UHD Spider-Verse Disc fails with MakeMKV, but Blu-Ray doesn't
kekulism
Post by kekulism » Thu Aug 03, 2023 8:48 pm
Bit new to all this so sorry if I come off stupid or if this is the wrong category for this post.
Recently I bought an LG BP60NB10 External Drive looking to find a way to play my Blu-Rays on VLC, as well as dump them. Found out how to get it to do that and it does it well so that's good, but I recently bought a 4K UHD copy of Into the Spider-Verse and that's where my problems start. No matter what I try it seems I cannot find a way to either play or dump the UHD Blu-Ray. I flashed the downgrade firmware thing to patch my drive (which I'm not totally sure why I had to do that but I did it) and MakeMKV says my drive is good now, but every time I try to dump it with MakeMKV I get the same error:
Saved AACS dump file as C:\Users\kekul/.MakeMKV/MKB20_v61_Spider-Man-_Into_the_Spider-Verse_835F.tgz
I don't get why this happens because as far as I can tell, this is caused by the program failing to download the latest hash keys, but it doesn't have this problem when I dump a normal Blu-Ray, just 4K UHD ones. I also checked the keydb.cfg (which I think is the hash key file that MakeMKV uses), and it has the keys for UHD Into the Spider-Verse, which confuses me even more. I don't know what the problem is here and the more I try to find it with googling the more frustrated I become so here I am. If I could get some help in solving this issue I would greatly appreciate it. Would love to be able to watch my physical media on my PC.
Re: UHD Spider-Verse Disc fails with MakeMKV, but Blu-Ray doesn't
Post by Billycar11 » Thu Aug 03, 2023 9:05 pm
this is your issue
makemkv does not use keydb.cfg it uses its own in privatedata.tar
to fix the Automatic HK downloading is disabled or failed.
change your dns
unblock Russia in your firewall
use a vpn
