Having a Definitive Answer about Flashing Bluray Drive
loganxwolverine
Post by loganxwolverine »
Hello all...
I am looking for a definitive answer about these UHD friendly Drive, Libredrive, flashed Bluray Drive or whatever.
My question :
Will I be able to play any Bluray with a flashed Bluray Drive with my Kodi player connected to my Raspberry Pi ?
Or with PowerDvd on Windows ?
Or with Windvd ?
I mean, a bluray unreadable because of its protection will be playable ?
I see so many of these on ebay and I would love to buy one of them.
Many thanks for your answer
And apologyze for my bad English.
Re: Having a Definitive Answer about Flashing Bluray Drive
loganxwolverine wrote: Sun Jul 30, 2023 2:33 pm Hello all...
My question :
Or with Windvd ?
Yes and no if you rip it yes it will be very easy to play.
But direct playback from disc on raspberry pie is going to require setup with Kodi I think it is possible but you will need to enable integration in makemkv and or manually copy the plugin to Kodi
loganxwolverine
That's what I thought...
A long time ago, I managed to install makemkv plugin into my libreelec...
But I was with an old version such as Krypton I think.
Today, it seems to be a little bit harder. I didn't succed yet.
If you have any clue with these newer version ? Or maybe a link ?
