Purchased The BDR-XS07UHD on eBay, is it currently supported?
massmodz
delete
Re: Purchased The BDR-XS07UHD on eBay, is it currently supported?
I would recommend you buy one of those pioneers from me I have the ones with the correct fw just got 50 in yesterday flashing and testing them nowmassmodz wrote: Thu Jul 27, 2023 4:44 am I purchased a Pioneer BDR-XS07UHD slim slot portable USB 3.1 Gen1(3.0). Is there anything in particular I should know about it's capability to rip UHD or any idea if this particular model is on the older or newer firmware?
I reached out to the seller and haven't received a response. Figured I would get your take since this seems like the place to ask.
Thanks in advance!
massmodz
delete
Correct. If the drive is March 2022 then it most probably has pre 12/2022 firmware and should work out of the box.massmodz wrote: Thu Jul 27, 2023 9:30 pm I appreciate the offer but I already spent the money on this one. Manufacture date is March 2022. If firmware is able to be tinkered with I might just pick up 50 myself
Is there any tutorial posted on flashing this particular drive? Say from 1.02 to an older fw?
It’s my understanding if the firmware is pre Dec 2022 then it should work out of the box, or am I mistaken?
unless the seller did him a favor and updated it for him
