legosoff
#8581 Post by legosoff » Sun Jul 23, 2023 11:05 am
Weird iPhone changed in the version now Dolby Vision Profile 5 does not work, Dolby Vision Profile 8.1+HDR10 only play on HDR10, Dolby Vision Profile 8.4+HLG now there is already Dolby Vision. I already understood iOS 16.5 stopped Dolby Vision 5 and Vision 8.1+HDR10.
Gatorman
#8582 Post by Gatorman » Sun Jul 23, 2023 7:23 pm
Cr4z33 wrote: Sat Jul 22, 2023 12:32 pm I've remuxed a DV title with MKVtoolnix, but when it comes to MakeMKV I keep getting errors.
And by the way SAME errors with both DV MP4/MKV sources.
Is there really nothing I can do about it? :cry:
MakeMKV v1.17.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Cr4z33/MakeMKV_log.txt
Opening files on harddrive at Z:/***/***.mkv
Saving 1 titles into directory Y:/2160p/***
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 0 at P!"D9mkbBYey!WCL"e9n:29397081
DEBUG: Code 0 at Ja:%,=w1-Hvtlno[h?Ff:29398208
The source file 'Z:/***/***.mkv' is corrupt or invalid at offset 14345576448, attempting to work around
DEBUG: Code 0 at P!"D9mkbBYey!WCL"e9n:121265453
DEBUG: Code 0 at Ja:%,=w1-Hvtlno[h?Ff:213135021
DEBUG: Code 0 at |03L4Qet`E.eCrMo,`Zs':213137068
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29394022
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29404878
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29405384
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29403383
DEBUG: Code 0 at _m/rhT44"V1.WQmL:213132537
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121264464
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121263912
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):213130145
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file Y:/2160p/***/***_t00.mkv
0 titles saved, 1 failed
It looks like the rip may be corrupted?
You can ignore the "Program reads data faster than it can write to disk," errors. The other errors are typically cause by the disc being dirty or damaged when it was ripped.
lnchbox
#8583 Post by lnchbox » Sun Jul 23, 2023 7:53 pm
RESET_9999 wrote: Fri Feb 24, 2023 8:19 pm if you want to save some time, I already generated DV in resolve for most of the movies, here are over 600 RPU files ready to be injected :)
https://mega.nz/folder/CjYWyaZR#tSlKPhdblAd8shSaYoiOWA
Anyway you can PM me the new mega link to these please? Thank you in advance
#8584 Post by RESET_9999 » Mon Jul 24, 2023 1:59 am
qwertiio wrote: Sun Jul 23, 2023 6:56 am In mode 3-1, I got this "invalid Mastering Display index specified (ID:1000)" error in some video files, is it possible to manually choosing preset mastering displays or is there any workaround for this error????
I'm using this file as an example.
https://mega.nz/file/aOIj3RgY#9YSI8ik27 ... DVd7ga_vjc
That file got invalid mastering display metadata.
In the next version, I'll make the script fallback to 1000/50/P3 by default when the source is missing metadata.
you can add this after line 4596:
if not "%MDL1%"=="1000" if not "%MDL1%"=="4000" set MDL=20& set MDL1=1000& set min=50
qwertiio
#8585 Post by qwertiio » Mon Jul 24, 2023 9:25 am
RESET_9999 wrote: Mon Jul 24, 2023 1:59 am
It's working now, thanks.
davenukem
#8586 Post by davenukem » Tue Jul 25, 2023 11:11 pm
I'm losing my mind a little... I can't seem to find the tools folder download? Scripts folder is all there but can't for the life of me find the tools folder download? Is this available or is the expectation we manually download all of them? Any help appreciated :oops:
Gatorman
#8587 Post by Gatorman » Wed Jul 26, 2023 3:44 am
davenukem wrote: Tue Jul 25, 2023 11:11 pm I'm losing my mind a little... I can't seem to find the tools folder download? Scripts folder is all there but can't for the life of me find the tools folder download? Is this available or is the expectation we manually download all of them? Any help appreciated :oops:
The Tools folder has only been available intermittently. You'll need to download them individually. https://drive.google.com/file/d/1zZ9fV2 ... p=drivesdk, or keep an eye out for when they're available again.
legosoff
#8588 Post by legosoff » Thu Jul 27, 2023 4:13 am
iPhone 14 Dolby Vision test
https://radikal.host/i/Fa7tDT HDR10 vs https://radikal.host/i/Fa7hHx P5 dvh1, P8+HDR10 dvh1 and hvc1, there is nothing special, DV not work.
LG 1C Web OS Dolby Vision test
https://radikal.host/i/Fa7rdI P5 dvh1 and P8+HDR10 dvh1 and hvc1 great really.
speeddemon
#8589 Post by speeddemon » Thu Jul 27, 2023 8:11 am
@RESET_9999 can I use your scripts to streamline using DoViBaker?
If so, what's the proper process for doing this so I can accomplish the following:
1. Encode to a lossless format (ideally ProRes 422 HQ) from DoViBaker using your scripts
2. I'd then like to separately encode the ProRes file to x265 using StaxRip so I can customize the settings myself.
3. Would it then be ok for me ot inject hte original RPU again from the P7 FEL version?
#8590 Post by RESET_9999 » Thu Jul 27, 2023 11:10 am
speeddemon wrote: Thu Jul 27, 2023 8:11 am @RESET_9999 can I use your scripts to streamline using DoViBaker?
No need to convert to prores. Just make the avs script with 6-8-1, remove the subtitles/OSD and encode it directly in staxrip.
You have to convert the RPU to P8. Re-injecting the P7 rpu is wrong, it would be like applying FEL two times.
fransalas
#8591 Post by fransalas » Thu Jul 27, 2023 2:50 pm
Good afternoon friend, if I wanted to make an HDR movie to Dolby Vision, which one would you recommend your 3+2 script?
#8592 Post by RESET_9999 » Thu Jul 27, 2023 3:37 pm
fransalas wrote: Thu Jul 27, 2023 2:50 pm Good afternoon friend, if I wanted to make an HDR movie to Dolby Vision, which one would you recommend your 3+2 script?
best to worst:
1- Davinci Resolve (dolby algo) (tutorial video on my youtube)
2- Dovi_script (3-1) (dolby algo)
3- Dovi_script (3-2) (madvr, may have brightness fluctuation and inaccurate avg_pq values)
speeddemon
#8593 Post by speeddemon » Thu Jul 27, 2023 5:10 pm
RESET_9999 wrote: Thu Jul 27, 2023 11:10 am
3. Would it then be ok for me to inject the original RPU again from the P7 FEL version?
I had previously tried 6-9... is that the wrong flow?
#8594 Post by RESET_9999 » Thu Jul 27, 2023 5:21 pm
No, the output will be the same as staxrip.
6-9 is just automated and the encoding settings are hardcoded (except for preset and crf value)
thirdmoon
#8595 Post by thirdmoon » Fri Jul 28, 2023 4:37 am
@RESET_9999 On the Dolby vision excel file, you posted the L5 IMAX edits for Guardians of the Galaxy. How and where to use it? Thanks in advance.
