UHD Blu-Ray Disk outputs FullHD and not UHD MKV
GamingHen
Post by GamingHen » Thu Jul 27, 2023 3:40 pm
Hey,
When i try to rip this UHD Blu-Ray i only get a 1080p MKV, do you know why and what i can do to get UHD?
i attached all infos down below.
Originaltitel: Independence Day: Resurgence (2016)
Blu-Ray ISBN: 4010232068699
Log:
MakeMKV v1.17.4 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'SPTI:\Device\CdRom1'
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
Title #00010.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00172.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00600.mpls was added as title #0
Title #00173.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00174.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00330.mpls was added as title #1
File 00331.mpls was added as title #2
Title #00332.mpls has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00333.mpls has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00334.mpls was added as title #3
File 00335.mpls was added as title #4
Title #00336.mpls has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00337.mpls has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00338.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00339.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00850.mpls is equal to title 00600.mpls and was skipped
File 00230.mpls was added as title #5
File 00237.mpls was added as title #6
Title #00238.mpls has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00239.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00240.mpls has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00241.mpls has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00242.mpls has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00243.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00244.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00245.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00246.mpls was added as title #7
File 00247.mpls was added as title #8
File 00248.mpls was added as title #9
File 00249.mpls was added as title #10
File 00250.mpls was added as title #11
Title 00800.mpls is equal to title 00600.mpls and was skipped
Title 00801.mpls is equal to title 00600.mpls and was skipped
Title 00851.mpls is equal to title 00600.mpls and was skipped
File 00437.mpls was added as title #12
Title #00438.mpls has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00439.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00440.mpls has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00441.mpls has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00442.mpls has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00443.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00444.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00445.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00446.mpls was added as title #13
File 00447.mpls was added as title #14
File 00448.mpls was added as title #15
File 00449.mpls was added as title #16
File 00450.mpls was added as title #17
Title #00070.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00142.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00149.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00172.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00152.m2ts was added as title #18
File 00153.m2ts was added as title #19
File 00200.m2ts was added as title #20
File 00201.m2ts was added as title #21
File 00202.m2ts was added as title #22
File 00203.m2ts was added as title #23
File 00204.m2ts was added as title #24
Title #00205.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00192.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00290.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00174.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00206.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00207.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00209.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00210.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00211.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00212.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00213.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00214.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00215.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00216.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00217.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00218.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00219.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00221.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00222.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00223.m2ts was added as title #25
File 00224.m2ts was added as title #26
File 00225.m2ts was added as title #27
File 00226.m2ts was added as title #28
Title #00227.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00291.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00292.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00293.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00294.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Re: UHD Blu-Ray Disk outputs FullHD and not UHD MKV
Post by Woodstock » Thu Jul 27, 2023 5:00 pm
If you're getting a 1080P file, that's not the UHD disk.
Most UHD titles I've seen or purchased came with a standard 1080P Bluray, and the UHD was a separate disk marked as UHD, and ONLY having the UHD video on it.
Post by Billycar11 » Thu Jul 27, 2023 10:34 pm
You imagine shows it a reg bdrom not UHD so your puting the wrong disc in or you got ripped off on the disc.
