mp4box subtitles.vtt works iPhone and iPad, but it's a pity there is a minus LG TV, Samsung TV, Android TV, Windows VLC and 321 does not work subtitles.vtt
Most likely mp4box at him mov_text no, need to inform the development mp4box up to update version with support mov_text. Where can I inform those mp4box support?
Well if I can make two there will be subtitles format subtitles.srt and subtitles.vtt now everyone has support iPhone, iPad, LG TV, Samsung TV, Android TV, Windows VLC and 321 everything is OK.
I don't know, I hate the MP4 container.TheEqualizer wrote: ↑Sat Jul 29, 2023 9:22 pmRESET_9999, I understand that maybe the question is not at the right address, but I'll ask if you know. There is a problem that could not be solved, I understand that this is some kind of limitation of the LG operating system, if you play DV mp4 movies over the network (DLNA or NAS) with a lot of subtitle tracks, then switching subtitles is not available, at the same time if you run the same movie in mkv over the network, then subtitles can be switched as when connected via usb
TS container is 10times better for DV. Have you tried it with external SRT ?
TheEqualizer
I would love to do it in TS, but srt external subtitles are only suitable when it comes to one track, and if there are many of them? Therefore, this solution is not suitable.RESET_9999 wrote: I don't know, I hate the MP4 container.
No you can add as many as you want with PLEXTheEqualizer wrote: ↑Sun Jul 30, 2023 12:09 pmI would love to do it in TS, but srt external subtitles are only suitable when it comes to one track, and if there are many of them? Therefore, this solution is not suitable.
TheEqualizer
RESET_9999, unfortunately, this is also not an option, the task is to have everything already inside the container, since this is not for personal use, but for public use, for myself I can do at least in mkv dv and watch from the media player)
Just for fun, I thought I would try generating DV metadata for the Hitchcock film "Rear Window" using the new 3-1 frame by frame option. This movie was only released in HDR, with no DV. The film is in 1:66:1 (5:3) aspect ratio, so am I correct in entering the L5 offsets as:
Left L5 offset 120, Right L5 offset 120, Top L5 offset 0, Bottom L5 offset 0
Thank you so much!
Thank you so much!
I am right that dv p7 mel, converted to p8.1
, will have a better output on a c1 internal player versus original p7 mel on sony x800m2? Because of l1 and l2 metadata?
you have to measure the black bars manually in Avspmod. I didn't generate the RPU I have but it's set to:dapope wrote: ↑Mon Jul 31, 2023 12:23 pmJust for fun, I thought I would try generating DV metadata for the Hitchcock film "Rear Window" using the new 3-1 frame by frame option. This movie was only released in HDR, with no DV. The film is in 1:66:1 (5:3) aspect ratio, so am I correct in entering the L5 offsets as:
Thank you so much!
"Level5": {
"active_area_left_offset": 124,
"active_area_right_offset": 125,
"active_area_top_offset": 0,
}The metadata response will be slightly different but I really don't know which one is more accurate.
If you have a good audio system, I would not sacrifice lossless audio.
Thank you !!
Thank you. I got about the same result when I measured it except I had left as 125 and right as 124.RESET_9999 wrote: ↑Mon Jul 31, 2023 3:08 pmyou have to measure the black bars manually in Avspmod. I didn't generate the RPU I have but it's set to:dapope wrote: ↑Mon Jul 31, 2023 12:23 pmJust for fun, I thought I would try generating DV metadata for the Hitchcock film "Rear Window" using the new 3-1 frame by frame option. This movie was only released in HDR, with no DV. The film is in 1:66:1 (5:3) aspect ratio, so am I correct in entering the L5 offsets as:
Thank you so much!
"Level5": { "active_area_left_offset": 124, "active_area_right_offset": 125, "active_area_top_offset": 0, "active_area_bottom_offset": 0 }
Unfortunately the file only played fine up until about the 1h20m mark. The audio kept playing but the picture froze. This is on the LG CX internal player after muxing to a .ts file. Seems like it has trouble seeking through the file, like it thinks the video is shorter than it actually is. Of course on VLC it plays fine.
So if im encoding this and cropping away the 68px for the imax scenes should my RPU be 0,0,0,0 for the imax scenes and 208 for the normal scenes to make up for the difference?RESET_9999 wrote: ↑Fri Jul 28, 2023 3:01 pmyou edit all the frames to 0,0,276,276 with a json file and then you edit all the Imax frames to 0,0,68,68 with another json file.@RESET_9999 On the Dolby vision excel file, you posted the L5 IMAX edits for Guardians of the Galaxy. How and where to use it? Thanks in advance.
dovi_tool.exe editor -i D:\input.bin -j D:\276.edits.json --rpu-out D:\276.edits.bin
dovi_tool.exe editor -i D:\276.edits.bin -j D:\68.edits.json --rpu-out D:\final.RPU.bin
276/276 json68/68 jsonCode: Select all
{ "mode": 0, "active_area": { "presets": [ { "id": 1, "left": 0, "right": 0, "top": 276, "bottom": 276 } ], "edits": { "all": 1 } } }
{ "mode": 0, "active_area": { "presets": [ { "id": 1, "left": 0, "right": 0, "top": 68, "bottom": 68 } ], "edits": { "2313-8290": 1, "12867-20599": 1, "29662-30346": 1, "44226-50210": 1, "62482-71703": 1, "90855-94414": 1, "114450-114880": 1, "120568-130909": 1, "150232-163186": 1, "180560-180982": 1, "184049-187882": 1, "197234-205633": 1 } } }
I've improved mp4muxer (official dlb_mp4base) a bit.
The main improvement is a significant boost in the performance of muxing hevc files.
In the official version, after reading the input files, the mp4muxer looks like it goes idle (low CPU usage, minimal disk usage).
During the "inactivity" the program does n * n loops (where n = number of video frames) - so the longer (not bigger) the input video, the longer the idleness period. After my fixes, such a loop is made only once (by using a map-like data structure).
This fix significantly reduces the time needed to mux hevc files, the "idle" time has been reduced to almost 0. Muxing performance now depends almost only on the speed of the used disk.
Other changes:
Other changes:
- Fixed codec id for EL layer (codec id for the EL layer is again 'dvhe' and not 'hev1') - in this aspect, the behavior is the same as in the old 'mp4muxer_64bits' version (1.0.0)
- Support for .eac3 audio input
- Muxing progress logging
I don't know I never tried with cropped content but 208 for the non-imax shots sounds right. Test it on an LG TV internal player.
@RESET_9999 Do you have any idea why this might be the case? Any help would be appreciated.dapope wrote: ↑Tue Aug 01, 2023 2:17 pmThank you. I got about the same result when I measured it except I had left as 125 and right as 124.RESET_9999 wrote: ↑Mon Jul 31, 2023 3:08 pmyou have to measure the black bars manually in Avspmod. I didn't generate the RPU I have but it's set to:dapope wrote: ↑Mon Jul 31, 2023 12:23 pmJust for fun, I thought I would try generating DV metadata for the Hitchcock film "Rear Window" using the new 3-1 frame by frame option. This movie was only released in HDR, with no DV. The film is in 1:66:1 (5:3) aspect ratio, so am I correct in entering the L5 offsets as:
Thank you so much!
Also I would check if there isn't a bug in your program switching the left and right offset. I'm sure I entered the left offset as 125 and the right offset as 124, but now the metadata is saying it's reversed (like the one you posted).
Hi, RESET_9999! mp4box subtitles iPhone и iPad it will work tx3g and sbtl. @jamiew just saved my life!
test.srt:lang=eng:layout=0x60x0x-1:group=2:hdlr=sbtl:tx3g
