TheEqualizer
Post by TheEqualizer »
Perhaps you don’t quite understand me because of the translator, but you caught the essence, different frame sizes, imax scenes and ordinary ones. If the blu-ray and streaming versions were used, everything is identical in them, the scenes change exactly, what is this procedure for?
Because the itunes DV source is cropped and doesnt have L5 metadata.
It doesn't matter for HDMI devices though, L5 is ignored and DV tone mapping is always applied to the whole image, letterbox included.
only the LG TVs internal player use that metadata.(I dont know about the other TVs brand)
TheEqualizer
I made a hybrid of uhd hdr and web-dl MA, there is a full frame, therefore, these manipulations are useless, if I understand you correctly.
TheEqualizer
RESET_9999 wrote:
Fri Jul 28, 2023 11:07 am
check out 1.8.9.5 later today.
Will it be available for download soon?
TheEqualizer wrote:
Fri Jul 28, 2023 4:56 pm
useless as long as you don't use your TV internal player.
what?
TheEqualizer wrote:
Fri Jul 28, 2023 5:07 pm
In a few hours when I get home.
You can use the hdr10plus_tool if you cant wait for me...
hdr10plus_tool.exe remove input.hevc -o hdr10plus_removed_output.hevc
TheEqualizer
RESET_9999 wrote:
Fri Jul 28, 2023 5:09 pm
what?
How bad it is that we speak different languages ​​​​and we don’t understand each other well((((
Used on the built-in LG player, movies anywhere streaming service has a full frame, not cropped like amazon or itunes, I recognize or you will understand me this time)
TheEqualizer wrote:
Fri Jul 28, 2023 5:17 pm
there is no MA Profile 5 available online on torrent/scene... the only DV source is iTunes.
Even if MA P5 DV was available, all their encodes have incorrect Level 5 metadata just like itunes.
TheEqualizer
Metadata was extracted by me from MA hybrid release (8 profile, full frame) and injected into uhd hdr
What does it mean not faithful and why release such a thing at all? ...
Where can I read in detail and in an understandable language about the levels?
TheEqualizer wrote:
Fri Jul 28, 2023 5:39 pm
that ma p8 release use DV meta from iTunes...
Easy to tell because all the iTunes web-dl are missing level 4 metadata.
Studios can be a bunch of amateur sometimes, nothing new here. We often get much better quality through piracy.
https://professionalsupport.dolby.com/s ... uage=en_US
TheEqualizer
After running through this utility, the frame rate changes from 23.976 to 25.000, this should not be! I suppose this is due to incomplete resolution, how to solve this problem?
TheEqualizer wrote:
Fri Jul 28, 2023 7:10 pm
appletv / iTunes web-dl I guess?
This is due to Apple's incompetence. Most of their encodes are missing the frame rate bitstream information and if you don't specify it before muxing in mkvtoolnix, the output will be 25fps after using the dovi_tool/hdr10plus_tool.
You could try to write a proper framerate bitstream with eac3to.exe but it doesn't work all the time.
TheEqualizer
RESET_9999, уes exactly Apple TV. The new script that I expect from you is taught to do this automatically to avoid similar problems?
P.S. In manual mode, I got rid of the problem
TheEqualizer wrote:
Fri Jul 28, 2023 7:19 pm
Yes, the script takes care of specifying the proper frame rate before muxing to MKV or TS but it doesn't fix it at the bitstream level like eac3to.exe or ffmpeg can do.
eac3to.exe "D:\input.mkv" 1: "D:\output.h265" -23.976 -changeto23.976
ffmpeg.exe -vsync drop -i input.mkv -c copy -bsf:v hevc_metadata=tick_rate=24000/1001:num_ticks_poc_diff_one=1 "output.hevc"
legosoff
Post by legosoff »
Hi, RESET_9999.
ffmpeg there are commands dvh1? I didn't find the command dvh1 only there is hvc1 и hev1, i need to dvh1. mp4box dvh1 great, but iPhone and iPad subtitles don't work, ffmpeg subtitles work.
