[SOLVED] Using libmmdb as libaacs+libdbplus - vlc and mpv segfault
numeralwrongdoer
Post by numeralwrongdoer »
I try to do the direct blue-ray playback according to https://www.makemkv.com/forum/viewtopic.php?f=3&t=7009
I installed makemkv in the prefix ~/.local/, so before symlinking, the ~/.local/lib directory looks like this:
$ ls -r ~/.local/lib/
libmmbd.so.0  libmakemkv.so.1  libdriveio.so.0
I also added ~/.local/lib/ to the LD_LIBRARY_PATH environment variable.
When I now create the symlinks according to the forum post and try to play a Blu-Ray disc, both vlc and mpv segfault.
# Example for mpv
LD_DEBUG=libs mpv bd:////dev/sr0
      9231:	find library=libaacs.so.0 [0]; searching
      9231:	 search path=/home/numeralwrongdoer/.local/lib:tls/x86_64:tls:x86_64:		(LD_LIBRARY_PATH)
      9231:	  trying file=/home/numeralwrongdoer/.local/lib/libaacs.so.0
      9231:
      9231:	find library=libcrypto.so.1.1 [0]; searching
      9231:	  trying file=/home/numeralwrongdoer/.local/lib/libcrypto.so.1.1
      9231:	  trying file=tls/x86_64/libcrypto.so.1.1
      9231:	  trying file=tls/libcrypto.so.1.1
      9231:	  trying file=x86_64/libcrypto.so.1.1
      9231:	  trying file=libcrypto.so.1.1
      9231:	 search cache=/etc/ld.so.cache
      9231:	  trying file=/usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
      9231:
      9231:
      9231:	calling init: /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
      9231:
      9231:
      9231:	calling init: /home/numeralwrongdoer/.local/lib/libaacs.so.0
      9231:
Speicherzugriffsfehler
The problem existed with version 1.14.4 and also exists with the current version 1.14.7.
I used VLC via GUI and tried both enabling and disabling disc menus.
I'm using the Debian-based "Devuan" distro, libavcodec is at version 10:3.3.9-dmo1+deb9u1 from Debian Multimedia.
Did I do something wrong? What else info could I look for and provide?
Last edited by numeralwrongdoer on Fri Oct 23, 2020 5:59 pm, edited 1 time in total.
numeralwrongdoer
Re: Using libmmdb as libaacs+libdbplus - vlc and mpv segfault
Solved:
The problem appears to be that I had libaacs installed by the systems package manager.
After uninstalling it, playback works as expected.
EncryptedEggs
Re: [SOLVED] Using libmmdb as libaacs+libdbplus - vlc and mpv segfault
Post by EncryptedEggs »
So how is it precisely that you were able to get BDs working with MPV? I know about copying libmmbd into VLC's folder twice, one as libaacs.dll and one as bdplus.dll, but how can this be done with mpv?
EncryptedEggs
Update on the above: I solved that by putting libaacs in the same folder as mpv
jvian1
Post by jvian1 »
One may also look at my thread about a similar issue with vlc and having installed makemkv system wide.
viewtopic.php?f=3&t=31489&sid=252553db4 ... 9591c9a9c1
The linked post by mike did not work, but after installing some other packages the solution was found. I had previously installed makemkv 1.16.? so the libmmbd.so file was available even though the newer release 1.17.4 won't compile on my fedora 38 system.
