LibreDrive for Pioneer drives
mankr1981@gmail.com wrote: Sat Aug 05, 2023 5:18 am could someone help with this drive
OS device name: E:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO7M2QA1409
Bus encryption flags: 1F
Highest AACS version: 68
Harware support: Yes
Firmware support: No
Firmware version: 1.02
see guide below or email me or Marty for an automated flasher
imacmike
Post by imacmike »
Any chance my very old but robust tank of a BDXL drive might get support?
Manufacturer: PIONEER
Product: BD-RW BDR-XD04
Revision: 1.00
Firmware date: 2011-11-22
Bus encryption flags: 13
Highest AACS version: 78
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS8130
Firmware version: GENE
imacmike wrote: Sat Aug 05, 2023 4:54 pm Any chance my very old but robust tank of a BDXL drive might get support?
Revision: 1.00
definitely no UHD support ever
Libredrive maybe as it says but likely not.
mankr1981@gmail.com
Post by mankr1981@gmail.com »
Thanks for the reply.
But not quite following completely, mine is already on 1.02, not sure which flash version/type to use?
Per my drive model, should I be using > LG slim BU40N -> HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
mankr1981@gmail.com wrote: Sat Aug 05, 2023 5:18 pm Thanks for the reply.
If you can't follow the guide I recommend buying an automated flasher me and Marty both sell them
mankr1981@gmail.com
actaully I was successfully able to flash but now I get error while playing
Blu-ray error:
This Blu-ray Disc needs a library for AACS decoding, and your system does not have it.
Your input can't be opened:
VLC is unable to open the MRL 'bluray:///E:\'. Check the log for details.
PowerDVD is able to load but no video.
logs for flash
Reading input file D:\Downloads\mkv\LG-slim-BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO7M2QA1409
100% Operation finished
Done successfully
mankr1981@gmail.com wrote: Sat Aug 05, 2023 6:22 pm actaully I was successfully able to flash but now I get error while playing
Blu-ray error:
logs for flash
Done successfully
likely not getting hk because your dns is bad or your firewall blocks Russia
also why are you talking about flashing lg drives in the pioneer section.
mankr1981@gmail.com
sorry is there a lg thread, I can post there
but didnt get this - likely not getting hk because your dns is bad or your firewall blocks Russia
hk?
dns - why dns is bad?
you mean codec is getting downloaded from russia?
Why is DNS bad? Because some outfits decided to screw up DNS replies for "unapproved" outfits.
The DNS entry MakeMKV uses for LibreDrive is one of those outfits. So SOME machines cannot get an IP when they ask for it. Change your DNS server entry, and, just as suddenly, it works.
tommik128
Post by tommik128 »
andrewtjb wrote: Sun Feb 13, 2022 1:45 pmIt's been updated here's the link https://pioneer.jp/cgi-bin/device/downl ... W154EU.exe
Hi guys, I have the Pioneer 209 EBK (209-M) and the current firmware is only 1.34/ID60. It is probably perfect for MakeMKV but I would like to upgrade the drive since it will be used as a burner as well. Is that 1.54 firmware still safe for MakeMKV? (I guess it might be since that firmware should be quite old - 2020?).
tommik128 wrote: Wed Aug 09, 2023 2:40 pm
Do not update no reason for it
MrEJ42
Post by MrEJ42 »
I just installed MakeMKV, but this is the info it gives me. I sent the firmware dump to support@makemkv.com. This says December, so does that mean I'm out of luck?
OS device name: G:
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: [Redacted]
Firmware date: 2022-12-27
Highest AACS version: 61
Drive platform: Pioneer RS9331
Firmware version: ID05
MrEJ42 wrote: Wed Aug 09, 2023 5:44 pm I just installed MakeMKV, but this is the info it gives me. I sent the firmware dump to support@makemkv.com. This says December, so does that mean I'm out of luck?
OS device name: G:
Revision: 1.02
Yup out of luck until pioneer libredrive v2
super__squirrel
Post by super__squirrel »
Is that the same for the drive below - I am more than willing to pay for a flash.
OS device name: E:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CEDL006852WL
Firmware date: 2023-01-06
Highest AACS version: 76
Billycar11 wrote: Wed Aug 09, 2023 6:20 pm Yup out of luck until pioneer libredrive v2
Yes. You also have to wait.
