Ronin 4K Disc
lujan
Ronin 4K Disc
#1 Post by lujan » Tue Aug 01, 2023 10:08 pm
Anyone have issues with the recent release of Ronin 4K? I keep getting a "failed" message when trying to rip. I don't see tgz file but will send txt file to support.
tresnugget
Re: Ronin 4K Disc
#2 Post by tresnugget » Wed Aug 02, 2023 9:30 pm
lujan wrote: Tue Aug 01, 2023 10:08 pm Anyone have issues with the recent release of Ronin 4K? I keep getting a "failed" message when trying to rip. I don't see tgz file but will send txt file to support.
No issue here. Might have just gotten a bad disc. Try cleaning it with some water and a micro fiber cloth and/or using a different drive. I have one drive that'll do 90% of discs and another drive that will usually complete if that one won't but runs at 4x instead of 6x. The crazy thing is I already had like 300+ discs by the time I got into ripping and all of those ripped no problem on one drive or another but since then I've had at least 5 discs that wouldn't rip on either drive but a replacement disc always worked.
demon
Re: Ronin 4K Disc
#3 Post by demon » Wed Aug 16, 2023 12:28 am
My copy worked fine as well, so I would definitely look at disc cleanliness and/or drive issues.
gatsntatsdad
Re: Ronin 4K Disc
#4 Post by gatsntatsdad » Sun Mar 23, 2025 4:41 pm
that was first disc i tried to rip when getting my new setup with a pioneer drive i'd gotten, it basically 'killed' the drive, couldn't even open the tray, had to open computer and actually pull the power and sata cables out and plug them back in to get the drive to power up.
