#8611
Post
by RESET_9999 » Fri Jul 28, 2023 5:25 pm
TheEqualizer wrote: ↑Fri Jul 28, 2023 5:17 pm
How bad it is that we speak different languages and we don’t understand each other well((((
Used on the built-in LG player, movies anywhere streaming service has a full frame, not cropped like amazon or itunes, I recognize or you will understand me this time)
there is no MA Profile 5 available online on torrent/scene... the only DV source is iTunes.
Even if MA P5 DV was available, all their encodes have incorrect Level 5 metadata just like itunes.
TheEqualizer
#8612
Post
by TheEqualizer » Fri Jul 28, 2023 5:39 pm
Metadata was extracted by me from MA hybrid release (8 profile, full frame) and injected into uhd hdr
What does it mean not faithful and why release such a thing at all? ...
Where can I read in detail and in an understandable language about the levels?
TheEqualizer on Fri Jul 28, 2023 5:52 pm, edited 2 times in total.
#8613
Post
by RESET_9999 » Fri Jul 28, 2023 5:48 pm
TheEqualizer wrote: ↑Fri Jul 28, 2023 5:39 pm
that ma p8 release use DV meta from iTunes...
Easy to tell because all the iTunes web-dl are missing level 4 metadata.
Studios can be a bunch of amateur sometimes, nothing new here. We often get much better quality through piracy.
https://professionalsupport.dolby.com/s ... uage=en_US
TheEqualizer
#8614
Post
by TheEqualizer » Fri Jul 28, 2023 7:10 pm
RESET_9999 wrote:
You can use the hdr10plus_tool if you cant wait for me...
hdr10plus_tool.exe remove input.hevc -o hdr10plus_removed_output.hevc
After running through this utility, the frame rate changes from 23.976 to 25.000, this should not be! I suppose this is due to incomplete resolution, how to solve this problem?
#8615
Post
by RESET_9999 » Fri Jul 28, 2023 7:16 pm
TheEqualizer wrote: ↑Fri Jul 28, 2023 7:10 pm
appletv / iTunes web-dl I guess?
This is due to Apple's incompetence. Most of their encodes are missing the frame rate bitstream information and if you don't specify it before muxing in mkvtoolnix, the output will be 25fps after using the dovi_tool/hdr10plus_tool.
You could try to write a proper framerate bitstream with eac3to.exe but it doesn't work all the time.
TheEqualizer
#8616
Post
by TheEqualizer » Fri Jul 28, 2023 7:19 pm
RESET_9999, уes exactly Apple TV. The new script that I expect from you is taught to do this automatically to avoid similar problems?
P.S. In manual mode, I got rid of the problem
#8617
Post
by RESET_9999 » Fri Jul 28, 2023 7:27 pm
TheEqualizer wrote: ↑Fri Jul 28, 2023 7:19 pm
Yes, the script takes care of specifying the proper frame rate before muxing to MKV or TS but it doesn't fix it at the bitstream level like eac3to.exe or ffmpeg can do.
eac3to.exe "D:\input.mkv" 1: "D:\output.h265" -23.976 -changeto23.976
ffmpeg.exe -vsync drop -i input.mkv -c copy -bsf:v hevc_metadata=tick_rate=24000/1001:num_ticks_poc_diff_one=1 "output.hevc"
legosoff
#8618
Post
by legosoff » Sat Jul 29, 2023 4:12 am
Hi, RESET_9999.
ffmpeg there are commands dvh1? I didn't find the command dvh1 only there is hvc1 и hev1, i need to dvh1. mp4box dvh1 great, but iPhone and iPad subtitles don't work, ffmpeg subtitles work.
TheEqualizer
#8619
Post
by TheEqualizer » Sat Jul 29, 2023 5:43 am
RESET_9999, thanks for the correction in DoVi_Scripts_1.9.0, now the 6-1-1 works as expected, of course, you need to pre-prepare the video as you wrote with eac3to or ffmpeg, thanks
thirdmoon
#8620
Post
by thirdmoon » Sat Jul 29, 2023 7:34 am
@RESET_9999 is it possible to convert SDR video to HDR using the script or DaVinci?
legosoff
#8622
Post
by legosoff » Sat Jul 29, 2023 2:10 pm
RESET_9999 wrote: ↑Sat Jul 29, 2023 1:20 pm
legosoff wrote: ↑Sat Jul 29, 2023 4:12 am
Hi, RESET_9999.
no idea
The problem of iPhone and iPad subtitles should be solved by mp4box.
TheEqualizer
#8623
Post
by TheEqualizer » Sat Jul 29, 2023 9:22 pm
RESET_9999, I understand that maybe the question is not at the right address, but I'll ask if you know. There is a problem that could not be solved, I understand that this is some kind of limitation of the LG operating system, if you play DV mp4 movies over the network (DLNA or NAS) with a lot of subtitle tracks, then switching subtitles is not available, at the same time if you run the same movie in mkv over the network, then subtitles can be switched as when connected via usb
sw5163
#8624
Post
by sw5163 » Sun Jul 30, 2023 3:54 am
legosoff wrote: ↑Sat Jul 29, 2023 2:10 pm
You can try
mp4box -add dv.hevc -add atmos.eac3 -add sub.srt:hdlr=sbtl:lang=eng -new dvh1.atmos.engsub.mp4
Or you can first put an mov_text sub into a mp4 container
ffmpeg -i sub.srt -c:s mov_text -metadata:s language=eng sub.mp4
And then
mp4box -add dv.hevc -add atmos.eac3 -add sub.mp4 -new dvh1.atmos.engsub.mp4
legosoff
#8625
Post
by legosoff » Sun Jul 30, 2023 5:11 am
sw5163 wrote: ↑Sun Jul 30, 2023 3:54 am
You can try
And then
Hi, sw5163.
subtitles no.
through mp4box -add dv.hevc -add atmos.eac3 -add sub.mp4 -new dvh1.atmos.engsub.mp4
too subtitles no.
ffmpeg -i dv.mkv -map 0:v? -map 0:a? -map 0:s? -c:v copy -c:a copy -c:s mov_text dv.mp4
subtitles there is.
I'll try it now
Subtitle Edit there will be several format files on mp4box.
