Reset your c2 is showing mp4 7 profil dolby vision with this new version mp4 muxer ?RESET_9999 wrote: ↑Thu Aug 03, 2023 2:09 pmIt also works well on my C2 but the 2018 or older TV are more picky in regard of DV MP4.
if anyone with old LG TVs could test the latest beta script, workflows 7-2, that would be great. You have to update the mp4muxer.exe by the one from here: https://github.com/bbeny123/mp4muxer
Since the 1.3.2-alpha3 version seems to be fully stable, I released it as 1.3.2
https://github.com/bbeny123/mp4muxer/releases/tag/1.3.2
Version 1.3.2 differs from 1.3.1 in that for DV profiles > 7 the codec configuration box is set to dvcC instead of dvvC (mp4box_64bits 1.0.0 also set dvcC).
This is non-compliant with Dolby's documentation, but as we can see Oppo and older LG TVs are also non-compliant (as only this setting works on them).
No, LG dropped P7 support since the CX. I was talking about P8 and P5.
Is there a way to tell what resolution video an RPU came from/what resolution an RPU is intended for? Like if I have a p5 RPU but not the source p5 video, and a HDR10 Blu-ray BL to inject the RPU into - how do I know if black bars should be cropped or not (on some p5 videos the video is 16:9 with black bars in the stream, some p5 will have just the video in whatever resolution/aspect ratio with no black bars)? Like a specific line/variable to look for in the json/RPU?
Everything about the rpu aspect ratio(active area) is in Level 5staknhalo wrote: ↑Sun Aug 06, 2023 1:30 amIs there a way to tell what resolution video an RPU came from/what resolution an RPU is intended for? Like if I have a p5 RPU but not the source p5 video, and a HDR10 Blu-ray BL to inject the RPU into - how do I know if black bars should be cropped or not (on some p5 videos the video is 16:9 with black bars in the stream, some p5 will have just the video in whatever resolution/aspect ratio with no black bars)? Like a specific line/variable to look for in the json/RPU?
If the BL is 16:9 with no black bars or if it is cropped, L5 should always be 0 regardless of the base layer resolution.
if the new BL has black bars, you measure them and edit L5 accordingly.
Got it thanksRESET_9999 wrote: ↑Sun Aug 06, 2023 2:08 amEverything about the rpu aspect ratio(active area) is in Level 5staknhalo wrote: ↑Sun Aug 06, 2023 1:30 amIs there a way to tell what resolution video an RPU came from/what resolution an RPU is intended for? Like if I have a p5 RPU but not the source p5 video, and a HDR10 Blu-ray BL to inject the RPU into - how do I know if black bars should be cropped or not (on some p5 videos the video is 16:9 with black bars in the stream, some p5 will have just the video in whatever resolution/aspect ratio with no black bars)? Like a specific line/variable to look for in the json/RPU?
So I never really figured out what was wrong with my setup that was keeping me from converting TrueHD Atmos to DD+, but I think I figured out a way to get around it.
My setup can only handle lossy 5.1 Atmos over ARC anyway, so for movies where audio like that (or even just 5.1 surround or lesser) is available, I want to make a Frankenstein .MP4 file of a profile 7 DT-DL DV stream and whatever lossy audio I find. That should play in DV on my LG E8. I know I'll need to use MP4Muxer at the end but uh, how would I do that? Specifically, should I demux the P7 DT-DL DV stream from the original file (which in this case contains a TrueHD audio stream that would break DV on my LG E8), the lossy audio from whatever other file, and mux them together with MP4Muxer? I guess my real obstacle is properly demuxing everything, and finding out what command exactly I should enter in MP4Muxer. Any guidance would be much appreciated.
In short, the file I'm imagining would be a .MP4 file containing BL+EL+RPU profile 7 DT-DL Dolby Vision, and lossy audio topping out at 5.1 DD+ Atmos.
Amateur enthusiast
LG E8 55” ——-> Vizio M512A-H6
Thanks! But I noticed, the --dvh1flag option is not working. This would be necessary for playback on Apple TV (with tvOS 17). Can you fix it?bbeny123 wrote: ↑Sat Aug 05, 2023 1:54 pmSince the 1.3.2-alpha3 version seems to be fully stable, I released it as 1.3.2
This solution works until: https://github.com/rixtox/mp4dovi
Since its introduction, the '--dvh1flag {trackId}' flag has only worked with DV profiles: 1, 3 or 5. I have lifted this restriction.NiCE77 wrote: ↑Sun Aug 06, 2023 8:44 amThanks! But I noticed, the --dvh1flag option is not working. This would be necessary for playback on Apple TV (with tvOS 17). Can you fix it?
Version 1.3.3: https://github.com/bbeny123/mp4muxer/releases/tag/1.3.3
but why use the mp4muxer at all for ATV or new TV (2019+) when mp4box can mux directly lossless audio + subs + chapter?NiCE77 wrote: ↑Sun Aug 06, 2023 8:44 am
Please share the file "SDR_heatmap.cube".
Hi @RESET_9999! When using the 6-8-3 option with video 1 (HDR10) and video 2 (DV-P5) we get these screenshots, you can see that tonemapping is applied to video 2 (DV-P5).
unless you're using an older version of the script, the latest ones no longer tonemap to SDR for 6-8-3.Lapihin_A wrote: ↑Sun Aug 06, 2023 4:42 pmHi @RESET_9999! When using the 6-8-3 option with video 1 (HDR10) and video 2 (DV-P5) we get these screenshots, you can see that tonemapping is applied to video 2 (DV-P5).
if you're using the latest beta, are you sure it's not just your two sources that are different?
I know some BCORE webdl are incorrectly flagged as a ''full range'' which messes up the black levels.
https://drive.google.com/file/d/1Ix3JT6 ... drive_link
I used your script of the latest version of "DoVi_Scripts_1.9.0.2.beta_MKV" at the moment.RESET_9999 wrote: ↑Sun Aug 06, 2023 5:00 pmunless you're using an older version of the script, the latest ones no longer tonemap to SDR for 6-8-3.Lapihin_A wrote: ↑Sun Aug 06, 2023 4:42 pmHi @RESET_9999! When using the 6-8-3 option with video 1 (HDR10) and video 2 (DV-P5) we get these screenshots, you can see that tonemapping is applied to video 2 (DV-P5).
SiC's BCORE video was used, which has no contrast problem unlike ROCCaT's BCORE.
General
Unique ID : 83590475605974953443278668065443810502 (0x3EE2F0A411F5477A6A2AAA890CB20CC6)
Complete name : Escape.Room.2019.2160p.BCORE.WEB-DL.DTS-HD.MA.5.1.HDR.HEVC-SiC.mkv
Format : Matroska
Format version : Version 4
File size : 57.2 GiB
Duration : 1 h 39 min
Overall bit rate mode : Variable
Overall bit rate : 82.2 Mb/s
Frame rate : 23.976 FPS
Writing application : mkvmerge v13.0.0 ('Sharing is Caring') 64-bit
Writing library : libebml v1.0.0 + libmatroska v1.1.1
Video
Format : HEVC
Format profile : Main 10@L5.2@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 3876 cd/m2
Maximum Frame-Average Light Level : 852 cd/m2
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Delay relative to video : 2 ms
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Title : SDH
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Language : Arabic
Default : No
Forced : No
Text #4
Format : UTF-8
Language : Cantonese
Default : No
Forced : No
Text #5
Format : UTF-8
Title : Simplified
Language : Chinese-cmn-simple
Default : No
Forced : No
Text #6
Format : UTF-8
Title : Traditional
Language : Mandarin
Default : No
Forced : No
Text #7
Format : UTF-8
Language : Croatian
Default : No
Forced : No
Text #8
Format : UTF-8
Language : Czech
Default : No
Forced : No
Text #9
Format : UTF-8
Language : Danish
Default : No
Forced : No
Text #10
Format : UTF-8
Language : Dutch
Default : No
Forced : No
Text #11
Format : UTF-8
Language : Finnish
Default : No
Forced : No
Text #12
Format : UTF-8
Language : French
Default : No
Forced : No
Text #13
Format : UTF-8
Language : German
Default : No
Forced : No
Text #14
Format : UTF-8
Language : Greek
Default : No
Forced : No
Text #15
Format : UTF-8
Language : Hebrew
Default : No
Forced : No
Text #16
Format : UTF-8
Language : Hungarian
Default : No
Forced : No
Text #17
Format : UTF-8
Language : Icelandic
Default : No
Forced : No
Text #18
Format : UTF-8
Language : Indonesian
Default : No
Forced : No
Text #19
Format : UTF-8
Language : Italian
Default : No
Forced : No
Text #20
Format : UTF-8
Language : Korean
Default : No
Forced : No
Text #21
Format : UTF-8
Language : Norwegian
Default : No
Forced : No
Text #22
Format : UTF-8
Language : Polish
Default : No
Forced : No
Text #23
Format : UTF-8
Title : Brazilian
Language : Portuguese (BR)
Default : No
Forced : No
Text #24
Format : UTF-8
Title : Iberian
Language : Portuguese (PT)
Default : No
Forced : No
Text #25
Format : UTF-8
Language : Romanian
Default : No
Forced : No
Text #26
Format : UTF-8
Language : Russian
Default : No
Forced : No
Text #27
Format : UTF-8
Title : Castilian
Language : Spanish (ES)
Default : No
Forced : No
Text #28
Format : UTF-8
Language : Swedish
Default : No
Forced : No
Text #29
Format : UTF-8
Language : Thai
Default : No
Forced : No
Text #30
Format : UTF-8
Language : Ukrainian
Default : No
Forced : No
Text #31
Format : UTF-8
Language : Vietnamese
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:04:35.025 : en:Chapter 2
00:09:24.647 : en:Chapter 3
00:14:07.764 : en:Chapter 4
00:19:45.101 : en:Chapter 5
00:25:54.219 : en:Chapter 6
00:33:07.944 : en:Chapter 7
00:37:26.161 : en:Chapter 8
00:43:04.081 : en:Chapter 9
00:50:05.169 : en:Chapter 10
00:53:57.568 : en:Chapter 11
01:03:14.290 : en:Chapter 12
01:09:06.893 : en:Chapter 13
01:16:13.694 : en:Chapter 14
01:22:47.754 : en:Chapter 15
01:30:26.880 : en:Chapter 16
