I am trying to rip a 4k disc of Operation Fortune: Ruse de Guerre using Makemkv on an M1 mac. The disc will not load nor is it recognized by Finder. I tried an older 4k disc and it worked with no problems. Below is my drive info. Do I need to update the firmware? I am new to 4k and any help would be appreciated.
Product: BD-RE BU40N
Revision: 1.00
Serial number:
Firmware date: 2116-12-20 15:28
Highest AACS version: 77
Firmware version: 1.00
LibreDrive doesn’t load a UHD disc
Re: LibreDrive doesn’t load a UHD disc
I recommend you start with cleaning the disc
Then replace disc
Then clean drive laser
Then replace drive
Then replace disc
Then replace drive
Cleaning the drive fixed it. Thanks so much for replying and solving my problem!
