valington
Post by valington » Sat Aug 05, 2023 1:39 pm
RESET_9999 wrote:
Thu Aug 03, 2023 2:09 pm
bbeny123 wrote:
Wed Aug 02, 2023 2:15 pm
Nope, I've tested LG C9 only.
It also works well on my C2 but the 2018 or older TV are more picky in regard of DV MP4.
if anyone with old LG TVs could test the latest beta script, workflows 7-2, that would be great. You have to update the mp4muxer.exe by the one from here: https://github.com/bbeny123/mp4muxer
Reset your c2 is showing mp4 7 profil dolby vision with this new version mp4 muxer ?
Chisum04
Post by Chisum04 » Sat Aug 05, 2023 1:40 pm
bbeny123 wrote:
Sat Aug 05, 2023 9:12 am
Could you please check out version 1.3.2-alpha3? It should work with Oppo (and older LG TVs) and have the codec set correctly to 'dvhe'.
Worked! Perfect.
bbeny123
Post by bbeny123 » Sat Aug 05, 2023 1:54 pm
Since the 1.3.2-alpha3 version seems to be fully stable, I released it as 1.3.2 :)
https://github.com/bbeny123/mp4muxer/releases/tag/1.3.2
Version 1.3.2 differs from 1.3.1 in that for DV profiles > 7 the codec configuration box is set to dvcC instead of dvvC (mp4box_64bits 1.0.0 also set dvcC).
This is non-compliant with Dolby's documentation, but as we can see Oppo and older LG TVs are also non-compliant (as only this setting works on them).
Post by RESET_9999 » Sat Aug 05, 2023 1:57 pm
No, LG dropped P7 support since the CX. I was talking about P8 and P5.
staknhalo
Post by staknhalo » Sun Aug 06, 2023 1:30 am
Is there a way to tell what resolution video an RPU came from/what resolution an RPU is intended for? Like if I have a p5 RPU but not the source p5 video, and a HDR10 Blu-ray BL to inject the RPU into - how do I know if black bars should be cropped or not (on some p5 videos the video is 16:9 with black bars in the stream, some p5 will have just the video in whatever resolution/aspect ratio with no black bars)? Like a specific line/variable to look for in the json/RPU?
Post by RESET_9999 » Sun Aug 06, 2023 2:08 am
Everything about the rpu aspect ratio(active area) is in Level 5
If the BL is 16:9 with no black bars or if it is cropped, L5 should always be 0 regardless of the base layer resolution.
if the new BL has black bars, you measure them and edit L5 accordingly.
staknhalo
Post by staknhalo » Sun Aug 06, 2023 2:49 am
Got it thanks
UNSCTrafalgar
Post by UNSCTrafalgar » Sun Aug 06, 2023 6:50 am
So I never really figured out what was wrong with my setup that was keeping me from converting TrueHD Atmos to DD+, but I think I figured out a way to get around it.
My setup can only handle lossy 5.1 Atmos over ARC anyway, so for movies where audio like that (or even just 5.1 surround or lesser) is available, I want to make a Frankenstein .MP4 file of a profile 7 DT-DL DV stream and whatever lossy audio I find. That should play in DV on my LG E8. I know I'll need to use MP4Muxer at the end but uh, how would I do that? Specifically, should I demux the P7 DT-DL DV stream from the original file (which in this case contains a TrueHD audio stream that would break DV on my LG E8), the lossy audio from whatever other file, and mux them together with MP4Muxer? I guess my real obstacle is properly demuxing everything, and finding out what command exactly I should enter in MP4Muxer. Any guidance would be much appreciated.
In short, the file I'm imagining would be a .MP4 file containing BL+EL+RPU profile 7 DT-DL Dolby Vision, and lossy audio topping out at 5.1 DD+ Atmos.
Amateur enthusiast 8)
LG E8 55” ——-> Vizio M512A-H6
NiCE77
Post by NiCE77 » Sun Aug 06, 2023 8:44 am
Thanks! But I noticed, the --dvh1flag option is not working. This would be necessary for playback on Apple TV (with tvOS 17). Can you fix it?
This solution works until: https://github.com/rixtox/mp4dovi
bbeny123
Post by bbeny123 » Sun Aug 06, 2023 11:20 am
Since its introduction, the '--dvh1flag {trackId}' flag has only worked with DV profiles: 1, 3 or 5. I have lifted this restriction.
Version 1.3.3: https://github.com/bbeny123/mp4muxer/releases/tag/1.3.3
Post by RESET_9999 » Sun Aug 06, 2023 11:42 am
but why use the mp4muxer at all for ATV or new TV (2019+) when mp4box can mux directly lossless audio + subs + chapter?
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 3:22 pm
Please share the file "SDR_heatmap.cube".
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 4:42 pm
Hi @RESET_9999! When using the 6-8-3 option with video 1 (HDR10) and video 2 (DV-P5) we get these screenshots, you can see that tonemapping is applied to video 2 (DV-P5).
Post by RESET_9999 » Sun Aug 06, 2023 5:00 pm
unless you're using an older version of the script, the latest ones no longer tonemap to SDR for 6-8-3.
if you're using the latest beta, are you sure it's not just your two sources that are different?
I know some BCORE webdl are incorrectly flagged as a ''full range'' which messes up the black levels.
https://drive.google.com/file/d/1Ix3JT6 ... drive_link
Lapihin_A
Post by Lapihin_A » Sun Aug 06, 2023 5:10 pm
I used your script of the latest version of "DoVi_Scripts_1.9.0.2.beta_MKV" at the moment.
SiC's BCORE video was used, which has no contrast problem unlike ROCCaT's BCORE.
General
Unique ID                                : 83590475605974953443278668065443810502 (0x3EE2F0A411F5477A6A2AAA890CB20CC6)
Complete name                            : Escape.Room.2019.2160p.BCORE.WEB-DL.DTS-HD.MA.5.1.HDR.HEVC-SiC.mkv
File size                                : 57.2 GiB
Duration                                 : 1 h 39 min
Overall bit rate                         : 82.2 Mb/s
Frame rate                               : 23.976 FPS
Writing application                      : mkvmerge v13.0.0 ('Sharing is Caring') 64-bit
Writing library                          : libebml v1.0.0 + libmatroska v1.1.1
Video
Format profile                           : Main 10@L5.2@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Maximum Content Light Level              : 3876 cd/m2
Maximum Frame-Average Light Level        : 852 cd/m2
Audio
Format                                   : DTS XLL
Commercial name                          : DTS-HD Master Audio
Channel layout                           : C L R Ls Rs LFE
Bit depth                                : 16 bits
Delay relative to video                  : 2 ms
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Text #2
Format                                   : UTF-8
Title                                    : SDH
Text #3
Format                                   : UTF-8
Language                                 : Arabic
Text #4
Format                                   : UTF-8
Language                                 : Cantonese
Text #5
Format                                   : UTF-8
Title                                    : Simplified
Language                                 : Chinese-cmn-simple
Text #6
Format                                   : UTF-8
Title                                    : Traditional
Language                                 : Mandarin
Text #7
Format                                   : UTF-8
Language                                 : Croatian
Text #8
Format                                   : UTF-8
Language                                 : Czech
Text #9
Format                                   : UTF-8
Language                                 : Danish
Text #10
Format                                   : UTF-8
Language                                 : Dutch
Text #11
Format                                   : UTF-8
Language                                 : Finnish
Text #12
Format                                   : UTF-8
Language                                 : French
Text #13
Format                                   : UTF-8
Language                                 : German
Text #14
Format                                   : UTF-8
Language                                 : Greek
Text #15
Format                                   : UTF-8
Language                                 : Hebrew
Text #16
Format                                   : UTF-8
Language                                 : Hungarian
Text #17
Format                                   : UTF-8
Language                                 : Icelandic
Text #18
Format                                   : UTF-8
Language                                 : Indonesian
Text #19
Format                                   : UTF-8
Language                                 : Italian
Text #20
Format                                   : UTF-8
Language                                 : Korean
Text #21
Format                                   : UTF-8
Language                                 : Norwegian
Text #22
Format                                   : UTF-8
Language                                 : Polish
Text #23
Format                                   : UTF-8
Title                                    : Brazilian
Language                                 : Portuguese (BR)
Text #24
Format                                   : UTF-8
Title                                    : Iberian
Language                                 : Portuguese (PT)
Text #25
Format                                   : UTF-8
Language                                 : Romanian
Text #26
Format                                   : UTF-8
Language                                 : Russian
Text #27
Format                                   : UTF-8
Title                                    : Castilian
Language                                 : Spanish (ES)
Text #28
Format                                   : UTF-8
Language                                 : Swedish
Text #29
Format                                   : UTF-8
Language                                 : Thai
Text #30
Format                                   : UTF-8
Language                                 : Ukrainian
Text #31
Format                                   : UTF-8
Language                                 : Vietnamese
Menu
00:00:00.000                             : en:Chapter 1
00:04:35.025                             : en:Chapter 2
00:09:24.647                             : en:Chapter 3
00:14:07.764                             : en:Chapter 4
00:19:45.101                             : en:Chapter 5
00:25:54.219                             : en:Chapter 6
00:33:07.944                             : en:Chapter 7
00:37:26.161                             : en:Chapter 8
00:43:04.081                             : en:Chapter 9
00:50:05.169                             : en:Chapter 10
00:53:57.568                             : en:Chapter 11
01:03:14.290                             : en:Chapter 12
01:09:06.893                             : en:Chapter 13
01:16:13.694                             : en:Chapter 14
01:22:47.754                             : en:Chapter 15
01:30:26.880                             : en:Chapter 16
