bobbymkV
Post by bobbymkV » Thu Aug 03, 2023 8:05 pm
EncodeThis420 wrote:
Thu Aug 03, 2023 5:08 pm
RESET_9999 wrote:
Thu Aug 03, 2023 4:49 pm
Thu Aug 03, 2023 2:38 pm
Sorry to reply to you directly but would you able to confirm my question on profile 8 hybrids? I can't find a diffinitive answer and it seems like EVERYONE is encoding with profile 8 hybrid formats now. I'm not seeing ANY native profile 5 formats any longer :-/. Do you see this as an issue? This is in reference to P5 streams combined with hdr10/+ streams, not hdr10 blurays that are combined with a p5 stream.
making p8 hybrid is not an issue as long as you make sure the P5 and HDR10 encode are the same brightness/master. I have a huge excel sheet about it in my signature.
Most of the p2p or scene groups make hybrid without checking any of this and it is a problem especially if they are not going to release the profile 5 source which seems to happen more frequently lately.
While most of the time, the P5 and HDR10 encode are from the same source/master, it doesn't mean it will always be the same, and making hybrid releases blindly is wrong.
And sometimes studios decide to deliver different trim pass even though it's from the same master.
two examples I came across recently:
Black Widow profile 5 iMAX is much brighter than the HDR10 IMAX web-dl: https://slow.pics/c/zzHW5Qhv
And recently Hot Pursuit (which FLUX only released hybrid P8): https://slow.pics/c/37t2bB4J
Thanks. This is kind of what I was afraid of. There's really no way (for a normal person like myself) to tell whether a "hybrid" encode was done properly. I'm basically seeing ONLY hybrid files for all new streaming shows being encoded. These encoders are not posting the original profile 5 sources which is absolutely infuriating. I rather just grab P5 versions so that I know that it has the correct brightness. Why in the world are people not doing this? What changed? Is there any possible way to like "reverse engineer" these files to split back out the p5 stream? or is that impossible?
I stopped grabbing p8 hybrids earlier this year when I learned all of this. There is really only one uploader that I trust.
EncodeThis420
Post by EncodeThis420 » Thu Aug 03, 2023 8:43 pm
Is there any way that you could share which uploader you trust? Not sure of the rules here or if you can even send private messages. Feel free to decline if I am crossing a line.
But yea. I just don't understand it.....uploaders who used to upload source P5 materials just randomly all switched to uploading P8 files. I have no idea what happened. I legit cannot find any P5 files of recent streamed shows. They're literally all P8 lol. If they know that P8 files are bad form....then why do they keep doing it?
skull88
Post by skull88 » Thu Aug 03, 2023 9:36 pm
I suggest this is better to be taken offline into private discussion. My suggestion is just consider paying to watch on your favourite streaming platform, if the possibility of poor DV metadata bothers you this much from said "other" sources. As for why the prevalence of profile 8 DV hybrids now over p5/p8 split before: compatibility and saving time/bandwidth. Cheers.
Chisum04
Post by Chisum04 » Fri Aug 04, 2023 12:32 pm
bbeny123 wrote:
Thu Aug 03, 2023 5:37 pm
My fixes were focused on DV-Profile 7 (dual track), but it is possible that version 1.3.2 will also work with the Oppo.
1.3.2-alpha1: https://github.com/bbeny123/mp4muxer/re ... 3.2-alpha1
If 1.3.2-alpha1 still does not work, you can also try 1.3.2-alpha2: https://github.com/bbeny123/mp4muxer/re ... 3.2-alpha2
Alpha 2 triggers Dolby on my Oppo, Alpha 1 fails. MP4 in alpha 1 und 2 is hev1, in ver 1.0 they are dvhe (nevertheless triggering Dolby)
NiCE77
Post by NiCE77 » Fri Aug 04, 2023 1:18 pm
RESET_9999 wrote:
Thu Aug 03, 2023 2:09 pm
bbeny123 wrote:
Wed Aug 02, 2023 2:15 pm
Nope, I've tested LG C9 only.
It also works well on my C2 but the 2018 or older TV are more picky in regard of DV MP4.
if anyone with old LG TVs could test the latest beta script, workflows 7-2, that would be great. You have to update the mp4muxer.exe by the one from here: https://github.com/bbeny123/mp4muxer
Only HDR on LG B8.
bbeny123
Post by bbeny123 » Fri Aug 04, 2023 1:22 pm
Could you share a sample of original file?
Only HDR on LG B8.
Have you tried the 1.3.2-alpha2: https://github.com/bbeny123/mp4muxer/re ... 3.2-alpha2?
NiCE77
Post by NiCE77 » Fri Aug 04, 2023 1:34 pm
Only HDR on LG B8.
1.3.2-alpha2 works fine, thanks!
Chisum04
Post by Chisum04 » Sat Aug 05, 2023 8:30 am
"Original file" meaning the RPU injected hevc-file? The Original from the UHD is without Dolby. If you provide a download link via PM I could upload.
bbeny123
Post by bbeny123 » Sat Aug 05, 2023 9:12 am
I dont't need it anymore, I managed to find some other video with DV profile 8.1 :)
Could you please check out version 1.3.2-alpha3? It should work with Oppo (and older LG TVs) and have the codec set correctly to 'dvhe'.
1.3.2-alpha3: https://github.com/bbeny123/mp4muxer/re ... 3.2-alpha3
valington
Post by valington » Sat Aug 05, 2023 1:39 pm
Reset your c2 is showing mp4 7 profil dolby vision with this new version mp4 muxer ?
Chisum04
Post by Chisum04 » Sat Aug 05, 2023 1:40 pm
Worked! Perfect.
bbeny123
Post by bbeny123 » Sat Aug 05, 2023 1:54 pm
Since the 1.3.2-alpha3 version seems to be fully stable, I released it as 1.3.2 :)
https://github.com/bbeny123/mp4muxer/releases/tag/1.3.2
Version 1.3.2 differs from 1.3.1 in that for DV profiles > 7 the codec configuration box is set to dvcC instead of dvvC (mp4box_64bits 1.0.0 also set dvcC).
This is non-compliant with Dolby's documentation, but as we can see Oppo and older LG TVs are also non-compliant (as only this setting works on them).
Post by RESET_9999 » Sat Aug 05, 2023 1:57 pm
No, LG dropped P7 support since the CX. I was talking about P8 and P5.
staknhalo
Post by staknhalo » Sun Aug 06, 2023 1:30 am
Is there a way to tell what resolution video an RPU came from/what resolution an RPU is intended for? Like if I have a p5 RPU but not the source p5 video, and a HDR10 Blu-ray BL to inject the RPU into - how do I know if black bars should be cropped or not (on some p5 videos the video is 16:9 with black bars in the stream, some p5 will have just the video in whatever resolution/aspect ratio with no black bars)? Like a specific line/variable to look for in the json/RPU?
Post by RESET_9999 » Sun Aug 06, 2023 2:08 am
Everything about the rpu aspect ratio(active area) is in Level 5
If the BL is 16:9 with no black bars or if it is cropped, L5 should always be 0 regardless of the base layer resolution.
if the new BL has black bars, you measure them and edit L5 accordingly.
