LibreDrive doesn’t load a UHD disc
rtwd_sc
Post by rtwd_sc »
I am trying to rip a 4k disc of Operation Fortune: Ruse de Guerre using Makemkv on an M1 mac. The disc will not load nor is it recognized by Finder. I tried an older 4k disc and it worked with no problems. Below is my drive info. Do I need to update the firmware? I am new to 4k and any help would be appreciated.
Product: BD-RE BU40N
Revision: 1.00
Serial number:
Firmware date: 2116-12-20 15:28
Highest AACS version: 77
Firmware version: 1.00
Re: LibreDrive doesn’t load a UHD disc
I recommend you start with cleaning the disc
Then replace disc
Then clean drive laser
Then replace drive
rtwd_sc
Post by rtwd_sc »
Cleaning the drive fixed it. Thanks so much for replying and solving my problem!
