Way to rename rips for Plex?
Re: Way to rename rips for Plex?
You can do the renaming when you do the rip... That's how I've done it. Click on each title, and look for the "Properties" tag... select "Name", and fill in the name you want the track to have. You can pull down the "Name" button and select "File name", and modify the actual name the file will be saved as (separate from the name inserted into the MKV file).
When doing a series, you can step down through the titles fairly quickly.
This will make sure the files end up with the correct names when viewed with Plex. Otherwise, you can have a difference in how it displays in Plex and what the actual file name is.
(I don't get that problem, because I process the files through handbrake afterwards, anyway, to reduce their size.)
Radiocomms237
Post by Radiocomms237 »
WTF is going on here? This is the third time (that I know of) that this post (verbatim) has been put up by three different user names:
EDIT: Reporting my own post to bring this to the moderator's attention.
nastor5 wrote:
Mon Jul 03, 2023 3:10 am
Hi! I've been ripping DVDs for the kids, but I often spend hours renaming everything for Plex.
I just bought a ton of Blu-ray movies, and after ripping them all, it's gonna be weeks of every-night renaming to get them Plex-ready.
It's really bad for special features considering the box doesn't always name them all, and I still have to watch them to figure out what they are.
Is there some program run that can check each movie by the disc and name all the files similar to how MP3s can auto-name based on the album and song fingerprinting?
troxad wrote:
Fri Jul 21, 2023 9:28 pm
yamat5 wrote:
Sat Jul 29, 2023 7:11 am
alishakihnh
Post by alishakihnh »
Rename your media files using a consistent naming convention. For movies, you can use the movie title followed by the release year in parentheses, such as "The Shawshank Redemption (1994)". For TV shows, you can use the show title followed by the season and episode number, such as "Breaking Bad S01E01".
Radiocomms237
@alishakihnh, not sure if you saw the post above but this is a phishing scam and the three user names have now been banned.
P.S. I see this was your 1st post, welcome aboard!
