For some reason I can't seem to rip Disc 1. Every time I try, I get the following error:
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '31174422528'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00073.m2ts' at offset '31174422528'
Any ideas?
LOTR: Two Towers (Extended) Disc 1
Re: LOTR: Two Towers (Extended) Disc 1
Clean and/ replace the disc. Those are read errors.
VoodooHellfire
Tried cleaning. Any other ideas? I can try getting a replacement from Amazon if need be, but I wanted to see anything else could cause this kind of error.
2 thing dirty/bad discVoodooHellfire wrote: ↑Fri Jul 28, 2023 6:39 pmTried cleaning. Any other ideas? I can try getting a replacement from Amazon if need be, but I wanted to see anything else could cause this kind of error.
Or bad drive
These discs are hard to read generally. What drive do you have and what is the firmware version?
VoodooHellfire
I have a LG WH16NS40 with firmware 1.02. I also ordered another copy and the error message changed to this:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00073.m2ts' at offset '2710241280'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2710241280'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00073.m2ts' at offset '2710437888'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '2710437888'
Failed to save title 3 to file D:/Video/The Lord of the Rings- The Two Towers (EXT.) PT. 1/The Lord of the Rings- The Two Towers (EXT.) PT. 1-SEG FPL_MainFeature_t03.mkv
