Two disc set: one will rip, one won't
I am using the latest version and I have a paid license.
FWIW, the discs are Harry Potter and the Deathly Hallows, Part 1.
I tried to rip Disc 1 a few weeks ago and just noticed that MakeMKV did all of the 'extras' from the disc but not the actual movie. Unfortunately, I did NOT save the log file from that attempt. It *did* create large MKV files (~9 GB each) for the movie, but the MKV files will not play in VLC (no error, but it just sits there). Furthermore, the MKV files do not have a 'length' when viewed in Windows Explorer.
I tried to rip it again and NONE of the files ripped this time. I have attached the log file for reference. Errors seem to be things like:
[*]'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00043.m2ts'
[*]Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0'
From what little I know, I suspect that this would indicate... a Blu-ray drive going bad...?
But the 2nd disc rips just fine. Log attached as well.
Any help would be appreciated. I didn't bother cleaning disc 1 as it does not look scratched or damaged to me. Thanks.
Re: Two disc set: one will rip, one won't
That 'uncorrectable error' indicates that the optical drive was unable to correctly read the disc. The standard advice is to gently clean the disc and try again.
If you're experiencing rip errors, please read here first!
If you clean the disc, try again, and it fails, post that log here.
Cleaned disc. Failed again.
Tried to post log file. Get error:
"Sorry, the board attachment quota has been reached."
You don't have to post a screenshot. You can copy & paste the text into here (especially into a 'code' block).
However, if you're getting the MEDIUM ERROR:L-EC UNCORRECTABLE ERROR messages, it still means the drive can't correctly read the disc.
Thanks for the info. Here it is.
I guess this means my Blu-ray drive is going bad...?
Debug log started at Tue Jul 25 10:21:19 2023 , written by MakeMKV v1.17.4 win(x64-release)
001005:0000 MakeMKV v1.17.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\username/MakeMKV_log.txt
No SDF v098: ASUS_BW-12B1ST_1.03_BAD0CL289720
No auto SDF v098: ASUS_BW-12B1ST_1.03_BAD0CL289720
DEBUG: Code 0 at /$I_D_s_U8V}=/y'0:29396253
DEBUG: Code 0 at Hu0Y6$"G%/26#v|y:213136746
DEBUG: Code 3 at w.G,[.W,J~s[OWwzq<.Q$D1P:29395310
SDF id v098: ASUS_BW-12B1ST_1.03_BAD0CL289720
No SDF v098: MATSHITA_DVD-RAM_SW830_8.82_20000000000000_8SSO10A11855
SDF id v098: MATSHITA_DVD-RAM_SW830_8.82_20000000000000_8SSO10A11855
DEBUG: Code 2147483648 at Nx*e^{R_\6h/]Oy7:121265499
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=tUjVokR/WO/vCU02QDnui6Biaasw5OgYSAoCDOUlkInDynMYWOiatLYegiJxU1nWSjJSG2MZKg+HR64SU3zo4sSguRLMOLm76irGzt+R1KHC/k5EyDcs7YpAvm6tMPmBy2H3U599rCyWVJHeQ+0j1oZwb9wWLARJxQ==
DCE=FJ1W/lY2/4Vx7v9+09US5F0W6L7dvS2eml+1erCpN/x8JbsQ4Lp4xgOciVCQoBTXKeOHCvl2t7skJg3YAyHJZBUk6gASsewxxR5MfGqUwWZoOvVz54zIdXv5gN/WKZUazOM/smYDpPGGnXnvaALKRwiKGEPB0Pq/Jw==
DISCID=005CFB23C3A6ADD900BA755C24B9D03ABE3DCC5E
003307:0000 File 00101.mpls was added as title #0
003307:0000 File 00207.mpls was added as title #1
003307:0000 File 00100.mpls was added as title #2
003307:0000 File 00007.mpls was added as title #3
003307:0000 File 00200.mpls was added as title #4
003307:0000 File 00307.mpls was added as title #5
003307:0000 File 00300.mpls was added as title #6
003307:0000 File 00023.m2ts was added as title #7
003025:0000 Title #00020.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00010.m2ts was added as title #8
003307:0000 File 00016.m2ts was added as title #9
003307:0000 File 00009.m2ts was added as title #10
003307:0000 File 00015.m2ts was added as title #11
003307:0000 File 00008.m2ts was added as title #12
003307:0000 File 00014.m2ts was added as title #13
003307:0000 File 00084.m2ts was added as title #14
003307:0000 File 00054.m2ts was added as title #15
003307:0000 File 00052.m2ts was added as title #16
003307:0000 File 00051.m2ts was added as title #17
003025:0000 Title #00135.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00133.m2ts was added as title #18
003025:0000 Title #00131.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00130.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00127.m2ts was added as title #19
003025:0000 Title #00126.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00125.m2ts was added as title #20
003307:0000 File 00124.m2ts was added as title #21
003025:0000 Title #00123.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00115.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00110.m2ts was added as title #22
003307:0000 File 00109.m2ts was added as title #23
003025:0000 Title #00108.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00106.m2ts was added as title #24
003025:0000 Title #00104.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00103.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00102.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00101.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00100.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00099.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00098.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00097.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00096.m2ts was added as title #25
003307:0000 File 00093.m2ts was added as title #26
003307:0000 File 00089.m2ts was added as title #27
003025:0000 Title #00088.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00047.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00087.m2ts was added as title #28
003025:0000 Title #00086.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00085.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00083.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00080.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00079.m2ts was added as title #29
003307:0000 File 00074.m2ts was added as title #30
003025:0000 Title #00073.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00072.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00071.m2ts was added as title #31
003307:0000 File 00070.m2ts was added as title #32
003307:0000 File 00069.m2ts was added as title #33
003307:0000 File 00068.m2ts was added as title #34
003025:0000 Title #00067.m2ts has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00066.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00065.m2ts was added as title #35
003025:0000 Title #00064.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00063.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00062.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00061.m2ts was added as title #36
003307:0000 File 00060.m2ts was added as title #37
003025:0000 Title #00059.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00049.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00046.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00045.m2ts was added as title #38
003307:0000 File 00044.m2ts was added as title #39
003307:0000 File 00043.m2ts was added as title #40
003025:0000 Title #00042.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00039.m2ts was added as title #41
003025:0000 Title #00038.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00033.m2ts was added as title #42
003025:0000 Title #00032.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00031.m2ts was added as title #43
003025:0000 Title #00030.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00029.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00028.m2ts was added as title #44
003025:0000 Title #00027.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00121.m2ts was added as title #45
003025:0000 Title #00022.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00119.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00117.m2ts was added as title #46
003025:0000 Title #00011.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00114.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00113.m2ts was added as title #47
003307:0000 File 00105.m2ts was added as title #48
005014:0000 Saving 1 titles into directory file://D:/Video/Harry Potter and the Deathly Hallows Part 1
DEBUG: Code 1024 at ;{hn4jqDN?x,JJv8&Pm:29396506
ak=1 seg=2 miss_count=1024 acc_size=0 off=1
0: 1011 off=5664
1: 1100 off=330
2: 1100 off=420
3: 1100 off=330
4: 1201 off=5664
5: 1201 off=5664
DEBUG: Code 2048 at ;{hn4jqDN?x,JJv8&Pm:29396506
ak=1 seg=2 miss_count=2048 acc_size=0 off=1
0: 1011 off=11808
1: 1100 off=330
2: 1100 off=420
3: 1100 off=330
4: 1201 off=11808
5: 1201 off=11808
AV sync issues in D:/Video/Harry Potter and the Deathly Hallows Part 1/Harry Potter and the Deathly Hallows Part 100.mkv
AV sync in 1,2 at 0:02:29.691 (4.708ms) : encountered overlapping frame, audio skew is +4.791ms
AV sync in 1,2 at 0:09:20.226 (3.541ms) : encountered overlapping frame, audio skew is +8.333ms
AV sync in 1,2 at 0:10:00.600 (10.333ms) : encountered overlapping frame, audio skew is +18.666ms
AV sync in 1,2 at 0:10:00.618 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +8ms
AV sync in 1,2 at 0:11:10.753 (1.25ms) : encountered overlapping frame, audio skew is +9.25ms
AV sync in 1,2 at 0:11:41.117 (4.333ms) : encountered overlapping frame, audio skew is +13.583ms
AV sync in 1,2 at 0:11:41.130 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +2.916ms
AV sync in 1,2 at 0:15:19.084 (5.583ms) : encountered overlapping frame, audio skew is +8.5ms
AV sync in 1,2 at 0:20:58.131 (3.625ms) : encountered overlapping frame, audio skew is +12.125ms
AV sync in 1,2 at 0:20:58.144 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +1.458ms
AV sync in 1,2 at 0:22:06.366 (10.5ms) : encountered overlapping frame, audio skew is +11.958ms
AV sync in 1,2 at 0:22:06.378 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +1.291ms
AV sync in 1,2 at 0:27:01.328 (4ms) : encountered overlapping frame, audio skew is +5.291ms
AV sync in 1,2 at 0:27:35.528 (7.166ms) : encountered overlapping frame, audio skew is +12.458ms
AV sync in 1,2 at 0:27:35.541 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +1.791ms
AV sync in 1,2 at 0:28:47.475 (10.458ms) : encountered overlapping frame, audio skew is +12.25ms
AV sync in 1,2 at 0:28:47.488 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +1.583ms
AV sync in 1,2 at 0:29:35.440 (3.416ms) : encountered overlapping frame, audio skew is +5ms
AV sync in 1,2 at 0:35:53.734 (9.416ms) : encountered overlapping frame, audio skew is +14.416ms
AV sync in 1,2 at 0:35:53.749 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +3.75ms
AV sync in 1,2 at 0:36:31.981 (4.125ms) : encountered overlapping frame, audio skew is +7.875ms
AV sync in 1,2 at 0:41:44.460 (1.166ms) : encountered overlapping frame, audio skew is +9.041ms
AV sync in 1,2 at 0:42:27.461 (6.708ms) : encountered overlapping frame, audio skew is +15.75ms
AV sync in 1,2 at 0:42:27.477 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +5.083ms
AV sync in 1,2 at 0:43:17.177 (1ms) : encountered overlapping frame, audio skew is +6.083ms
AV sync in 1,2 at 0:45:00.823 (2.791ms) : encountered overlapping frame, audio skew is +8.875ms
AV sync in 1,2 at 0:46:16.857 (8.375ms) : encountered overlapping frame, audio skew is +17.25ms
AV sync in 1,2 at 0:46:16.874 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +6.583ms
AV sync in 1,2 at 0:46:54.937 (0.291ms) : encountered overlapping frame, audio skew is +6.875ms
AV sync in 1,2 at 0:50:41.538 (1.291ms) : encountered overlapping frame, audio skew is +8.166ms
AV sync in 1,2 at 0:51:46.895 (8.375ms) : encountered overlapping frame, audio skew is +16.541ms
AV sync in 1,2 at 0:51:46.912 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +5.875ms
AV sync in 1,2 at 0:52:15.423 (4.833ms) : encountered overlapping frame, audio skew is +10.708ms
AV sync in 1,2 at 0:52:15.434 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +0.041ms
AV sync in 1,2 at 0:53:12.480 (9.666ms) : encountered overlapping frame, audio skew is +9.708ms
001003:0020 DEBUG: Code 3221225628 at w.G,[.W,J~s[OWwzq<.Q$D1P:121262371
001003:0020 DEBUG: Code 3221225628 at spDZ-<~\bXU:/9Ia:213130559
001003:0020 DEBUG: Code 100864261 at Hu0Y6$"G%/26#v|y:121271617
001003:0020 DEBUG: Code 100864261 at spDZ-<~\bXU:/9Ia:213130559
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00043.m2ts' at offset '496300032'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '496300032'
DEBUG: Code 3221225628 at XLZy#@p!6m/^{4B`f):29394896
001003:0020 DEBUG: Code 3221225628 at XLZy#@p!6m/^{4B`f):213131502
DEBUG: Code 100864261 at XLZy#@p!6m/^{4B`f):29394896
001003:0020 DEBUG: Code 100864261 at XLZy#@p!6m/^{4B`f):213131502
001003:0020 DEBUG: Code 0 at .{9B4[Fe jYP ZH8Jl]t:29395471
001003:0020 DEBUG: Code 0 at DB!^@B"@;hWJ_7EETUQ@:29394068
001003:0020 DEBUG: Code 0 at .{9B4[Fe jYP ZH8Jl]t:213131157
001003:0020 DEBUG: Code 0 at .{9B4[Fe jYP ZH8Jl]t:121262647
001003:0020 DEBUG: Code 242334 at .{9B4[Fe jYP ZH8Jl]t:121261773
001003:0020 DEBUG: Code 0 at |03L4Qet`E.eCrMo,`Zs':213137068
001003:0020 DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29394022
001003:0020 DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29404878
001003:0020 DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29405384
001003:0020 DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29403383
001003:0020 DEBUG: Code 0 at _m/rhT44"V1.WQmL:213132537
001003:0020 DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121264464
001003:0020 DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121263912
001003:0020 DEBUG: Code 0 at S+CKH[[Cjt"K.94+):213130145
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
---- Failed D:/Video/Harry Potter and the Deathly Hallows Part 1/Harry Potter and the Deathly Hallows Part 100.mkv
ch_0 3621122505000 0
ch_1 3622023405000 0
ch_2 3622924305000 0
ch_3 3623825205000 0
ch_4 3624410790000 0
ch_5 3625311690000 0
ch_6 3626212590000 0
ch_7 3627113490000 0
If your drive was starting to go bad, you'd see failures on many discs.
In this case, the first error is
All subsequent errors in the log are at the same offset, which means they're all at the same spot on the disc. For whatever reason, the drive can not correctly read the data in that spot.
The second error is
That error usually means the operating system, Windows in this case, thinks there's something wrong. In the case where an optical drive is only powered via USB, it is possible for MakeMKV to ask the drive to do things that use more power than the USB plug can provide. When this happens the drive briefly shuts down and reboots.
In this case, the drive looks to be an ASUS BW-12B1ST, which seems to be a traditional 'internal' drive. So, I'm guessing it is either inside your computer case and powered via the motherboard or it is in a USB connected external enclosure with its own power supply. As such, I doubt you're having a power issue.
In the end, all I can offer is this. In my experience, some drives just don't like some discs. I have 3 different optical drives. Most discs work fine on my 'main' drive, but not all of them. For discs that don't work on my main drive, they will often work in a different drive. If none of my drives can read a problematic disc, I clean the disc. Usually after a cleaning one of my drives will read the disc. It is very rare for none of my drives to be able to read a disc.
The second error is
Thank you very much dcoke22 for your very good post !
I've been reading along here for years (please don't infer my presence from the number of posts I've made) and so far, this is by far !!! the best explanation for the recurring problems with reading out movies.
Also included is the very important info that most problems can be solved with additional drives.
I always get the feeling here that people think it's a makemkv problem, which simply isn't true.
So... thank you very much for your posting.
I wish someone could post your explanation to every new user that comes in here with these errors.
The rest of the log file (too big for one post):
mt=0000019F25BBC130 n=5
s=0 n=1 o=496300032
0 287998 000001 3627113490000 45045000 27C2714C 0000000209100000003327640029AC26C0780227E5C0720000271A00075301C4C0001C9C380003938740E5C6260000E3FB40001C9C3A072E1CB08845160000008128EA809F3954C730C17498A344921A1E0E870341384850B02B03680BF2B4D7A7A142DD231DE285040222C5C841512728C1438811122C829362820609C24202
s=1 n=1 o=492994560
1 4944 000001 3627118080000 11520000 A6C19BED 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000060002000000000002090220060830000422D14700D02E8B8F6F096F50C1EAF1D1BF54D0529293DAB5A94A4A4E9314C628C62084210CA0F7316B5292952949418E629463108210D20E6B16B5254A4A52939C
s=2 n=1 o=492994560
2 2012 000001 3627118080000 11520000 A3E4460A 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000060002000000000002090220060830000422D14700D02E8B8F6F096F50C1EAF1D1BF54D0529293DAB5A94A4A4E9314C628C62084210CA0F7316B5292952949418E629463108210D20E6B16B5254A4A52939C
s=3 n=1 o=496300032
3 13384 000031 3628915290000 22522500 A58B0B01 1600130780043810003C800000010000000002F7036C17000A010002F7036C018F008914014700000010808000011080808002108080BF031080809F04108080400510808060061080802007108080DF081080800809108080F70A108080100B108080CF0C108080E70D108080180E108080EF0F108080701010808048111080
s=4 n=0 o=496300032
mt=0000019F25C1F8B0 n=5
s=0 n=20 o=496300032
0 50095 000008 3627068445000 45045000 95C774D0 0000000209500000000E06010A02002438075DC20037298000001072019E7EFC885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5B48E6BA5FA317D7C88F1FFC51058EE2A966F4FAC67163C7917B8D1B403486F0990745B2532A4769C738B20F5DD03189CB548F33549A374
0 88216 000000 3627203580000 45045000 2B230A2C 0000000209300000000E06010A04102438135DC20037298000002192219A7FB245F32000000300000302C397D9CCD03FAC548A091587EE36F82FECE57FFC4EC8C1A8029F0C02536AA80491E2D312126C4242410BE7ED2222AF890A33EBCA121E70653BDD443BE95389FC43A777D114026E6A29639870DCE1017EFDBEFAF4B1C8
0 50828 000008 3627158535000 45045000 8C259C5D 0000000209500000000E06010A060024380F5DC20037298000001006019E837C885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5AE54B0769FACF924E2D71FC83E9AF4CA5C18972E3DC212F5EC018AA7C04A220160C0623DCE4EA58718AA13D436C9817EB5BD4BF8E1E7E1
0 80221 000000 3627293670000 45045000 A889ADAE 0000000209300000000E06010A081024381B5DC20037298000001E21219A803245F32000000300000302C397D8CD35128BF6E95F179BC0C32279D78E50BAE095466E69C17183133DDC0A3B0540E5BBAC9BCC0FE93A66C5E668638F68416EE629596CB6EA785185C9F57BA09947D208BE889E89143E6B6436C04BB0677A719742
0 50149 000008 3627248625000 45045000 BDB3EA7E 0000000209500000000E06010A0A002438175DC200372980000010DA019E87FC885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5B447E0DBBB4EF47D3C0515D9DC1B9DCF03FE1C32A74C3411DCC0D3CD630C6F29606FA0FA0DB65B949B455354B486E1DC08497606B76564
0 101081 000000 3627383760000 45045000 04CC5208 0000000209300000000E06010A0C102438235DC20037298000002F5A219A84B245F32000000300000302C24FFE2B9C7B61F679008FAB11D23FD48CDE4976F2F86ECE02E71EECEF2481F854FC5BDB11053D35AFD9D1484DA7EA77E39EC3A15DAF4E0A493640929CA33B80965BCA263D9E2269C443085CF352381EE3C35E2D9308
0 51224 000008 3627338715000 45045000 43D48F78 0000000209500000000E06010A0E0024381F5DC200372980000011A1019E887C885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5B48EC8C2A8687F847A7F66DDB8BE88AA4D8AE0672D3C783264A7E59120A3F382377F20D7669359C8C0F73078DF6D99BFB340467E99D81F
0 87495 000000 3627473850000 45045000 8DBB2FBF 0000000209300000000E06010A101024382B5DC2003729800000235F219A893245F32000000300000302C246E939C6CDC8FDCAF8581DE08644922CE5C78A3963C382B23256C4DF574146D6EF0070F859C92CB4D343DBC81A17C52FA60242B23445A1E5E779A9C0C183AB2D08AED5DEE0AEBAA639D06F806E6AC24096B7BC0E0C
0 53035 000008 3627428805000 45045000 E563F848 0000000209500000000E06010A12002438275DC20037298000001255019E8CFC885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5B51DD3CC887347C2BB0A4884F20D2D2742CC7EE42E5F89C3524CE6E296B081D1011E3E9637F7FD2E79A1EE07D2364B5CDE9F7B8CB12FD4
0 102303 000000 3627563940000 45045000 2CF52727 0000000209300000000E06010A14102438335DC20037298000002FD4219A8DB245F32000000300000302C7B4462F97DD42A0B9AD520B28CCE5B0930CE5B28EDEC42684BC40231191BEA2F6D124F401C122124EA6ED87267D4E938E717CE63C7CCA463CAF883A8C23B0ED948FC98EBF8804FBFD2ADE654E70F9E602BC18C81CC9
0 53969 000008 3627518895000 45045000 671319FB 0000000209500000000E06010A160024382F5DC200372980000012CB019E917C885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5C2F4D063175DD9D5EC9C381A5A1A35D232584CFB31E4A30AE822CE4F767676C24A34877C4A22CFC414D7B78E2106F73E54EE700C987D6F
0 87441 000000 3627654030000 45045000 7BE102B2 0000000209300000000E06010A181024383B5DC200372980000022E6219A923245F32000000300000302C279EDC589DB3F8BA090C6D69D7FD19498C54D9134148964A25D6A18F46CB9E92ED5DFEE1074E14122536924F3F04F164FE3B9F5E23F6066E00634CCC3FB1DBBF591730E522CFC79EFA9CB3738FC876E9B0F0E1612D5
0 53093 000008 3627608985000 45045000 3CB34D18 0000000209500000000E06010A1A002438375DC20037298000001346019E95FC885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5C2E998E2804DD88C149713794186BB096D8A7D387E6E31D77AA073A040743DD0A6CCFBA4F1CA1976619685D98B1BC8F382419FAC9855C5
0 92356 000000 3627744120000 45045000 25FF6CC9 0000000209300000000E06010A1C102438435DC20037298000002D1A219A96B265E4400000030000086D099CF44311EC33027ACF9A9C62AC79DAEDD7DD8059A8945A46E2EEE82F733C48B1BE8B1AF34828C68D1112350E468CF72CB85580E904C9FFBAE93CFA9AF9BB6026CE6A9F6985CC290B8417A50C9D7AEF36B1149E2BF7
0 53452 000008 3627699075000 45045000 D80A7E7C 0000000209500000000E06010A1E0024383F5DC20037298000001385019E9A7C885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5B508E38A0022F51994CE94DB1059EB65BA283251338ECA9FAE6AF42F6A232B80D804751211AA5D86246A3C72D3FF0A038C46FD2F4C539B
0 83172 000000 3627834210000 45045000 847CA09A 0000000209300000000E06010A201024384B5DC200372980000022E0219A9B3245F32000000300000302C382719EAA697197B94BBA23A9C2CC7B829424B2BD16DE3CF041D33A9CBFA7488275AF4A40F10AF2F219B7C779287B4954ADB4E4F8D7E5FA7110D514BAC23DC04E334CBF5572019327604D41D92BEB0B85AB1D016913
0 52121 000008 3627789165000 45045000 D6A41339 0000000209500000000E06010A22002438475DC200372980000013EE019E9EFC885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5B508E377FAAFFC895682A9C02AE810B1C43FA1C31FE09B4EDAF141FD2364A44B2C2FCAB4033AB4D023FE0CD247207F949BC794E346CFF1
0 107243 000000 3627924300000 45045000 D8183CD1 0000000209300000000E06010A24102438535DC20037298000003679219A9FB245F32000000300000302C38270AAD6397BC84BA253C30273B97E18DF434DBF7F84235E41D822675E4168DD4CFDA9975AF03992DB60534714FDFB4EF72CEBAD7A1965DA476203E7C4558F38CDB770487C0475B344118F24E71301FE707D02A2BE
0 52435 000008 3627879255000 45045000 15A3F163 0000000209500000000E06010A260024384F5DC2003729800000144D019EA37C885FFAC3713E00000300000300000300000300000300000302172F76D532C006A5463C49F6AE47B9D5C2F4D065FBEB41B6EB2040B772B81F4A11997DB9089B2F2591032625B3E3CE4EAB96FA2279B6CBCDE252345B8B58F17267464AC84036C0
0 70105 000000 3627969345000 45045000 001C78BA 0000000209300000000E06010A28082438575DC20037298000001E1F219AA3F265E44000000300000868058348561C9CACCEF390A323F8390845B4021C862491B68548C29000A20DAE078AD5809BF3172EB44BF5ECF38CCB471D0391B24FA3A31D818DE716EC4947A8B8D13A8DA34285855F8FE43304CA19DD9E3BE95B09B9FD
s=1 n=42 o=492994560
1 4996 002001 3627129600000 11520000 533AC95C 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000020000000000000802000200300003E0AE78C862F3F9BEFD2728B9AC5AD494A528398C521062084210CE2F6B16B5292A525494A10731482104210CE0E6B16B5294A4A529420E629062104210C9EE62D4
1 4976 002001 3627141120000 11520000 9F10DBA6 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000060002000000000000090200020020000021ACF71CE8F0F6114D8FBF1D251839AC5AD4A4A52839CC628C41084210CE106B56B5A9495292949CE8318A2108210CE107356B5A94A4A94949CE631482084210CA
1 4956 002001 3627152640000 11520000 F854C0E6 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000008000000000000020902000208200005259AE2E78398D6632301C925251839AC5AD4A5292839CE631462084210CE2F6B56B5294A529494212739463104210CE2F7316B5294A4A9293A0E531463108210CD
1 5004 002001 3627164160000 11520000 47764ABB 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000000000000209020002007000058069B0CA481A22C49BEEBF74E31839AD62D6A529494A0E731882084210CE0F6B56B5294952D4A4A528390A5108210CE0F6B56B5AD4952929420E531083108210C9
1 5068 002001 3627175680000 11520000 16FB91F0 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4040000000200000000000000201020002001000011AD121DE0F890AA64C574E3183DAC5AD694A527318C520C41084210CA307B54D5A96A5294A5252729CA3108210CE0F6B16B5A949529494A4C7218A2084210C9ED6
1 5124 002001 3627187200000 11520000 FB202C03 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000100000000020802000200100004CD59F9C6499A264F7CE317B58B5A96A4A52949CC628C41084210CA2F7316C5A96A52D4A5252939463104410CA0F6B58B5AD4A5294949D2729462104210C9ED62D2
1 5088 002001 3627198720000 11520000 3FD81753 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000020802000200100005903048D650A4D3CA307B98C5AD4A5252949CE629042084210CA0F7318B52D6A5294A4A529398A310C410CA0F7356B5294A525294A4E731442108410C9EE62D4A4A
1 5112 002001 3627210240000 11520000 611F3482 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000200020002003000061350C481D06CDCBEBCA2F7358C5A94A5252931CC628C41084210CA2F7358C5AD4A52D4A4A52841483188210CA0F7316B5A94A4A92A4A12639463188210C9EE6B14
1 5252 002001 3627221760000 11520000 F21543D6 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000004A2F7356B5A94A4A507318C528821084210C62F7358B5AD6A529495252949463104210C60E6B16B5A94A525484A4E839442084210C5EE62D8B5A5494A509498E618
1 5556 002001 3627233280000 11520000 1BCC9ADA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000000000000000000000000000041EE6B16A529294A4C849CA330421084210C1EE6B58B6314B6294A5A52851CA5188210C5EE6B16A52D4A5252841CA528822084210C1CD6B16A5AD2A5A929520E649
1 5820 002001 3627244800000 11520000 A3205366 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000000000000000000000000000000000000420F7B56B5AD4A52507318E528C41084210C1EE7358C5B16B5A94A4A52839062104210C5EE6B56B52D6A5252741CC530C41084210BDEE6B56B52D6A525493A12530
1 5916 002001 3627256320000 11520000 E7063B8D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40800000000000000200000000000000000000000594A344610735AC6318B52D4B5A92A4A526214621460F7316B5A94A5294949CE739482104210C5EE6B16B525294A52849CA531042084210C5CE62D4A5252949CE72
1 5932 002001 3627267840000 11520000 6226F61D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40008000000000000200000002000000000000000159D0526EC60F7B5AC6316B5A94B5294A525063148214A0F7358B5A9494A9494A12629062084210C5EE6B16B5A9494A52739CE528C41084210C5EE6316A5252839C
1 5900 002001 3627279360000 11520000 A09F2E85 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400080000000800002000000020000000020000001598FD5116325CFCA0F7B5AC6316A5294A525294A4C6188420CA0F6B58B529494A52941CE531042104210CA0E7316B5AD4952529398C530C22084210C5EE6B16A4A
1 5836 002001 3627290880000 11520000 733BD95B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF408080000000000002000000020000000040000006A9154A4DE6C51D4A107398D62D4A5292952529498A3108410CA0E6B56B5294A5294A4212731462104210CA107358B5A92A5294941CE629062084210C5EE6B14A4A
1 5940 002001 3627302400000 11520000 5992E460 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF410080000400000000000000000000000000000004C3841C85C60E7358C5AD495252949CE831462084210C5EE6B16B5AD4A52D6B525294A4A3210220CA0F7318C5AD6A5296A5252741C8318C220C5ED62D2A4A4E7418
1 5864 002001 3627313920000 11520000 FFE33729 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41008000000000000000000000000080001000000496840EA14C4460F7356B5AD29524E8398E828C61084210CA0F7318B5AD6A529494A52839482084210CA0E7318C5AD4A4A5294A50731061084210C60E6AD6A52949
1 5796 002001 3627325440000 11520000 9FAC3DF6 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400081020000000000000000020000000400004000FD84BDDE98C39810DC60F7358C5A94952508414A518421084210CA0E7358C62D6A5AD4A4A4E731862084210CA0F6B58B5AD4A5A9494A0E631442084210C5ED62D6
1 5740 002001 3627336960000 11520000 9C28ED94 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40808000020000000000000082000000000000000367DE2503DCAA3DCA0F7356C5AD4952509394C618441084210CA0F7358C5AD4A5296A5250939483108210CA0F6B18C5B16A5294A4A0E729462108210C5EE62D6A52
1 5696 002001 3627348480000 11520000 81E30BC1 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF414082040300000000000000020000000200000003E70A98EABFAA70507BF550AD0A4A0F7318B5AD2A52527398C828C21084210CE0E7358C5AD4A5294A5290941442084210CA0F7358B5AD4A5294A4A5083946210421
1 5608 002001 3627360000000 11520000 0214F00E 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40008000020000000000000000000000000000000213225CA0F7358B5A96A4A5293990628841084210CE0F7358B5AD6A5294A524E839463084210CA107358C5AD6A5254949CE629062084210CA0E6AD6A525294A1063
1 5568 002001 3627371520000 11520000 DA13A08A 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440080000000000000000000000000000000000007E08E7CA0F7358B5A94952129318C520821084210CE2F7358C5AD6A5254A4A52739463104210CE0F7358B5AD4A529494A50629442084210CA0E62D6A529294A1263
1 5476 002001 3627383040000 11520000 47EA2590 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000040000000200000000000000050C42FB9B4A0F7358C5A94952529398C310821084210CE0F7358C62D6A5A94A52529394A2084210CA306B58C62D695292A4A4E839462084210C9EE6314A529294A0
1 5468 002001 3627394560000 11520000 994E09F2 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000020000000000000002000000058F503CE10735AB5AD4A524E7314A318821084210CE0F735AC5AD6A5294A4A527414A4084210CE0F735CC5AD4A529494A50739482084210C9EE6AD4A5292949D263
1 5468 002001 3627406080000 11520000 6E44421B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF404000000400000000000000000000000200000001F651FD8FCE0F7318B5A94952507398A518821084210CA307358C62D6A5294A4A529418A3104210CE307358C5AD4A5294A49D2939882084210C9EE6B16B5252941C
1 5492 002001 3627417600000 11520000 362E4E29 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44020000020200000000000000000000020000000708E23D0ED9FE20CA0F7398C5AD2A5292949CC620821084210CE10735AC62D4B52D4A5252839862084210CE2F739AC62D4A5294949CE831462084210C9EE6316A52
1 5484 002001 3627429120000 11520000 E22DD96A 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000600000000000000000000000200000006145005054E107398C5A94A52527394C318821084210CA107B58C62D6A5A96A4A52731462084210CE2F7398C5AD6A5A94A4A50731442084210CA0E6B16A5292829C
1 5424 002001 3627440640000 11520000 B9A6BE9E 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000060000000400000000000000000000000612A416594E307B98C62D4A52508398A310C41084210CA307B98C62D6A5AD294A50629462084210CA307B98C62D6A5252849CE728841084210C9EF6B16A5A92939C
1 5380 002001 3627452160000 11520000 423647F0 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000006000000000000000000000000000000070343D500CE0F7358C52D494A529318C418821084210CE307358C62D6B5294A4A527394A2084210D2307358D62D6A5294949CC531082084210CA0E6B16A5252949C
1 5324 002001 3627463680000 11520000 71AA8A74 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000060000000000000000000000000000000027582CE2F7358C5AD4A52507318C418C41084210CE307B1AC5AD6A5AD494A50729482084210CE307398C5AD6B5292949D0629041084210CA0E6B16A52529398C52
1 5228 002001 3627475200000 11520000 E42B0491 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000020000000200000000000000020000000584D061ADCE307358C62D4A524E8398A518821084210CE307B5AD6316B529294A52731462084210CE306B9AD62D6A5292949D2739441084210CA0E62D4A5252939C
1 5208 002001 3627486720000 11520000 374A08CA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000020000000200000002000000058F50E9D4393CE2F7B56C5AD494A4E72988418841084210D2307398D6316A529294A50731462084210D2107B9AC62D6A52929424E729042084210CA0E6B14A52529
1 5260 002001 3627498240000 11520000 2949D111 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000020000000240000002000000018C50362F446505CE4F7358B5A94A524E72108318841084210D2307B5AC62D6B529494A50731462084210D2307358B62D6A5292749CC728C62084210CA0E6AD4A52
1 5296 002001 3627509760000 11520000 A1C7EF37 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000000000000200000002000000066B98FCE2F7358C5A94952506318A318821084210D6507B5AC6316B5294A4A0E631442104210D2507398C62D6A5292949CC530842104210CA0E6316A52929398C31
1 5272 002001 3627521280000 11520000 72AD5F97 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000004000000040000000200000002000000051E65D50DD0D4E307B9AC62D4A525074188420841084210D2307B9AD6316A529494A10630C62084210CE507B9CC62D6A52929420E628C42084210CE0D6B16A52527
1 5212 002001 3627532800000 11520000 14AD086E 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000006000000000000000000000002000000051E514507CE0F7398B52D494A4E7298A419041084210D2307B98C62D6A529294A0E731462104210D2307B98C5AD4A4A92949CC629462104210CE2F6B14A52948314
1 5132 002001 3627544320000 11520000 29EB8ECF 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400040000200000000000000000000000200000004B7D821D94E2F7358B5294A49D28314C420C41084210D2307B9AC5AD6A529294A50731063104210D230739AC5AD6A5250949CC628841084210CA0F6B16A52529418
1 5104 002001 3627555840000 11520000 5BCB68E5 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000006000000000000000200000000000000052FA63A654E107358B5AD4A4A4E7398A529042084210CE507B9AC62D6A5292949D0629082104210D250739AC5AD4A5252939CC619062104210CE0E6B16A52529398
1 5236 002001 3627567360000 11520000 9651CA15 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000020000000000000002000000000000000263A2CCA0F7356C5294949CC7318A510841084210CE2F7358C5A9695294B4A52731062104210CE2F7358B5AD495252A3A4E720861084210C9EE62D6A525474A52A3
1 5244 002001 3627578880000 11520000 1F168B19 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000000008000200000000000000059FD3366BCE2F7398C5A94A525273148320C21084210CE4F7B98D62D6A525294A52829082104210D2507B5AC62D4A52529318E720C41084210C9EE6B16B52927398
1 5136 002001 3627590400000 11520000 8A73ACE7 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000020000000000000002000000058D59FD0ACE0F7B98C62D4A4A508318A529041084210D250735AC5A96A529294A4C629462104210CE2F735AB5AD4A4A92949CE630C62084210CA0E6B16A52528398
1 5040 002001 3627601920000 11520000 3551B475 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000020000000000000002000000058FB62264CE10739AC5AD6A4A4E7318A528C62084210D2507B9AC62D6A5292949CE731463084210D2307358B5AD6A4A52941CC629063084210CA0E6AD6A5A526398
s=2 n=42 o=492994560
2 2012 002001 3627129600000 11520000 B4973FEB 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000020000000000000802000200300003E0AE78C862F3F9BEFD2728B9AC5AD494A528398C521062084210CE2F6B16B5292A525494A10731482104210CE0E6B16B5294A4A529420E629062104210C9EE62D4
2 2012 002001 3627141120000 11520000 507D7002 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000060002000000000000090200020020000021ACF71CE8F0F6114D8FBF1D251839AC5AD4A4A52839CC628C41084210CE106B56B5A9495292949CE8318A2108210CE107356B5A94A4A94949CE631482084210CA
2 2012 002001 3627152640000 11520000 BA3F49BF 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000008000000000000020902000208200005259AE2E78398D6632301C925251839AC5AD4A5292839CE631462084210CE2F6B56B5294A529494212739463104210CE2F7316B5294A4A9293A0E531463108210CD
2 2012 002001 3627164160000 11520000 242A9ADA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000000000000209020002007000058069B0CA481A22C49BEEBF74E31839AD62D6A529494A0E731882084210CE0F6B56B5294952D4A4A528390A5108210CE0F6B56B5AD4952929420E531083108210C9
2 2012 002001 3627175680000 11520000 AA44E0D3 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4040000000200000000000000201020002001000011AD121DE0F890AA64C574E3183DAC5AD694A527318C520C41084210CA307B54D5A96A5294A5252729CA3108210CE0F6B16B5A949529494A4C7218A2084210C9ED6
2 2012 002001 3627187200000 11520000 69EFC845 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000100000000020802000200100004CD59F9C6499A264F7CE317B58B5A96A4A52949CC628C41084210CA2F7316C5A96A52D4A5252939463104410CA0F6B58B5AD4A5294949D2729462104210C9ED62D2
2 2012 002001 3627198720000 11520000 F7E73623 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000020802000200100005903048D650A4D3CA307B98C5AD4A5252949CE629042084210CA0F7318B52D6A5294A4A529398A310C410CA0F7356B5294A525294A4E731442108410C9EE62D4A4A
2 2012 002001 3627210240000 11520000 71676308 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000040000000200020002003000061350C481D06CDCBEBCA2F7358C5A94A5252931CC628C41084210CA2F7358C5AD4A52D4A4A52841483188210CA0F7316B5A94A4A92A4A12639463188210C9EE6B14
2 2012 002001 3627221760000 11520000 C05629BD 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000004A2F7356B5A94A4A507318C528821084210C62F7358B5AD6A529495252949463104210C60E6B16B5A94A525484A4E839442084210C5EE62D8B5A5494A509498E618
2 2012 002001 3627233280000 11520000 45F5F8F5 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000000000000000000000000000041EE6B16A529294A4C849CA330421084210C1EE6B58B6314B6294A5A52851CA5188210C5EE6B16A52D4A5252841CA528822084210C1CD6B16A5AD2A5A929520E649
2 2012 002001 3627244800000 11520000 C3278EE4 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000000000000000000000000000000000000420F7B56B5AD4A52507318E528C41084210C1EE7358C5B16B5A94A4A52839062104210C5EE6B56B52D6A5252741CC530C41084210BDEE6B56B52D6A525493A12530
2 2012 002001 3627256320000 11520000 215B0F1C 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40800000000000000200000000000000000000000594A344610735AC6318B52D4B5A92A4A526214621460F7316B5A94A5294949CE739482104210C5EE6B16B525294A52849CA531042084210C5CE62D4A5252949CE72
2 2012 002001 3627267840000 11520000 56E22AD8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40008000000000000200000002000000000000000159D0526EC60F7B5AC6316B5A94B5294A525063148214A0F7358B5A9494A9494A12629062084210C5EE6B16B5A9494A52739CE528C41084210C5EE6316A5252839C
2 2012 002001 3627279360000 11520000 781D7EA5 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400080000000800002000000020000000020000001598FD5116325CFCA0F7B5AC6316A5294A525294A4C6188420CA0F6B58B529494A52941CE531042104210CA0E7316B5AD4952529398C530C22084210C5EE6B16A4A
2 2012 002001 3627290880000 11520000 49E7BF58 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF408080000000000002000000020000000040000006A9154A4DE6C51D4A107398D62D4A5292952529498A3108410CA0E6B56B5294A5294A4212731462104210CA107358B5A92A5294941CE629062084210C5EE6B14A4A
2 2012 002001 3627302400000 11520000 19E884D5 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF410080000400000000000000000000000000000004C3841C85C60E7358C5AD495252949CE831462084210C5EE6B16B5AD4A52D6B525294A4A3210220CA0F7318C5AD6A5296A5252741C8318C220C5ED62D2A4A4E7418
2 2012 002001 3627313920000 11520000 5F052AFD 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41008000000000000000000000000080001000000496840EA14C4460F7356B5AD29524E8398E828C61084210CA0F7318B5AD6A529494A52839482084210CA0E7318C5AD4A4A5294A50731061084210C60E6AD6A52949
2 2012 002001 3627325440000 11520000 B6A0A9D0 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400081020000000000000000020000000400004000FD84BDDE98C39810DC60F7358C5A94952508414A518421084210CA0E7358C62D6A5AD4A4A4E731862084210CA0F6B58B5AD4A5A9494A0E631442084210C5ED62D6
2 2012 002001 3627336960000 11520000 7C71627B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40808000020000000000000082000000000000000367DE2503DCAA3DCA0F7356C5AD4952509394C618441084210CA0F7358C5AD4A5296A5250939483108210CA0F6B18C5B16A5294A4A0E729462108210C5EE62D6A52
2 2012 002001 3627348480000 11520000 CA14EE7D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF414082040300000000000000020000000200000003E70A98EABFAA70507BF550AD0A4A0F7318B5AD2A52527398C828C21084210CE0E7358C5AD4A5294A5290941442084210CA0F7358B5AD4A5294A4A5083946210421
2 2012 002001 3627360000000 11520000 313F25EA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40008000020000000000000000000000000000000213225CA0F7358B5A96A4A5293990628841084210CE0F7358B5AD6A5294A524E839463084210CA107358C5AD6A5254949CE629062084210CA0E6AD6A525294A1063
2 2012 002001 3627371520000 11520000 07F122A7 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440080000000000000000000000000000000000007E08E7CA0F7358B5A94952129318C520821084210CE2F7358C5AD6A5254A4A52739463104210CE0F7358B5AD4A529494A50629442084210CA0E62D6A529294A1263
2 2012 002001 3627383040000 11520000 D49790F4 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000040000000200000000000000050C42FB9B4A0F7358C5A94952529398C310821084210CE0F7358C62D6A5A94A52529394A2084210CA306B58C62D695292A4A4E839462084210C9EE6314A529294A0
2 2012 002001 3627394560000 11520000 F87D70C6 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000020000000000000002000000058F503CE10735AB5AD4A524E7314A318821084210CE0F735AC5AD6A5294A4A527414A4084210CE0F735CC5AD4A529494A50739482084210C9EE6AD4A5292949D263
2 2012 002001 3627406080000 11520000 D87ED080 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF404000000400000000000000000000000200000001F651FD8FCE0F7318B5A94952507398A518821084210CA307358C62D6A5294A4A529418A3104210CE307358C5AD4A5294A49D2939882084210C9EE6B16B5252941C
2 2012 002001 3627417600000 11520000 F221A353 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44020000020200000000000000000000020000000708E23D0ED9FE20CA0F7398C5AD2A5292949CC620821084210CE10735AC62D4B52D4A5252839862084210CE2F739AC62D4A5294949CE831462084210C9EE6316A52
2 2012 002001 3627429120000 11520000 C6084C5E 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000600000000000000000000000200000006145005054E107398C5A94A52527394C318821084210CA107B58C62D6A5A96A4A52731462084210CE2F7398C5AD6A5A94A4A50731442084210CA0E6B16A5292829C
2 2012 002001 3627440640000 11520000 14DA0CB7 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000060000000400000000000000000000000612A416594E307B98C62D4A52508398A310C41084210CA307B98C62D6A5AD294A50629462084210CA307B98C62D6A5252849CE728841084210C9EF6B16A5A92939C
2 2012 002001 3627452160000 11520000 46A49F92 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4400000006000000000000000000000000000000070343D500CE0F7358C52D494A529318C418821084210CE307358C62D6B5294A4A527394A2084210D2307358D62D6A5294949CC531082084210CA0E6B16A5252949C
2 2012 002001 3627463680000 11520000 84FFE51A 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000060000000000000000000000000000000027582CE2F7358C5AD4A52507318C418C41084210CE307B1AC5AD6A5AD494A50729482084210CE307398C5AD6B5292949D0629041084210CA0E6B16A52529398C52
2 2012 002001 3627475200000 11520000 D6FDB9C2 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000020000000200000000000000020000000584D061ADCE307358C62D4A524E8398A518821084210CE307B5AD6316B529294A52731462084210CE306B9AD62D6A5292949D2739441084210CA0E62D4A5252939C
2 2012 002001 3627486720000 11520000 48177D09 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000020000000200000002000000058F50E9D4393CE2F7B56C5AD494A4E72988418841084210D2307398D6316A529294A50731462084210D2107B9AC62D6A52929424E729042084210CA0E6B14A52529
2 2012 002001 3627498240000 11520000 71E079DD 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000020000000240000002000000018C50362F446505CE4F7358B5A94A524E72108318841084210D2307B5AC62D6B529494A50731462084210D2307358B62D6A5292749CC728C62084210CA0E6AD4A52
2 2012 002001 3627509760000 11520000 686D2EAE 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000000000000200000002000000066B98FCE2F7358C5A94952506318A318821084210D6507B5AC6316B5294A4A0E631442104210D2507398C62D6A5292949CC530842104210CA0E6316A52929398C31
2 2012 002001 3627521280000 11520000 430770F7 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000004000000040000000200000002000000051E65D50DD0D4E307B9AC62D4A525074188420841084210D2307B9AD6316A529494A10630C62084210CE507B9CC62D6A52929420E628C42084210CE0D6B16A52527
2 2012 002001 3627532800000 11520000 51E9BBAF 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000006000000000000000000000002000000051E514507CE0F7398B52D494A4E7298A419041084210D2307B98C62D6A529294A0E731462104210D2307B98C5AD4A4A92949CC629462104210CE2F6B14A52948314
2 2012 002001 3627544320000 11520000 F11CD877 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400040000200000000000000000000000200000004B7D821D94E2F7358B5294A49D28314C420C41084210D2307B9AC5AD6A529294A50731063104210D230739AC5AD6A5250949CC628841084210CA0F6B16A52529418
2 2012 002001 3627555840000 11520000 CF54D0F4 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000006000000000000000200000000000000052FA63A654E107358B5AD4A4A4E7398A529042084210CE507B9AC62D6A5292949D0629082104210D250739AC5AD4A5252939CC619062104210CE0E6B16A52529398
2 2012 002001 3627567360000 11520000 163E9DE2 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000020000000000000002000000000000000263A2CCA0F7356C5294949CC7318A510841084210CE2F7358C5A9695294B4A52731062104210CE2F7358B5AD495252A3A4E720861084210C9EE62D6A525474A52A3
2 2012 002001 3627578880000 11520000 7B17CC5D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000000008000200000000000000059FD3366BCE2F7398C5A94A525273148320C21084210CE4F7B98D62D6A525294A52829082104210D2507B5AC62D4A52529318E720C41084210C9EE6B16B52927398
2 2012 002001 3627590400000 11520000 2079F24B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000020000000000000002000000058D59FD0ACE0F7B98C62D4A4A508318A529041084210D250735AC5A96A529294A4C629462104210CE2F735AB5AD4A4A92949CE630C62084210CA0E6B16A52528398
2 2012 002001 3627601920000 11520000 045B5B97 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000002000000020000000000000002000000058FB62264CE10739AC5AD6A4A4E7318A528C62084210D2507B9AC62D6A5292949CE731463084210D2307358B5AD6A4A52941CC629063084210CA0E6AD6A5A526398
s=3 n=0 o=496300032
s=4 n=0 o=496300032
mt=0000019F252A0950 n=5
s=0 n=1 o=496300032
0 347316 000001 3628014390000 45045000 8EE585CE 0000000209100000003327640029AC26C0780227E5C0720000271A00075301C4C0001C9C380003938740E5C6260000E3FB40001C9C3A072E1CB08845160000008028EA8F3954C730C17498A344921A1E0E870341384850B02B03680BF2B4D7A7A142DD231DE285040222C5C841512728C1438811122C829362820609C2420261
s=1 n=1 o=492994560
1 5088 002001 3627602955000 11520000 DC389AE9 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000020000000200000002080000024000000183A6E18A1DCE3DAC84A2F7B9AC62D6A4A527398C418C42084210D22F7398C5AD6A529294A4E739442108210D2307B5AB5AD6A4A529420C628C62084210CA0E6314
s=2 n=1 o=492994560
2 2012 002001 3627602955000 11520000 1EB122CC 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000020000000200000002080000024000000183A6E18A1DCE3DAC84A2F7B9AC62D6A4A527398C418C42084210D22F7398C5AD6A529294A4E739442108210D2307B5AB5AD6A4A529420C628C62084210CA0E6314
s=3 n=0 o=496300032
s=4 n=0 o=496300032
005003:0000 Failed to save title 0 to file D:/Video/Harry Potter and the Deathly Hallows Part 1/Harry Potter and the Deathly Hallows Part 100.mkv
002023:0000 Encountered 23 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=23 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 16 unclassified errors
error=0xC000009C count=16 name=OS error - STATUS_DEVICE_DATA_ERROR
005004:0080 0 titles saved, 1 failed
Application exited at Tue Jul 25 10:45:50 2023
Thank you, dcoke22.
Follow-up post (should I start a new thread?)
Since my ASUS BW-12B1ST won't read the Blu-ray disc, I should probably get a different brand/model for a secondary drive.
Can anyone recommend some dependable but inexpensive Blu-ray drives to check out?
Would recommend a pioneer if you want to upgrade to a UHD model email meDougmeister wrote: ↑Fri Jul 28, 2023 2:34 pmFollow-up post (should I start a new thread?)
As I understand it, the internals of the LG and ASUS desktop drives are the same. They're all made by LG and just have a different brand printed on the case and are running different firmware. Drives from before the pandemic are considered to be relatively reliable. In the supply chain constrained post pandemic world we live in now, these drives are considered relatively unreliable. If you buy one, be sure to order from a place with a generous return policy.
The LG BU40N 'laptop' drive has a different set of internals and is considered a good drive.
The Pioneer drives have their own Pioneer designed and manufactured internals and are considered good drives. Pioneer released a firmware update to make Pioneer drives incompatible with MakeMKV. All the 'old' ones with previous, compatible firmware are likely sold out if you order from a big internet retailer. If you want one of them it is best to buy from one of the sellers listed in the Flashing Guide, like Billycar11.
