AUTO )
D:\Movies_Soft\DoVi_Scripts>echo Drag and drop a video file and press enter... & set /p input=
W:\_Work\Escape.Room.2019\Escape.Room.2019.2160p.DolbyVision.WEB-DL.DTS-HD.MA.5.1.H.265-BLUTONiUM\Escape.Room.2019.DolbyVision.mkv
D:\Movies_Soft\DoVi_Scripts>Setlocal EnableDelayedExpansion
D:\Movies_Soft\DoVi_Scripts>for %i in (!input!) do set filename=%~ni
D:\Movies_Soft\DoVi_Scripts>set filename=Escape.Room.2019.DolbyVision
D:\Movies_Soft\DoVi_Scripts>Setlocal DisableDelayedExpansion
D:\Movies_Soft\DoVi_Scripts>D:\Movies_Soft\Program_Files\mpv\mpv.com --target-trc=auto --target-prim=auto --vo=gpu-next --gpu-context=d3d11 --screenshot-format=png --screenshot-png-compression=1 --screenshot-directory=D:\Movies_Soft\DoVi_Scripts\ --screenshot-template="Escape.Room.2019.DolbyVision" "Escape.Room.2019.DolbyVision"
[file] Cannot open file 'Escape.Room.2019.DolbyVision': No such file or directory
Failed to open Escape.Room.2019.DolbyVision.
Exiting... (Errors when loading file)
D:\Movies_Soft\DoVi_Scripts>goto :againqqq
