Avatar 4K UHD can't be decrypted
Jman5150
Re: Avatar 4K UHD can't be decrypted
Post by Jman5150 »
I got a pioneer recorder and it is ripping the disks the lg and asus wouldn’t including avatar
hln98
Post by hln98 »
I could not rip 2 separate discs - 4K Avatar Way of the Water from Amazon. They both died at similar places. Then I bought a copy from Best Buy and worked perfectly. I am thinking many folks are having similar issues with Amazon discs because they all came defective as these discs may have factory defects.
When I looked at these discs, they both have slight circular swirls in the inside and I can’t feel them when touching the areas. The Best Buy disc does not have these swirls that I can see. Maybe Amazon got discounts buying boat load of these defective discs.
gujral55
Post by gujral55 »
I am also stuck with a walmart uhd 4k copy. I am getting errors on 2 tracks/files. Can anyone help/share please.
Post by SamuriHL »
There's really nothing anyone else can do for you. If cleaning the disc doesn't work, no matter "how clean it looks" or "just took it out of the package" then either the disc is defective or your drive is having issues reading it.
gujral55
Post by gujral55 »
Stuck with a lemon! :(
gujral55 wrote: Thu Aug 31, 2023 10:55 pm Stuck with a lemon! :(
Are you within your return window? Exchanging for a new copy might be relatively easy.
