Top Gun HD DVD - Fatal error occurred, program will now exit
nekno
Post by nekno » Mon Jul 31, 2023 5:01 am
Not sure where to post about HD DVDs, but I'm trying to open Top Gun with an LG GGC-H20L combo drive.
This issue appears to be a new bug, as in June 2019 I was able to successfully open and rip the disc.
When attempting to open the disc, while the progress bar shows "Decrypting", I get an error popup that says:
MakeMKV BETA popup
Debug log started at Mon Jul 31 04:47:42 2023 , written by MakeMKV v1.17.4 win(x64-release)
001005:0000 MakeMKV v1.17.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\xxx/MakeMKV_log.txt
No  SDF v098: HL-DT-ST_BDDVDRW_GGC-H20L_1.03_20080515123456_xxx
DEBUG: Code 0 at /$I_D_s_U8V}=/y'0:29396253
DEBUG: Code 0 at Hu0Y6$"G%/26#v|y:213136746
DEBUG: Code 3 at w.G,[.W,J~s[OWwzq<.Q$D1P:29395310
SDF id v098: HL-DT-ST_BDDVDRW_GGC-H20L_1.03_20080515123456_xxx
DEBUG: Code 0 at %>QWC*,ao4XFqFK2g1b:121261704
Re: Top Gun HD DVD - Fatal error occurred, program will now exit
Post by dcoke22 » Mon Jul 31, 2023 5:23 am
MakeMKV 1.17.3 not opening any HD DVD discs
HD DVD support seems to have been broken in the last couple of point releases.
nekno
Post by nekno » Mon Jul 31, 2023 5:44 am
Oh! :cry:
Poor searching on my part. :roll: Thanks!
nekno
Post by nekno » Thu Aug 03, 2023 6:06 am
So I reinstalled 1.17.2 and I'm getting different errors ripping the disc. I've previously ripped this disc, so I don't believe it to be the problem.
Any of this look familiar to anyone?
MakeMKV v1.17.2 win(x64-release) started
The new version 1.17.4 is available for download at http://www.makemkv.com/download/
DEBUG: Code 0 at sAsRoYOC"v.1gCP{:29398300
Title #PARALOGO.EVO has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #BLACK.EVO has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 989 at w3bdtHM'`U+liV<Pv>-|-:213134055
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 12288, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 10240, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 16384, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 22528, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 26624, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 38912, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 45056, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 51200, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 61440, attempting to work around
DEBUG: Code 15360 at w3bdtHM'`U+liV<Pv>-|-:121265338
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 69632, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 73728, attempting to work around
DEBUG: Code 0 at )^<o4,IWdh3,t+[phRO:121264119
DEBUG: Code 0 at )^<o4,IWdh3,t+[phRO:121263015
DEBUG: Code 0 at "j%_6%.1kR5STy/6TK+4:213131157
DEBUG: Code 0 at "j%_6%.1kR5STy/6TK+4:121262647
DEBUG: Code 40 at "j%_6%.1kR5STy/6TK+4:121261773
DEBUG: Code 0 at C0:uI8.LBlKv"3?xR:)dX:213129984
DEBUG: Code 0 at w3bdtHM'`U+liV<Pv>-|-:213137068
DEBUG: Code 3 at []FT^0o 9ptqu*vu:121262578
DEBUG: Code 0 at D/Yd;xQJz x=B>=:213138494
