LOTR: Two Towers (Extended) Disc 1
VoodooHellfire
Post by VoodooHellfire »
For some reason I can't seem to rip Disc 1. Every time I try, I get the following error:
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '31174422528'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00073.m2ts' at offset '31174422528'
Any ideas?
Re: LOTR: Two Towers (Extended) Disc 1
Post by SamuriHL »
Clean and/ replace the disc. Those are read errors.
VoodooHellfire
Tried cleaning. Any other ideas? I can try getting a replacement from Amazon if need be, but I wanted to see anything else could cause this kind of error.
VoodooHellfire wrote:
Fri Jul 28, 2023 6:39 pm
2 thing dirty/bad disc
Or bad drive
These discs are hard to read generally. What drive do you have and what is the firmware version?
VoodooHellfire
I have a LG WH16NS40 with firmware 1.02. I also ordered another copy and the error message changed to this:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00073.m2ts' at offset '2710241280'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2710241280'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00073.m2ts' at offset '2710437888'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2710437888'
Failed to save title 3 to file D:/Video/The Lord of the Rings- The Two Towers (EXT.) PT. 1/The Lord of the Rings- The Two Towers (EXT.) PT. 1-SEG FPL_MainFeature_t03.mkv
