Movie bakcup problem MARLEY AND ME, and LadyHawke
BonJavi
Post by BonJavi » Fri Aug 04, 2023 2:58 am
Hello
I wanted to ask a question about this problem I'm having. I want to make a Backup of my Bluray MARLEY_AND_ME. It finishes making the copy, but when playing a screen appears in which it says "Your player needs to be updated". With the original Bluray it doesn't happen.
I have observed and I think it could be the following. Since these messages appear in MakeMKV.
Processed BD+ code. Please wait, this may take several minutes.
Processing BD+ code using the builtin/generic.svq generic SVQ
BD+ code processed. Earned 1 FUT(s) from 1 clip(s)
The content of the hash table has been loaded, the integrity of the M2TS files will be verified.
Is it for this reason that this problem occurs? What should I do? Would you have any solution?
To say that exactly the same thing happens to me with another film, LadyHawke.
I hope someone helps me. Thank you!
All the best.
Re: Movie bakcup problem MARLEY AND ME, and LadyHawke
Post by Billycar11 » Fri Aug 04, 2023 3:47 am
dont play it on an offical player and it should not happen or make a direct rip of the movie only
BonJavi
Post by BonJavi » Fri Aug 04, 2023 7:09 am
Hello, thanks for answering.
So there is no solution? What causes this problem? I was hoping I could understand what's going on.
In all players the problem appears, so it would not be useful.
Post by Billycar11 » Fri Aug 04, 2023 7:12 am
if you play it in a bluray player yes this will happen it does not like the drm removed thats why. no way to fix it other then to use an unofficial player like an nvidia shield or something
Ezatoka
Post by Ezatoka » Fri Aug 04, 2023 10:27 am
E.g. DVDfab Passkey can also remove those BD+-things:
(https://i.imgur.com/cvbUz0t.png if the picture isn't shown)
MakeMKV only removes AACS as much as I know, not BD+
BonJavi
Post by BonJavi » Fri Aug 04, 2023 8:30 pm
Hello Ezatoka
Indeed, applying the PassKey solves the problem by applying the Bluray Fix.
Thank you for the contribution Ezatoka
A greeting and good weekend!
Ezatoka
Post by Ezatoka » Sat Aug 05, 2023 12:18 pm
Glad to be of help :)
Besides, the problem with "Update your player" happened to me in the past as well, when trying to open such a ripped BluRay with VLC Player. So it's not just official players showing that problem.
Post by Billycar11 » Sat Aug 05, 2023 3:22 pm
But it usually just skips right past it after a few seconds at least it usually does for.me
Now that I think about it they may need to set the region in vlc too that might be why
