Asus BW-16D1X-U
and_guazu
Re: Asus BW-16D1X-U
#91 Post by and_guazu » Thu Jul 27, 2023 7:02 am
Billycar11 wrote: Thu Jul 27, 2023 7:00 am
and_guazu wrote: Thu Jul 27, 2023 6:58 am Drive does not appear to see any other disks but it is brand new. Before flashing it said it was mt1959 and after flashing as well
was the drive tested before flashing?
No it was not, could be defective I suppose
silmaril
Re: Asus BW-16D1X-U
#92 Post by silmaril » Sat Aug 05, 2023 8:31 pm
I bought a BW-16D1X-U today and found out it can't read UHD disks :-(
After reading through this thread, I could successfully flash it and just imported my first UHD disk successfully :-)
My drive was manufactured in February 2023.
Original version info from MakeMKV:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 63
I used the GUI SDF tool on Windows 10 and flashed HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin.
This version was not (yet) in the all-you-need pack, but I found it inside this repo: https://github.com/pjobson/Flash-LG-WH16NS60-Linux
Version info after flashing:
Product: BD-RE WH16NS60
Revision: 1.03
Firmware date: 2120-05-08 10:10
Highest AACS version: 76
Firmware version: 1.03
Thank you very much for providing not only this great piece of software (which I will definitely buy now) but also such a great community that finds solutions to make things possible - even against the will of hardware manufacturers ;-)
jbuff
Re: Asus BW-16D1X-U
#93 Post by jbuff » Mon Aug 21, 2023 1:46 am
I have the same bluray drive. I had purchased mine from 'zon on 06 July 2023.
Your post emboldened me to give the flash a try. Following your instructions exactly my Asus BW-16D1X-U on Windows10 desktop PC is now able to directly play/view 4k UHD Blu-Ray disks.
Also MakeMKV was able to copy the disk contents to a backup folder. The .mkv/movies were playable.
hopperwelles
Re: Asus BW-16D1X-U
#94 Post by hopperwelles » Tue Dec 26, 2023 11:53 pm
hi there - longtime user, first time replier
I've had my ASUS since the pandemic- purchasing it in 2020- and never had any issues reading or copying discs to mkv - until today. Granted, I haven't used the program in a while and was able to re-up with the beta key. But now I've tried both 4K and standard blurays and neither works.
Can someone help me? I've gone over earlier posts in the thread and read up on the UHD Flashing, but that seems to be Windows-based, and I'm on a Mac (my last to be sure).
My Specs as of this post in MakeMKV
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: [redacted]
Firmware date: 2119-01-04 10:47
Highest AACS version: 78
Debug log started at Tue Dec 26 23:30:14 2023 , written by MakeMKV v1.15.3 darwin(x64-release)
001005:0000 MakeMKV v1.15.3 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///tmp/MakeMKV-0xd0e-1.tmp
Network access is ENABLED, CURL version 8.1.2/(SecureTransport) LibreSSL/3.3.6/1.45.1 (x86_64-apple-darwin21.0) , proxy server not set.
002010:0000 Optical drive "BD-RE ASUS BW-16D1X-U A104d" opened in OS access mode.
005075:0000 The new version 1.17.5 is available for download at http://www.makemkv.com/download/
003338:0000 Downloading latest SDF to /Users/Patrick/Library/MakeMKV ...
003339:0000 Automatic SDF downloading is disabled or failed.
001003:0020 DEBUG: Code 152 at F\*z(O*2XK(Bc\ko:29407638
No  SDF v07f: ASUS_BW-16D1X-U_A104_211901041047_KLBJALA2806
SDF id v07f: ASUS_BW-16D1X-U_A104_211901041047_KLBJALA2806
SDF auto v07f: ASUS_BW-16D1X-U_A104_211901041047_KLBJALA2806
SDFW: DEBUG: Code 4278525958 at dw|GL&h^ZC,QM-c,P7p%U=3B)s oHO}.:213130927
DEBUG: Code 0 at n!ysZ^DeG<7@Ht`+Y:213132284
DEBUG: Code 0 at `PDP'Y<E4nRZuR)7:121268604
DEBUG: Code 2147483648 at F\*z(O*2XK(Bc\ko:121264786
003310:0000 This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?XUIBeaO95Q6pFLd8hb8WVf7eHItuuPkhjCYeKk+S1AJQVJeaK0AgqRP0d6qWCB39RqTl36uJqpNi+u1sjaof8b2Lainbr9OHKtwnx/C9gt7wbVZI7bOtBz2RzLFiGMG2KCDGuZqwGb407fymhcvpTI4LQvey0JA9jWd5VECevvNaUYeq+rrL69dcNxLxyq6eNNnH7zpEFFnY4/Nul9i5F1FLSAuaduY0FFPBJ/madFSi5S4izGHtdU0d/dBTYblqaFPVoELwaeYRF/CmOjyLf0BcMXUd3jR/tfiEqfdIFj9zYtDlFuMTv9bIjvvccBcdo1bf2D/8Bw63UKD1WdSPrie+AKKX9bxoZV/hwK3jMyv3Te5Z9pbdTRkPD2XDjEW8lHujQSlviwwNszNWKl8uJHiIZXWBGqPfBCFMtOJIBM4Hni/PSWtde7qUDzyDDSgBuLAlmZ2D25Z+6SjyL+xsKFvapkfTPc4Wd79Mzy7u
DAFD=PAAAADAAAAEABDQkEHwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AFC19F3902AE726CB29D19BFD3EF3DC5C7 to device 'IoKit:/IOBDServices/552FB30B'
001003:0020 DEBUG: Code 0 at 1}e{60h#NWE.(-?fL:213130766
001003:0020 DEBUG: Code 0 at ;/r"4w}sE<4m}'!|I':213131824
001003:0020 DEBUG: Code 0 at ;/r"4w}sE<4m}'!|I':29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03121AFDA18DEC6F7436673530B0BA9AC97 to device 'IoKit:/IOBDServices/552FB30B'
001003:0020 DEBUG: Code 1 at ;/r"4w}sE<4m}'!|I':29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06C486B513CF93760B2651CDEDA4F4920A6 to device 'IoKit:/IOBDServices/552FB30B'
001003:0020 DEBUG: Code 2 at ;/r"4w}sE<4m}'!|I':29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BC36926BFC3986DBBD0C86CE5766E8DABC to device 'IoKit:/IOBDServices/552FB30B'
001003:0020 DEBUG: Code 3 at ;/r"4w}sE<4m}'!|I':29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0342FF3AD263608DF23ED5D952D0C282F36 to device 'IoKit:/IOBDServices/552FB30B'
001003:0020 DEBUG: Code 4 at ;/r"4w}sE<4m}'!|I':29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C3717029AF6D8C7DAC1D06568D428D36AD to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C2FC77459647D6776618DFE6F75105B921 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08564D6680BABAEDAC3173267A0E6C5789A to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00D6EC7CA1D19ECE00EAC8458CFFA07F9C6 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04E4AE2A030221D01D5C53C56994D13919A to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BB13166FDD212B27CFC4CF9C49DA9F9A8B to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02868E9EB867F7B70BDB1F365F07E18FB11 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03D9AA313F54E6C0625F10070161D5DFAFF to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08BECBBD070579DA52D7C64DED7101549EC to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C2ADBE30679EC3DC80E679420A0C02C178 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01A0F1FE0E4C1E50D8E95C488183D873EA5 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BB47D72FA025FBAF5C7EA989B2DBA5FB39 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0177B22FD7E348C177BCD9150AADA9DD252 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B14798AF0D007A6AB413FB0828192116BC to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A3391A9DA544555B2EE31107977BB262EC to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D0D00738BFA942B6BFD36CD4DEDE9A01CA to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/552FB30B'
DEBUG: Code 0 at 1}e{60h#NWE.(-?fL:213130306
001003:0020 DEBUG: Code 0 at ;/r"4w}sE<4m}'!|I':29396552
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E2969BDF9DD982BCECF9543F352B786D59 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E7123E2F1A2A0878F830D35E3110F1ABB0 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..079DC83D44A591E4763D6AE5F9A8E14B70D to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05E714FEB1316CB7C43D1D9C44F83EABCC0 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0857EC49A7DE52CB7D2DA779BA4CC0E3585 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03D6F80DF77060180CAB1C0473F36F18A75 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B7B4CF89199BC5C469E421A012222C8A27 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0DBF2C65DA12BCEB26383D57FF23FA0FB3A to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..006B80D64EC37B3DF8DC532C02558FFD111 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..038585ACE983A25E1C82DEF4C0DB1CFEB6D to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00F9FA1DD20F9C4E2E9DCE95A142FBBB259 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08B71E071EB10BA903062B41F3C081DDB3F to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D13BA80D4805417C4BAFBFEAF71D953668 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0DD81D73C5893BE4F15FACA7DAA387A1C74 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E00403BB15FE42176633359F3802738D0C to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01D47F8DA855D896FE9F25CF2785668E2A9 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A9EBFF35E1E4560B56EE2183264038A06E to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..081E2DDC226807681A1838EDBF5660FF677 to device 'IoKit:/IOBDServices/552FB30B'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0771DE160799EB3A3C6AD87CC8A098A1AC9 to device 'IoKit:/IOBDServices/552FB30B'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
001003:0020 DEBUG: Code 233 at ygoRN14xBjc3iUXkYj3tCpQ7:0
001003:0020 DEBUG: Code 233 at Y/O/88akjG0/MrTqiY9cUqVX:0
001003:0020 DEBUG: Code 233 at m/Xg1gNFGOEa5KpBrl27MZiw:0
001003:0020 DEBUG: Code 233 at iooJBlID+bh5bLL/ouOd8NiJ:0
001003:0020 DEBUG: Code 233 at o3gzNxd4hNFNuGo9aHA27LQA:0
001003:0020 DEBUG: Code 233 at Thoa/oPoUIGCqf347Xvjdc3y:0
001003:0020 DEBUG: Code 233 at /pEulr8bAb3O4ll/aAoVKUGK:0
001003:0020 DEBUG: Code 233 at 1j5doRtMj/IGMfPZSfjI581y:0
001003:0020 DEBUG: Code 233 at 0kcNly9sQK31Bj6vH35F/f0r:0
001003:0020 DEBUG: Code 233 at EuubCF8Era1ORDMydoZte03v:0
001003:0020 DEBUG: Code 233 at NF98X1QYLYgouscMXRnAJ2BH:0
001003:0020 DEBUG: Code 233 at PoKjSC23vHKijaia4r2PZxM1:0
001003:0020 DEBUG: Code 233 at pKOgQ75rDsY1YjexoMs9cBrI:0
001003:0020 DEBUG: Code 233 at 0iiNr4yc7tyWd633eg4Izl60:0
001003:0020 DEBUG: Code 233 at HpFTa0X6Z13VXvDV+OuNF1tr:0
001003:0020 DEBUG: Code 233 at 5CYa8B6+gl/8bhbeX6s/+PqY:0
001003:0020 DEBUG: Code 233 at cqN8FLpTEBHc2jr1x0+Qpcjw:0
001003:0020 DEBUG: Code 233 at IUu2oBC+6nt1MI00hMTFEDH1:0
001003:0020 DEBUG: Code 233 at Jh4/nXTPSEdUwiMLW3LTWFLR:0
001003:0020 DEBUG: Code 233 at idgM6zOO4XmYrveGQjyVg7pW:0
001003:0020 DEBUG: Code 233 at ulL88x0QlGpvRyn1Z9kIE6dC:0
001003:0020 DEBUG: Code 233 at 43xg958jFhUQwMgxlUnXQ3xf:0
Re: Asus BW-16D1X-U
#95 Post by dcoke22 » Thu Dec 28, 2023 3:35 am
That might mean you have internet access turned off in MakeMKV's preferences. Or it might mean something is blocking you from contacting MakeMKV's servers.
https://forum.makemkv.com/forum/viewtopic.php?p=141837#p141837
Also, your ASUS is not properly flashed to be a LibreDrive. On the Mac, you can do the necessary flashing in a Terminal window. The Ultimate UHD Drives Flashing Guide has instructions on how to do this. You will have to flash your drive to be able to rip 4K discs. It isn't strictly necessary to be able to rip most blu-rays, but earlier error message about SDF downloading is not helping you.
Doom Maestro
Re: Asus BW-16D1X-U
#96 Post by Doom Maestro » Sat Dec 30, 2023 10:40 am
Hi, I have been looking at the forums for a while, but I am new to flashing to be able to use my drive as a 4K ripping drive if possible.
Drive Information for MAKEMKV
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Highest AACS version: 81
Drive Platform: MT1959
I know very little overall.
I know the drive platform must be MT1959, and I have seen some drives similar people have said worked for ripping 4K after flashing, but I want to make sure mine is capable and I won't mess it up.
I purchased this in 2021 and it says Manufactured Apr. 2022.
Doom Maestro
Re: Asus BW-16D1X-U
#97 Post by Doom Maestro » Sat Dec 30, 2023 8:59 pm
sorry purchases 2022 my b spelling mishap
jdevil
Re: Asus BW-16D1X-U
#98 Post by jdevil » Tue Jan 16, 2024 12:52 am
hi im new here, i just recently bought one of these drives a week ago and i just now flashed it to DE_ASUS_BC-12D2HT_3.11_MK but i read in this thread that HL-DT-ST-BD-RE_WH16NS60-1.03 is better to flash this drive with, my issue is that when i try to flash 1.03 sdf tool says it worked but makemkv still shows the asus 3.11 firmware. is there something im missing here or is it honestly that much better than the 3.11 firmware?
Re: Asus BW-16D1X-U
#99 Post by Billycar11 » Tue Jan 16, 2024 1:02 am
jdevil wrote: Tue Jan 16, 2024 12:52 am hi im new here, i just recently bought one of these drives a week ago and i just now flashed it to DE_ASUS_BC-12D2HT_3.11_MK but i read in this thread that HL-DT-ST-BD-RE_WH16NS60-1.03 is better to flash this drive with, my issue is that when i try to flash 1.03 sdf tool says it worked but makemkv still shows the asus 3.11 firmware. is there something im missing here or is it honestly that much better than the 3.11 firmware?
enc
jdevil
Re: Asus BW-16D1X-U
#100 Post by jdevil » Tue Jan 16, 2024 1:27 am
Billycar11 wrote: Tue Jan 16, 2024 1:02 am
enc
hi, i just tried it by checking enc, for some reason i thought it was telling me it didnt need it, but with that said it still shows im on 3.11 after doing it.
Re: Asus BW-16D1X-U
#101 Post by MartyMcNuts » Tue Jan 16, 2024 1:38 am
jdevil wrote: Tue Jan 16, 2024 1:27 am
enc
If you ever want to write a disc, leave it as is.
Also, for some reason this model has always been difficult to cross-flash. That's why I always recommend the firmware you are currently on.
jdevil
Re: Asus BW-16D1X-U
#102 Post by jdevil » Tue Jan 16, 2024 1:40 am
MartyMcNuts wrote: Tue Jan 16, 2024 1:38 am
enc
oh so will flashing to 1.03 will make it where i cant write discs? if thats the case never mind im good lol. thanks for the quick replies though yall.
Hefeweizen
Re: Asus BW-16D1X-U
#103 Post by Hefeweizen » Sun Feb 04, 2024 2:27 am
Just sticking my head in here. I got the Asus BW-16D1X-U and flashed it with the SDFTool flasher using DE_ASUS_BW-16D1HT_3.10_MK and it works like a champ. Just loaded up the new Army of Darkness 4k and I'm good to go.
ScoopKona
Re: Asus BW-16D1X-U
#104 Post by ScoopKona » Wed Feb 21, 2024 2:29 am
Billycar11 wrote: Fri Mar 24, 2023 11:56 pmSee guide
First post. Just wanted to say thanks.
I bought an ASUS drive based on information I read here. Flashed without issue -- backwards from 3.11 which is what ASUS is shipping these days.
After ripping a few discs to eliminate some variables, I flashed the drive. All is well.
Czero101
Re: Asus BW-16D1X-U
#105 Post by Czero101 » Thu May 02, 2024 1:28 pm
Hi all, new guy on the block here :D
Recently picked up an Asus BW-16D1X-U from Amazon.ca, July '23 build, A105 fw, MT1959 platform. Found my way here and thanks to a lot of informative posts I was able to flash my drive to the Asus 3.10 fw and the drive is now happily reading UHD's.
Just wanted to say thanks to all those here before me for their experiences and information.
Cz
