I'm losing my mind a little... I can't seem to find the tools folder download? Scripts folder is all there but can't for the life of me find the tools folder download? Is this available or is the expectation we manually download all of them? Any help appreciated
The Tools folder has only been available intermittently. You'll need to download them individually. https://drive.google.com/file/d/1zZ9fV2 ... p=drivesdk, or keep an eye out for when they're available again.davenukem wrote: ↑Tue Jul 25, 2023 11:11 pmI'm losing my mind a little... I can't seem to find the tools folder download? Scripts folder is all there but can't for the life of me find the tools folder download? Is this available or is the expectation we manually download all of them? Any help appreciated
More reasons to collect physical media. 2019 Shield TV Pro.
iPhone 14 Dolby Vision test
https://radikal.host/i/Fa7tDT HDR10 vs https://radikal.host/i/Fa7hHx P5 dvh1, P8+HDR10 dvh1 and hvc1, there is nothing special, DV not work.
LG 1C Web OS Dolby Vision test
https://radikal.host/i/Fa7rdI P5 dvh1 and P8+HDR10 dvh1 and hvc1 great really.
@RESET_9999 can I use your scripts to streamline using DoViBaker?
If so, what's the proper process for doing this so I can accomplish the following:
1. Encode to a lossless format (ideally ProRes 422 HQ) from DoViBaker using your scripts
2. I'd then like to separately encode the ProRes file to x265 using StaxRip so I can customize the settings myself.
3. Would it then be ok for me ot inject hte original RPU again from the P7 FEL version?
No need to convert to prores. Just make the avs script with 6-8-1, remove the subtitles/OSD and encode it directly in staxrip.speeddemon wrote: ↑Thu Jul 27, 2023 8:11 am@RESET_9999 can I use your scripts to streamline using DoViBaker?
You have to convert the RPU to P8. Re-injecting the P7 rpu is wrong, it would be like applying FEL two times.
Good afternoon friend, if I wanted to make an HDR movie to Dolby Vision, which one would you recommend your 3+2 script?
best to worst:
1- Davinci Resolve (dolby algo) (tutorial video on my youtube)
2- Dovi_script (3-1) (dolby algo)
3- Dovi_script (3-2) (madvr, may have brightness fluctuation and inaccurate avg_pq values)
I had previously tried 6-9... is that the wrong flow?RESET_9999 wrote: ↑Thu Jul 27, 2023 11:10 amNo need to convert to prores. Just make the avs script with 6-8-1, remove the subtitles/OSD and encode it directly in staxrip.speeddemon wrote: ↑Thu Jul 27, 2023 8:11 am@RESET_9999 can I use your scripts to streamline using DoViBaker?
3. Would it then be ok for me to inject the original RPU again from the P7 FEL version?
No, the output will be the same as staxrip.
6-9 is just automated and the encoding settings are hardcoded (except for preset and crf value)
@RESET_9999 On the Dolby vision excel file, you posted the L5 IMAX edits for Guardians of the Galaxy. How and where to use it? Thanks in advance.
RESET_9999, hi, the 6-1-1 script is not working, it gives an error, the screenshot below, what could it be? I try on different movies, all contain HDR10+, which needs to be removed so that only HDR and DV remain. The script is currently DoVi_Scripts_1.8.9.3.beta_MKV, I tried it on other versions, there is no difference.
check out 1.8.9.5 later today.
you edit all the frames to 0,0,276,276 with a json file and then you edit all the Imax frames to 0,0,68,68 with another json file.@RESET_9999 On the Dolby vision excel file, you posted the L5 IMAX edits for Guardians of the Galaxy. How and where to use it? Thanks in advance.
dovi_tool.exe editor -i D:\input.bin -j D:\276.edits.json --rpu-out D:\276.edits.bin
dovi_tool.exe editor -i D:\276.edits.bin -j D:\68.edits.json --rpu-out D:\final.RPU.bin
276/276 json
"mode": 0,
"active_area": {
"presets": [
"id": 1,
"left": 0,
"right": 0,
"top": 276,
"bottom": 276
"edits": {
"all": 1
"mode": 0,
"active_area": {
"presets": [
"id": 1,
"left": 0,
"right": 0,
"top": 68,
"bottom": 68
"edits": {
"2313-8290": 1,
"12867-20599": 1,
"29662-30346": 1,
"44226-50210": 1,
"62482-71703": 1,
"90855-94414": 1,
"114450-114880": 1,
"120568-130909": 1,
"150232-163186": 1,
"180560-180982": 1,
"184049-187882": 1,
"197234-205633": 1
Can you please tell me if this is related to imax and not imax scenes? And what does it give?you edit all the frames to 0,0,276,276 with a json file and then you edit all the Imax frames to 0,0,68,68 with another json file.
Not sure I understand what you mean...TheEqualizer wrote: ↑Fri Jul 28, 2023 3:47 pmCan you please tell me if this is related to imax and not imax scenes? And what does it give?you edit all the frames to 0,0,276,276 with a json file and then you edit all the Imax frames to 0,0,68,68 with another json file.
Guardians of the Galaxy 3 bluray and web streaming have changing aspect ratios. Some scenes are 2.39(276/276) and some are 1.90(68/68).
Disney Plus should have the movie in full Imax though.
