ama0riko
Post
by ama0riko » Thu Jul 27, 2023 1:30 am
Billycar11 wrote: Wed Jul 26, 2023 8:34 am
ama0riko wrote: Wed Jul 26, 2023 7:04 am
Hi, this is my first time here so there are probably going to be some spots in my knowledge.
I'm looking to get a Pioneer drive that I can just purchase and will work with ripping pretty much any content.
- I live in Japan and so getting my hands on second-hand Pioneer drives with older firmware is not a problem.
- I use macOS
I'm looking to get a BDR-XD07J-UHD (should just be the Japanese version of the BDR-XD07UHD) with a manufacturing date on the back of the drive that reads March 2018.
Would this be a good choice? I would really appreciate if I can get opinions on this.
that would work long as someone didn't update it for you
Thanks for the quick and informative response!
Also, is buying a new BDR-XD08UMB-S a good idea? I don't have any UHD Blu-rays to rip at the moment, so I'd only need it as a feature in the future. I'd want to be able to use MakeMKV to rip some HD Blu-rays though.
Post
by Billycar11 » Thu Jul 27, 2023 3:17 am
ama0riko wrote: Thu Jul 27, 2023 1:30 am
- I use macOS
not a good idea you dont know what fw it will come with
best to get a flashed on your know will work
if the pioneer has to new of a fw t cant be flashed at all
ama0riko
Post
by ama0riko » Thu Jul 27, 2023 6:28 am
So to clarify, if it has firmware that is too recent, then it won't be able to be used with MakeMKV to rip any Blu-rays at all?
Post
by Billycar11 » Thu Jul 27, 2023 6:38 am
ama0riko wrote: Thu Jul 27, 2023 6:28 am
UHD blurays
ama0riko
Post
by ama0riko » Thu Jul 27, 2023 9:05 pm
Billycar11 wrote: Thu Jul 27, 2023 6:38 am
UHD blurays
Are there any estimates as to how long we could expect to wait for UHD blu-ray ripping to be supported?
Post
by Billycar11 » Thu Jul 27, 2023 10:30 pm
ama0riko wrote: Thu Jul 27, 2023 9:05 pm
UHD blurays
Weeks to months
PaulCB
Post
by PaulCB » Fri Jul 28, 2023 12:01 am
Saw that Amazon had a S13U in the 'amazon renewed' section and gave it a go as it was discounted and had a chance of being a drive with older firmware.. Annnnd it wasn't. 1.04 Dec 12 2022.
So if you see a Pioneer on Amazon, even the returns, it is probably best to assume it has the bad firmware and don't bother. Only buy from the guys here that have the known-good units.
PaulCB on Fri Jul 28, 2023 12:15 am, edited 1 time in total.
Post
by Billycar11 » Fri Jul 28, 2023 12:14 am
PaulCB wrote: Fri Jul 28, 2023 12:01 am
Yeah that one is just one someone sent back for the fw reason most likely
mankr1981@gmail.com
Post
by mankr1981@gmail.com » Mon Jul 31, 2023 5:04 am
Drive platform: Pioneer RS9400'
wanted to check is it supported
Post
by Billycar11 » Mon Jul 31, 2023 5:52 am
mankr1981@gmail.com wrote: Mon Jul 31, 2023 5:04 am
whats the full drive info what fw ver and build date
mankr1981@gmail.com
Post
by mankr1981@gmail.com » Mon Jul 31, 2023 7:19 am
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-X13
Revision: 1.03
Firmware date: 2022-12-12
Highest AACS version: 68
BDR-X13UBK
Post
by MartyMcNuts » Mon Jul 31, 2023 7:57 am
mankr1981@gmail.com wrote: Mon Jul 31, 2023 7:19 am
OS device name: E:
Revision: 1.03
Serial number: CDDL300322UC
BDR-X13UBK
No, not currently supported as the firmware is DEC 2022+. You could be waiting quite a while for that to be supported..
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
mankr1981@gmail.com
Post
by mankr1981@gmail.com » Sat Aug 05, 2023 5:18 am
could someone help with this drive
OS device name: E:
Product: BD-RE BU40N
Revision: 1.02
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
