Top Gun HD DVD - Fatal error occurred, program will now exit
nekno
Post by nekno »
Not sure where to post about HD DVDs, but I'm trying to open Top Gun with an LG GGC-H20L combo drive.
This issue appears to be a new bug, as in June 2019 I was able to successfully open and rip the disc.
When attempting to open the disc, while the progress bar shows "Decrypting", I get an error popup that says:
MakeMKV BETA popup
Debug log started at Mon Jul 31 04:47:42 2023 , written by MakeMKV v1.17.4 win(x64-release)
001005:0000 MakeMKV v1.17.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\xxx/MakeMKV_log.txt
No  SDF v098: HL-DT-ST_BDDVDRW_GGC-H20L_1.03_20080515123456_xxx
DEBUG: Code 0 at /$I_D_s_U8V}=/y'0:29396253
DEBUG: Code 0 at Hu0Y6$"G%/26#v|y:213136746
DEBUG: Code 3 at w.G,[.W,J~s[OWwzq<.Q$D1P:29395310
SDF id v098: HL-DT-ST_BDDVDRW_GGC-H20L_1.03_20080515123456_xxx
DEBUG: Code 0 at %>QWC*,ao4XFqFK2g1b:121261704
Re: Top Gun HD DVD - Fatal error occurred, program will now exit
MakeMKV 1.17.3 not opening any HD DVD discs
HD DVD support seems to have been broken in the last couple of point releases.
nekno
Post by nekno »
Oh! :cry:
Poor searching on my part. :roll: Thanks!
nekno
Post by nekno »
So I reinstalled 1.17.2 and I'm getting different errors ripping the disc. I've previously ripped this disc, so I don't believe it to be the problem.
Any of this look familiar to anyone?
MakeMKV v1.17.2 win(x64-release) started
The new version 1.17.4 is available for download at http://www.makemkv.com/download/
DEBUG: Code 0 at sAsRoYOC"v.1gCP{:29398300
Title #PARALOGO.EVO has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #BLACK.EVO has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 989 at w3bdtHM'`U+liV<Pv>-|-:213134055
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 12288, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 10240, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 16384, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 22528, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 26624, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 38912, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 45056, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 51200, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 61440, attempting to work around
DEBUG: Code 15360 at w3bdtHM'`U+liV<Pv>-|-:121265338
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 69632, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 73728, attempting to work around
DEBUG: Code 0 at )^<o4,IWdh3,t+[phRO:121264119
DEBUG: Code 0 at )^<o4,IWdh3,t+[phRO:121263015
DEBUG: Code 0 at "j%_6%.1kR5STy/6TK+4:213131157
DEBUG: Code 0 at "j%_6%.1kR5STy/6TK+4:121262647
DEBUG: Code 40 at "j%_6%.1kR5STy/6TK+4:121261773
DEBUG: Code 0 at C0:uI8.LBlKv"3?xR:)dX:213129984
DEBUG: Code 0 at w3bdtHM'`U+liV<Pv>-|-:213137068
DEBUG: Code 3 at []FT^0o 9ptqu*vu:121262578
DEBUG: Code 0 at D/Yd;xQJz x=B>=:213138494
