Super Mario Bros. Movie (2023) Blu ray UK version
MudydyDogs
Post by MudydyDogs » Mon Jul 31, 2023 4:24 pm
Is anyone else having problems with this movie?
When I scan the disk Make MKV is only finding two titles on the disk, neither of which are the movie - link to screenshot https://drive.google.com/file/d/1WCYSHv ... sp=sharing
The output window from the initial scan says it's skipping a lot of mpls but not saying why - see attached txt file
The initial scan says the operation completed normally.
Make MKV is the latest version
MakeMKV v1.17.4 darwin(x64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-S12U 1.02 ALDL005947WLd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=F1ED73020654)
Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Any ideas or pointers on this one? I've not had this happen before - normally you get a clean scan or you get errors. I've not had a clean scan before but it doesn't find the movie.
Thanks,
Scan results.txt
(7.15 KiB) Downloaded 458 times
